[petsc-dev] [Minor issue] Lag during PetscInitialize on Fedora 36 (never seen before with other OS)
    Matthew Knepley
    knepley at gmail.com
    Wed Jul 27 11:11:40 CDT 2022
On Wed, Jul 27, 2022 at 9:22 AM LEDAC Pierre <Pierre.LEDAC at cea.fr> wrote:
> Hello,
> Recently migrated from Fedora34 to Fedora36, using PETSc I have some lag
> during the PetscInitialize, which
> disappeared if I run again immediately the binary. But after few seconds,
> the lag happens again (see below).
> I suspected MPICH 4.0.2 on Fedora36, but a small reproducer indicated the
> issue is not in MPI_Init but really during PetscInitialize
How do you know it is not MPI_Init()? We always call it. Could you build
PETSc using --with-mpi=0 and do the test again?
My suspicion is that it is gethostbyname() that MPI_Init() calls. This is
always what mysterious startup slowness on my machine is.
      Matt
> Just annoying during testing, not very important, but did someone already
> see this ?
> Thanks,
> portable: /volatile/ledacp/petsc/src/ksp/ksp/tests (main) > time ./ex39
> real    0m3,593s
> user    0m0,872s
> sys    0m0,433s
> real    0m0,310s
> user    0m0,884s
> sys    0m0,023s
> # Wait ~20 seconds then again:
> real    0m3,507s
> user    0m0,897s
> sys    0m0,025s
> real    0m0,154s
> user    0m0,725s
> sys    0m0,015s
> real    0m0,176s
> user    0m0,875s
> sys    0m0,021s
> Pierre LEDAC
> Commissariat à l’énergie atomique et aux énergies alternatives
> Centre de SACLAY
> DES/ISAS/DM2S/STMF/LGLS
> Bâtiment 451 – point courrier n°43
> F-91191 Gif-sur-Yvette
> +33 1 69 08 04 03
> +33 6 83 42 05 79
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220727/911c78fa/attachment-0001.html>
