[petsc-dev] ld: warning: could not create compact unwind for _dgeev_: registers 27 and 28 not saved contiguously in frame
Satish Balay
balay at mcs.anl.gov
Tue Jul 19 13:53:01 CDT 2022
Strumpack requires the LAPACK routine dlapmr(), the current Lapack libraries ['liblapack.a', 'libblas.a'] does not have it
Try using --download-fblaslapack=1 option
Ok - so strumpack can't use vecLb
Satish
On Tue, 19 Jul 2022, Satish Balay via petsc-dev wrote:
> Executing: mpicc --version
> stdout:
> clang version 12.0.1
> Target: arm64-apple-darwin20.0.0
> Thread model: posix
> InstalledDir: /Users/kongf/mambaforge3/envs/moose-mpich/bin
> Ah yes - Moose doesn't use xcode compilers [or libraries..]
> Does download-openblas also fail?
> Satish
> > Barry,
> > Which commit in 3.17 fixed this?
> > Fande,
> > If I add a patch to branch "release-3.16" - would that get used? [as there won't be any new 3.16 tarballs]
> > BTW: Any particular reason to use fblaslapack - instead of [default] veclib on Mac?
> > Satish
> > On Tue, 19 Jul 2022, Fande Kong wrote:
> > > Hi Barry,
> > > It would be nice if we could get this patch to PETSc-3.16.
> > > We will upgrade to PETSc-3.17 for sure but it will take a while
> > > Fande
> > > On Tue, Jul 19, 2022 at 11:59 AM Barry Smith <bsmith at petsc.dev> wrote:
> > > > I think we have a fix for this in the 3.17 release. Perhaps Satish could
> > > > stick this line into the 3.16 release/tag for its users?
> > > > Barry
> > > > > On Jul 19, 2022, at 1:48 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> > > > > Hi PETSc team,
> > > > > We had trouble when compiling fblaslapack on Apple M1. We could get
> > > > around this issue by using the following patch, but do not really know
> > > > whether or not it is the right way to fix this issue.
> > > > > petsc % git diff
> > > > > diff --git a/config/BuildSystem/config/framework.py
> > > > b/config/BuildSystem/config/framework.py
> > > > > index 5b210ebb58..0ce27ef06d 100644
> > > > > --- a/config/BuildSystem/config/framework.py
> > > > > +++ b/config/BuildSystem/config/framework.py
> > > > > @@ -554,6 +554,7 @@ class Framework(config.base.Configure,
> > > > script.LanguageProcessor):
> > > > > lines = [s for s in lines if s.find(' was built for newer macOS
> > > > version') < 0]
> > > > > lines = [s for s in lines if s.find(' was built for newer OSX
> > > > version') < 0]
> > > > > lines = [s for s in lines if s.find(' stack subq instruction is
> > > > too different from dwarf stack size') < 0]
> > > > > + lines = [s for s in lines if s.find('could not create compact
> > > > unwind') < 0]
> > > > > # Nvidia linker
> > > > > lines = [s for s in lines if s.find('nvhpc.ld contains output
> > > > sections') < 0]
> > > > > if lines: output = '\n'.join(lines)
> > > > > Please check the log file to have more details of failing messages.
> > > > > Thanks,
> > > > > Fande
> > > > > <configure.log>
