[petsc-dev] macOS $ ./ex69 dyld[93174]: symbol not found in flat namespace '___mumps_ana_ord_wrappers_MOD_mumps_metis_nodend_mixedto32' Abort trap: 6
    Barry Smith
    bsmith at petsc.dev
    Thu Jul 14 09:58:15 CDT 2022
  No, no Strumpack.
  It is a strange thing, if I start a new shell then the code runs and I don't get that message but exit the new shell same problem. Sourcing .bashrc did not fix the problem so it is not just some environmental variable. Very odd.
> On Jul 14, 2022, at 3:35 AM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> Is your petsc configured with strumpack? I seem to recall some name clashing with MUMPS ordering routines. We found a similar issue with spack and mfem
> On Thu, Jul 14, 2022, 04:11 Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
> PETSc main
> $ ./ex69
> dyld[95838]: symbol not found in flat namespace '___mumps_ana_ord_wrappers_MOD_mumps_metis_nodend_mixedto32'
> Abort trap: 6
> ~/Src/petsc/src/snes/tutorials
>  nm -o ex69 | grep mumps_ana_ord_wrappers_MOD_mumps_metis_nodend_mixedto32
> ex69:                  U ___mumps_ana_ord_wrappers_MOD_mumps_metis_nodend_mixedto32
> but the symbol is in
> $ nm -o /Users/barrysmith/Src/petsc/arch-fix-fieldsplit-recall-setfromoptions/lib/libpetsc.3.017.dylib | grep mumps_ana_ord_wrappers_MOD_mumps_metis_nodend_mixedto32
> /Users/barrysmith/Src/petsc/arch-fix-fieldsplit-recall-setfromoptions/lib/libpetsc.3.017.dylib: 0000000002ae6991 T ___mumps_ana_ord_wrappers_MOD_mumps_metis_nodend_mixedto32
> Is this due to some recent change in the macOS compiler infrastructure?
> Everything on my system is what I believe to be the latest
> $ clang -v
> Apple clang version 13.1.6 (clang-1316.0.21.2.5)
> Target: x86_64-apple-darwin21.5.0
> Thread model: posix
> InstalledDir: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin
> ~/Src/petsc/src/snes/tutorials (barry/2022-07-13/fix-fieldsplit-recall-setfromoptions=) arch-fix-fieldsplit-recall-setfromoptions
> $ uname -a
> Darwin Barry-Smiths-MacBook-Pro.local 21.5.0 Darwin Kernel Version 21.5.0: Tue Apr 26 21:08:22 PDT 2022; root:xnu-8020.121.3~4/RELEASE_X86_64 x86_64
> $ gfortran -v
> Using built-in specs.
> COLLECT_GCC=gfortran
> COLLECT_LTO_WRAPPER=/usr/local/Cellar/gcc/11.3.0_2/bin/../libexec/gcc/x86_64-apple-darwin21/11/lto-wrapper
> Configured with: ../configure --prefix=/usr/local/opt/gcc --libdir=/usr/local/opt/gcc/lib/gcc/11 --disable-nls --enable-checking=release --with-gcc-major-version-only --enable-languages=c,c++,objc,obj-c++,fortran,d --program-suffix=-11 --with-gmp=/usr/local/opt/gmp --with-mpfr=/usr/local/opt/mpfr --with-mpc=/usr/local/opt/libmpc --with-isl=/usr/local/opt/isl --with-zstd=/usr/local/opt/zstd --with-pkgversion='Homebrew GCC 11.3.0_2' --with-bugurl=https://github.com/Homebrew/homebrew-core/issues <https://github.com/Homebrew/homebrew-core/issues> --enable-libphobos --build=x86_64-apple-darwin21 --with-system-zlib --with-sysroot=/Library/Developer/CommandLineTools/SDKs/MacOSX12.sdk
> Thread model: posix
> Supported LTO compression algorithms: zlib zstd
> gcc version 11.3.0 (Homebrew GCC 11.3.0_2)
> google finds [petsc-dev] problem in PETSc.pc filehttps://lists.mcs.anl.gov › petsc-dev › 2017-August <https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwjYmOmbpff4AhWApokEHRuXDY8QFnoECAMQAQ&url=https%3A%2F%2Flists.mcs.anl.gov%2Fpipermail%2Fpetsc-dev%2F2017-August%2F021244.html&usg=AOvVaw11zefHwBv_vttSC6cC_-aD> How to build? - The Mail Archivehttps://www.mail-archive.com › msg00411 <https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjYmOmbpff4AhWApokEHRuXDY8QFnoECAQQAQ&url=https%3A%2F%2Fwww.mail-archive.com%2Fgetfem-users%40nongnu.org%2Fmsg00411.html&usg=AOvVaw0SKHPTHrFgzmWHwNCXi12K>
> Something about gfortran modules and namespace and ????
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220714/7d358b64/attachment-0001.html>
