[petsc-dev] PCFIELDSPLIT with inner -ksp_reuse_preconditioner
    Barry Smith
    bsmith at petsc.dev
    Wed Jul 13 14:01:26 CDT 2022
   This is a bug https://gitlab.com/petsc/petsc/-/merge_requests/5424 <https://gitlab.com/petsc/petsc/-/merge_requests/5424> repeated calls to XXXSetFromOptions() with changed options should always propagate down to all the sub solvers regardless of how much a pain it may be to do, otherwise it provides a terrible user experience.
> On Jul 13, 2022, at 12:14 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jul 13, 2022 at 11:02 AM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>   Some of the ugliness of SetFromOptions in some of the nested solvers :-(
> * thread #1, queue = 'com.apple.main-thread', stop reason = breakpoint 1.1
>   * frame #0: 0x00000001132795f0 libpetsc.3.017.3.dylib`KSPSetFromOptions(ksp=0x00007f899f149a70) at itcl.c:324:19
>     frame #1: 0x0000000112eddda4 libpetsc.3.017.3.dylib`PCSetUp_FieldSplit(pc=0x00007f899f08d870) at fieldsplit.c:1087:32
>     frame #2: 0x0000000112dfb874 libpetsc.3.017.3.dylib`PCSetUp(pc=0x00007f899f08d870) at precon.c:991:5
>     frame #3: 0x0000000113285834 libpetsc.3.017.3.dylib`KSPSetUp(ksp=0x00007f899e95f670) at itfunc.c:401:3
>     frame #4: 0x000000011328b5e9 libpetsc.3.017.3.dylib`KSPSolve_Private(ksp=0x00007f899e95f670, b=0x00007f899f0dec70, x=0x00007f899f0ce870) at itfunc.c:835:3
>     frame #5: 0x000000011328aa66 libpetsc.3.017.3.dylib`KSPSolve(ksp=0x00007f899e95f670, b=0x00007f899f0dec70, x=0x00007f899f0ce870) at itfunc.c:1066:3
>     frame #6: 0x000000010e7c94e8 ex1111`main(argc=12, args=0x00007ff7b1739328) at ex1111.c:33:3
>     frame #7: 0x000000011703751e dyld`start + 462
> The SetFromOptions doesn't always traverse all the sub-methods suitably calling SetFromOptions on them because they may not have been created by the time that
> the SetFromOptions is first called. In this case, the PCSetUp_FieldSplit() creates the sub solvers and calls the options database on them after the initial call to PCSetFromOptions_FieldSplit()
> I've attached a patch that should fix this particular issue.
> I ran it with your test code, and it seemed to resolve the issue and ran the test suite, and it did not break anything.
> A redesigned/implemented PETSc would need some thought on how to improve the SetFromOptions model to prevent this kind of difficulty.
> My solution, which is used elsewhere in PETSc, would be for all PetscObjects to have a setfromoptions flag. If it creates a subobject and its own
> flag is set, it calls SetFromOptions on it.
>   Thanks,
>      Matt
> Barry
>> On Jul 13, 2022, at 8:40 AM, Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>> Hello,
>> A user(*) wants to switch back and forth with the option -fieldsplit_1_ksp_reuse_preconditioner, but it’s generating results that I don’t understand.
>> In the following example I solve three successive linear systems.
>> If I run
>> $ ./ex1111 -pc_type fieldsplit -fieldsplit_pc_type lu -log_view -info -options_view -switch false
>> -fieldsplit_1_ksp_reuse_preconditioner is always false, and I properly get:
>> 1) convergence in a single iteration every time
>> 2) [0] PCSetUp(): Setting up PC with same nonzero pattern for the last solve
>> 3) MatLUFactorNum         3 in -log_view
>> Now, if I run
>> $ ./ex1111 -pc_type fieldsplit -fieldsplit_pc_type lu -log_view -info -options_view -switch true
>> -fieldsplit_1_ksp_reuse_preconditioner is set to true for the second solve and switched back to false for the last solve.
>> I (wrongfully, IMHO?) get:
>> 1) convergence in 2 iterations for the last solve (instead of 1?)
>> 2) [0] PCSetUp(): Leaving PC with identical preconditioner since reuse preconditioner is set (which should not be set for the last solve?)
>> 3) MatLUFactorNum         1 (instead of 2?)
>> 4) #PETSc Option Table entries:
>> -fieldsplit_1_ksp_reuse_preconditioner false (though from -info, cf. point #2 just above, this option value is true?)
>> Does it make sense or do you agree that something is off?
>> Thanks,
>> Pierre
>> <ex1111.c>
>> (*) https://community.freefem.org/t/supply-petsc-numbering-for-shared-memory-block-matrix/486/18 <https://community.freefem.org/t/supply-petsc-numbering-for-shared-memory-block-matrix/486/18>
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220713/743de5b2/attachment-0001.html>
