[petsc-dev] VecNest
    Matthew Knepley
    knepley at gmail.com
    Tue Jul 12 07:50:44 CDT 2022
On Tue, Jul 12, 2022 at 7:41 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jul 12, 2022 at 7:39 AM Pierre Jolivet <pierre at joliv.et> wrote:
>> On 12 Jul 2022, at 2:32 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Jul 11, 2022 at 1:17 PM Pierre Jolivet <pierre at joliv.et> wrote:
>>> Hello,
>>> Could anyone help me understand what is going on in the following
>>> example, please?
>>> I have a VecNest.
>>> I either: a) initialize all values to 0.0, then set a specific part of
>>> the vector to nonzero or b) initialize a part of the vector to 0.0 and set
>>> the other part to nonzero.
>>> I don’t see why a) and b) produce different results.
>>> $ ./ex1111 -pc_type fieldsplit -ksp_monitor_true_residual
>>> -ksp_converged_reason -fieldsplit_pc_type jacobi -ksp_pc_side right
>>> -ksp_view_final_residual -nest_subvec true
>>>   0 KSP unpreconditioned resid norm 8.375635517980e-01 true resid norm
>>> 8.375635517980e-01 ||r(i)||/||b|| 1.000000000000e+00
>>>   1 KSP unpreconditioned resid norm 4.748816884247e-01 true resid norm
>>> 4.748816884247e-01 ||r(i)||/||b|| 5.669798875623e-01
>>>   2 KSP unpreconditioned resid norm 4.713006778679e-01 true resid norm
>>> 4.713006778679e-01 ||r(i)||/||b|| 5.627043784990e-01
>>>   3 KSP unpreconditioned resid norm 7.092979927129e-02 true resid norm
>>> 7.092979927129e-02 ||r(i)||/||b|| 8.468587144106e-02
>>>   4 KSP unpreconditioned resid norm 1.457836310255e-02 true resid norm
>>> 1.457836310255e-02 ||r(i)||/||b|| 1.740567992870e-02
>>>   5 KSP unpreconditioned resid norm 1.625040500524e-14 true resid norm
>>> 1.633468028779e-14 ||r(i)||/||b|| 1.950261595401e-14
>>> Linear solve converged due to CONVERGED_RTOL iterations 5
>>> KSP final norm of residual 1.63347e-14
>>> -ksp_view_final_residual -nest_subvec false
>>>   0 KSP unpreconditioned resid norm 0.000000000000e+00 true resid norm
>>> 8.375635517980e-01 ||r(i)||/||b||            inf
>>> Linear solve converged due to CONVERGED_ATOL iterations 0
>>> KSP final norm of residual 0.837564
>> I find if I assemble the vector, I get the same answers. Will try to
>> figure out what assembly is doing.
>> It’s probably reseting all these values
>> https://petsc.org/main/src/vec/vec/interface/rvector.c.html#line511,
>> which I believe are being used in VecNorm() inside VecNormalize().
>> I guess any call to VecNestSubVec() should invalidate those as well,
>> otherwise we get wrong cached norms.
>> I will give this a go.
> I believe the bug is the following:
>   You change values in a subvector, which does StateIncrease on the
> subvector, but not StateIncrease on the nest vector, so it has its cached
> norm
> I am not sure what to do about this, since how can the parent know you
> pulled out the subvector? Will think.
Okay, the error is more subtle. VecSet() automatically computes some norms.
VecNestGetSubVec() is broken with respect to caching.
I think the right fix now is VecNestGetSubVec/s() should increase the state
no matter what. If we want to get more precise, we need
to have Restore() for the subvecs, which checks the state of the subvector
when it is restored.
Do you want to change it?
     Matt
>    Matt
>> Thanks,
>> Pierre
>>   Thanks,
>>     Matt
>>> Thanks,
>>> Pierre
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220712/b0dac862/attachment-0001.html>
