[petsc-dev] Problem with unnamed side sets in DMPlexCreateExodus
Matthew Knepley
knepley at gmail.com
Sat Jul 9 15:15:13 CDT 2022
Hi David,
Can you take a look at this and tell me whether it will work for you, or we
should change it?
https://gitlab.com/petsc/petsc/-/merge_requests/5415
Matt
On Sun, Jun 26, 2022 at 4:08 PM David Andrs <andrsd at gmail.com> wrote:
> Hi Matt!
> On Jun 26, 2022, at 10:39, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Jun 26, 2022 at 8:31 AM David Andrs <andrsd at gmail.com> wrote:
>> Hi Jed!
>> I have been thinking about this and I think more correct would be not to
>> create the label with an empty name. It is not all or nothing kind of a
>> deal. Some side sets may have a name, some may not.
>> What I sent is probably more convenient, since after loading the mesh
>> there is either a label with a name or with an ID which can be easily
>> grabbed and passed into `PetscDSAddBoundary`. However, I agree that
>> assigning the name with an ID like this is specific to an application.
>> I can send a patch that will prevent the creation of a label with an
>> empty name if you think this is what should be happening instead.
> I think what Jed is suggesting is to use "Face Sets" if the name is empty.
> I currently prefer this solution.
> I am not sure I follow. The “Face Sets” label gets created correctly in
> both cases as far as I can tell.
> If there is an unnamed side set in the Exodus file, then a new label gets
> created with no name. This label then contains all the unnamed side sets.
> That does not seem correct to me and that’s what I was suggesting to fix in
> case y'all also think that is not right.
> Would this screw up your current workflow?
> No, it has no effect on my workflow. Jed’s question made me realize that
> I need to create the labels with IDs as their names every time. In
> ExodusII, IDs are mandatory, names are not. We do not know upfront if the
> user would use an ID or a name, so I need to have both if they are present
> in the mesh file. But, that is as I said, specific to my application.
> David
> I would also like to have a consistent policy for everything, but it is
> hard for me to see what this would be right now.
> Thanks,
> Matt
>> David
>> > On Jun 25, 2022, at 22:54, Jed Brown <jed at jedbrown.org> wrote:
>> > Do you think this is more correct than just using "Face Sets", which
>> gives you a numbered index?
>> > There is curently some inconsistency between file formats in whether
>> various sets show up as stand-alone labels or values under Face Sets. And
>> there's this lingering issue to have a way to name Face Sets (and Cell
>> Sets).
>> > https://gitlab.com/petsc/petsc/-/issues/689
>> > The issue is that if we just make named labels, there's no good way to
>> do structured traversal (handle all Face Sets) and one also has to be
>> careful to avoid namespace collisions between application sets and sets
>> created by the mesh.
>> > David Andrs <andrsd at gmail.com> writes:
>> >> Hello!
>> >> The current behavior in DMPlexCreateExodus is assuming that side sets
>> are always named. However, that is not always true. If there are unnamed
>> side sets in an ExodusII file, the created DM will contain a label with an
>> empty name (“”) with as many stratas as there are side sets. See the sample
>> output from DMView below:
>> >> Labels:
>> >> celltype: 3 strata with value/size (0 (138900), 4 (125514), 1
>> (265620))
>> >> depth: 3 strata with value/size (0 (138900), 1 (265620), 2 (125514))
>> >> Cell Sets: 4 strata with value/size (1 (57888), 2 (57888), 4 (1824),
>> 5 (7914))
>> >> Face Sets: 6 strata with value/size (1000 (28944), 1001 (28944), 1003
>> (28944), 1005 (15144), 1100 (120), 1200 (120))
>> >> : 6 strata with value/size (1000 (28944), 1001 (28944), 1003 (28944),
>> >> The attached patch fixes the behavior and names the side sets
>> according to their IDs if there is no name associated with it in the
>> ExodusII file. See the modified behavior below:
>> >> Labels:
>> (265620))
>> 5 (7914))
>> >> 1000: 1 strata with value/size (1000 (28944))
>> >> 1001: 1 strata with value/size (1001 (28944))
>> >> 1003: 1 strata with value/size (1003 (28944))
>> >> 1005: 1 strata with value/size (1005 (15144))
>> >> 1100: 1 strata with value/size (1100 (120))
>> >> 1200: 1 strata with value/size (1200 (120))
>> >> The patch is against 3.17.0, but is seems it should apply cleanly on
>> 3.17.2.
>> >> With regards,
>> >> David Andrs
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220709/00b2e272/attachment.html>
