[petsc-dev] ftn-auto in $PETSC_DIR/include ?
    Satish Balay
    balay at mcs.anl.gov
    Thu Jan 27 08:26:37 CST 2022
The change is at  https://gitlab.com/petsc/petsc/-/merge_requests/4770
Satish
On Thu, 27 Jan 2022, Satish Balay via petsc-dev wrote:
> And the source inside include don't get built.
> I guess the fix is to switch these stubs to custom [and move the sources to src/sys/logging/ftn-custom/]
> Will do.
> Satish
> On Thu, 27 Jan 2022, Stefano Zampini wrote:
> > This is a bug and it should be fixed
> > Il giorno gio 27 gen 2022 alle ore 15:22 Jose E. Roman <jroman at dsic.upv.es>
> > ha scritto:
> > > That is because PetscLogFlops() has an auto fortran stub. This is a
> > > PETSC_STATIC_INLINE function in include/petsclog.h
> > > Jose
> > > > El 27 ene 2022, a las 13:15, Stefano Zampini <stefano.zampini at gmail.com>
> > > escribió:
> > > > Just noticed this. Is it normal to have a ftn-auto directory generated
> > > by bfort in $PETSC_DIR/include?
> > > > (ecrcml-user) [szampini at localhost petsc]$ ls include/ftn-auto
> > > > makefile  petscloghf.c
> > > > Stefano
