[petsc-dev] Kokkos/Crusher perforance
Mark Adams
mfadams at lbl.gov
Wed Jan 26 13:35:33 CST 2022
On Wed, Jan 26, 2022 at 2:32 PM Justin Chang <jychang48 at gmail.com> wrote:
> rocgdb requires "-ggdb" in addition to "-g"
Ah, OK.
> What happens if you lower AMD_LOG_LEVEL to something like 1 or 2? I was
> hoping AMD_LOG_LEVEL could at least give you something like a "stacktrace"
> showing what the last successful HIP/HSA call was. I believe it should also
> show line numbers in the code.
I get a stack trace. The failure happens in our code. We can not find an
index that we received. The error message does not have the bad index. It
used to.
We have seen this before with buggy MPIs.
> On Wed, Jan 26, 2022 at 1:29 PM Mark Adams <mfadams at lbl.gov> wrote:
>> On Wed, Jan 26, 2022 at 1:54 PM Justin Chang <jychang48 at gmail.com> wrote:
>>> Couple suggestions:
>>> 1. Set the environment variable "export AMD_LOG_LEVEL=3" <- this will
>>> tell you everything that's happening at the HIP level (memcpy's, mallocs,
>>> kernel execution time, etc)
>> Humm, My reproducer uses 2 nodes and 128 processes. Don't think I could
>> do much with this flood of data.
>>> 2. Try rocgdb, AFAIK this is the closest "HIP variant of valgrind" that
>>> we officially support.
>> rocgdb just sat there reading symbols forever. I look at your doc.
>> Valgrind seem OK here.
>>> There are some tricks on running this together with mpi, to which you
>>> can just google "mpi with gdb". But you can see how rocgdb works here:
>>> https://www.olcf.ornl.gov/wp-content/uploads/2021/04/rocgdb_hipmath_ornl_2021_v2.pdf
>>> On Wed, Jan 26, 2022 at 9:56 AM Barry Smith <bsmith at petsc.dev> wrote:
>>>> Any way to run with valgrind (or a HIP variant of valgrind)? It looks
>>>> like a memory corruption issue and tracking down exactly when the
>>>> corruption begins is 3/4's of the way to finding the exact cause.
>>>> Are the crashes reproducible in the same place with identical runs?
>>>> On Jan 26, 2022, at 10:46 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> I think it is an MPI bug. It works with GPU aware MPI turned off.
>>>> I am sure Summit will be fine.
>>>> We have had users fix this error by switching thier MPI.
>>>> On Wed, Jan 26, 2022 at 10:10 AM Junchao Zhang <junchao.zhang at gmail.com>
>>>> wrote:
>>>>> I don't know if this is due to bugs in petsc/kokkos backend. See if
>>>>> you can run 6 nodes (48 mpi ranks). If it fails, then run the same problem
>>>>> on Summit with 8 nodes to see if it still fails. If yes, it is likely a bug
>>>>> of our own.
>>>>> --Junchao Zhang
>>>>> On Wed, Jan 26, 2022 at 8:44 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> I am not able to reproduce this with a small problem. 2 nodes or less
>>>>>> refinement works. This is from the 8 node test, the -dm_refine 5 version.
>>>>>> I see that it comes from PtAP.
>>>>>> This is on the fine grid. (I was thinking it could be on a reduced
>>>>>> grid with idle processors, but no)
>>>>>> [15]PETSC ERROR: Argument out of range
>>>>>> [15]PETSC ERROR: Key <= 0
>>>>>> [15]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>>> shooting.
>>>>>> [15]PETSC ERROR: Petsc Development GIT revision:
>>>>>> v3.16.3-696-g46640c56cb GIT Date: 2022-01-25 09:20:51 -0500
>>>>>> [15]PETSC ERROR:
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tests/data/../ex13 on a
>>>>>> arch-olcf-crusher named crusher020 by adams Wed Jan 26 08:35:47 2022
>>>>>> [15]PETSC ERROR: Configure options --with-cc=cc --with-cxx=CC
>>>>>> --with-fc=ftn --with-fortran-bindings=0
>>>>>> LIBS="-L/opt/cray/pe/mpich/8.1.12/gtl/lib -lmpi_gtl_hsa" --with-debugging=0
>>>>>> --COPTFLAGS="-g -O" --CXXOPTFLAGS="-g -O" --FOPTFLAGS=-g
>>>>>> --with-mpiexec="srun -p batch -N 1 -A csc314_crusher -t 00:10:00"
>>>>>> --with-hip --with-hipc=hipcc --download-hypre --with-hip-arch=gfx90a
>>>>>> --download-kokkos --download-kokkos-kernels --with-kokkos-kernels-tpl=0
>>>>>> --download-p4est=1
>>>>>> --with-zlib-dir=/sw/crusher/spack-envs/base/opt/cray-sles15-zen3/cce-13.0.0/zlib-1.2.11-qx5p4iereg4sjvfi5uwk6jn56o6se2q4
>>>>>> PETSC_ARCH=arch-olcf-crusher
>>>>>> [15]PETSC ERROR: #1 PetscTableFind() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/include/petscctable.h:131
>>>>>> [15]PETSC ERROR: #2 MatSetUpMultiply_MPIAIJ() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/mat/impls/aij/mpi/mmaij.c:35
>>>>>> [15]PETSC ERROR: #3 MatAssemblyEnd_MPIAIJ() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/mat/impls/aij/mpi/mpiaij.c:735
>>>>>> [15]PETSC ERROR: #4 MatAssemblyEnd_MPIAIJKokkos() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx:14
>>>>>> [15]PETSC ERROR: #5 MatAssemblyEnd() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/mat/interface/matrix.c:5678
>>>>>> [15]PETSC ERROR: #6 MatSetMPIAIJKokkosWithSplitSeqAIJKokkosMatrices()
>>>>>> at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx:267
>>>>>> [15]PETSC ERROR: #7 MatSetMPIAIJKokkosWithGlobalCSRMatrix() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx:825
>>>>>> [15]PETSC ERROR: #8 MatProductSymbolic_MPIAIJKokkos() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx:1167
>>>>>> [15]PETSC ERROR: #9 MatProductSymbolic() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/mat/interface/matproduct.c:825
>>>>>> [15]PETSC ERROR: #10 MatPtAP() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/mat/interface/matrix.c:9656
>>>>>> [15]PETSC ERROR: #11 PCGAMGCreateLevel_GAMG() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/ksp/pc/impls/gamg/gamg.c:87
>>>>>> [15]PETSC ERROR: #12 PCSetUp_GAMG() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/ksp/pc/impls/gamg/gamg.c:663
>>>>>> [15]PETSC ERROR: #13 PCSetUp() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/ksp/pc/interface/precon.c:1017
>>>>>> [15]PETSC ERROR: #14 KSPSetUp() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/ksp/ksp/interface/itfunc.c:417
>>>>>> [15]PETSC ERROR: #15 KSPSolve_Private() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/ksp/ksp/interface/itfunc.c:863
>>>>>> [15]PETSC ERROR: #16 KSPSolve() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/ksp/ksp/interface/itfunc.c:1103
>>>>>> [15]PETSC ERROR: #17 SNESSolve_KSPONLY() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/impls/ksponly/ksponly.c:51
>>>>>> [15]PETSC ERROR: #18 SNESSolve() at
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/interface/snes.c:4810
>>>>>> [15]PETSC ERROR: #19 main() at ex13.c:169
>>>>>> [15]PETSC ERROR: PETSc Option Table entries:
>>>>>> [15]PETSC ERROR: -benchmark_it 10
>>>>>> On Wed, Jan 26, 2022 at 7:26 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> The GPU aware MPI is dying going 1 to 8 nodes, 8 processes per node.
>>>>>>> I will make a minimum reproducer. start with 2 nodes, one process on
>>>>>>> each node.
>>>>>>> On Tue, Jan 25, 2022 at 10:19 PM Barry Smith <bsmith at petsc.dev>
>>>>>>> wrote:
>>>>>>>> So the MPI is killing you in going from 8 to 64. (The GPU flop
>>>>>>>> rate scales almost perfectly, but the overall flop rate is only half of
>>>>>>>> what it should be at 64).
>>>>>>>> On Jan 25, 2022, at 9:24 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> It looks like we have our instrumentation and job configuration in
>>>>>>>> decent shape so on to scaling with AMG.
>>>>>>>> In using multiple nodes I got errors with table entries not found,
>>>>>>>> which can be caused by a buggy MPI, and the problem does go away when I
>>>>>>>> turn GPU aware MPI off.
>>>>>>>> Jed's analysis, if I have this right, is that at *0.7T* flops we
>>>>>>>> are at about 35% of theoretical peal wrt memory bandwidth.
>>>>>>>> I run out of memory with the next step in this study (7 levels of
>>>>>>>> refinement), with 2M equations per GPU. This seems low to me and we will
>>>>>>>> see if we can fix this.
>>>>>>>> So this 0.7Tflops is with only 1/4 M equations so 35% is not
>>>>>>>> terrible.
>>>>>>>> Here are the solve times with 001, 008 and 064 nodes, and 5 or 6
>>>>>>>> levels of refinement.
>>>>>>>> out_001_kokkos_Crusher_5_1.txt:KSPSolve 10 1.0
>>>>>>>> 1.2933e+00 1.0 4.13e+10 1.1 1.8e+05 8.4e+03 5.8e+02 3 87 86 78 48
>>>>>>>> 100100100100100 248792 423857 6840 3.85e+02 6792 3.85e+02 100
>>>>>>>> out_001_kokkos_Crusher_6_1.txt:KSPSolve 10 1.0
>>>>>>>> 5.3667e+00 1.0 3.89e+11 1.0 2.1e+05 3.3e+04 6.7e+02 2 87 86 79 48
>>>>>>>> 100100100100100 571572 *700002* 7920 1.74e+03 7920 1.74e+03 100
>>>>>>>> out_008_kokkos_Crusher_5_1.txt:KSPSolve 10 1.0
>>>>>>>> 1.9407e+00 1.0 4.94e+10 1.1 3.5e+06 6.2e+03 6.7e+02 5 87 86 79 47
>>>>>>>> 100100100100100 1581096 3034723 7920 6.88e+02 7920 6.88e+02 100
>>>>>>>> out_008_kokkos_Crusher_6_1.txt:KSPSolve 10 1.0
>>>>>>>> 7.4478e+00 1.0 4.49e+11 1.0 4.1e+06 2.3e+04 7.6e+02 2 88 87 80 49
>>>>>>>> 100100100100100 3798162 5557106 9367 3.02e+03 9359 3.02e+03 100
>>>>>>>> out_064_kokkos_Crusher_5_1.txt:KSPSolve 10 1.0
>>>>>>>> 2.4551e+00 1.0 5.40e+10 1.1 4.2e+07 5.4e+03 7.3e+02 5 88 87 80 47
>>>>>>>> 100100100100100 11065887 23792978 8684 8.90e+02 8683 8.90e+02 100
>>>>>>>> out_064_kokkos_Crusher_6_1.txt:KSPSolve 10 1.0
>>>>>>>> 1.1335e+01 1.0 5.38e+11 1.0 5.4e+07 2.0e+04 9.1e+02 4 88 88 82 49
>>>>>>>> 100100100100100 24130606 43326249 11249 4.26e+03 11249 4.26e+03 100
>>>>>>>> On Tue, Jan 25, 2022 at 1:49 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>>>> Note that Mark's logs have been switching back and forth between
>>>>>>>>>> -use_gpu_aware_mpi and changing number of ranks -- we won't have that
>>>>>>>>>> information if we do manual timing hacks. This is going to be a routine
>>>>>>>>>> thing we'll need on the mailing list and we need the provenance to go with
>>>>>>>>>> it.
>>>>>>>>> GPU aware MPI crashes sometimes so to be safe, while debugging, I
>>>>>>>>> had it off. It works fine here so it has been on in the last tests.
>>>>>>>>> Here is a comparison.
>>>>>>>> <tt.tar>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220126/a62f0479/attachment.html>
