[petsc-dev] Kokkos/Crusher perforance
Mark Adams
mfadams at lbl.gov
Mon Jan 24 13:46:23 CST 2022
Yea, CG/Jacobi is as close to a benchmark code as we could want. I could
run this on one processor to get cleaner numbers.
Is there a designated ECP technical support contact?
On Mon, Jan 24, 2022 at 2:18 PM Barry Smith <bsmith at petsc.dev> wrote:
> I think you should contact the crusher ECP technical support team and
> tell them you are getting dismel performance and ask if you should expect
> better. Don't waste time flogging a dead horse.
> On Jan 24, 2022, at 2:16 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Jan 24, 2022 at 2:11 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> On Mon, Jan 24, 2022 at 12:55 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> On Mon, Jan 24, 2022 at 1:38 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> Mark, I think you can benchmark individual vector operations, and once
>>>> we get reasonable profiling results, we can move to solvers etc.
>>> Can you suggest a code to run or are you suggesting making a vector
>>> benchmark code?
>> Make a vector benchmark code, testing vector operations that would be
>> used in your solver.
>> Also, we can run MatMult() to see if the profiling result is reasonable.
>> Only once we get some solid results on basic operations, it is useful to
>> run big codes.
> So we have to make another throw-away code? Why not just look at the
> vector ops in Mark's actual code?
> Matt
>>>> --Junchao Zhang
>>>> On Mon, Jan 24, 2022 at 12:09 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> On Mon, Jan 24, 2022 at 12:44 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>> Here except for VecNorm the GPU is used effectively in that most of
>>>>>> the time is time is spent doing real work on the GPU
>>>>>> VecNorm 402 1.0 4.4100e-01 6.1 1.69e+09 1.0 0.0e+00
>>>>>> 0.0e+00 4.0e+02 0 1 0 0 20 9 1 0 0 33 30230 225393 0
>>>>>> 0.00e+00 0 0.00e+00 100
>>>>>> Even the dots are very effective, only the VecNorm flop rate over the
>>>>>> full time is much much lower than the vecdot. Which is somehow due to the
>>>>>> use of the GPU or CPU MPI in the allreduce?
>>>>> The VecNorm GPU rate is relatively high on Crusher and the CPU rate is
>>>>> about the same as the other vec ops. I don't know what to make of that.
>>>>> But Crusher is clearly not crushing it.
>>>>> Junchao: Perhaps we should ask Kokkos if they have any experience with
>>>>> Crusher that they can share. They could very well find some low level magic.
>>>>>> On Jan 24, 2022, at 12:14 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> Mark, can we compare with Spock?
>>>>>> Looks much better. This puts two processes/GPU because there are
>>>>>> only 4.
>>>>>> <jac_out_001_kokkos_Spock_6_1_notpl.txt>
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220124/1267ff83/attachment-0001.html>
