[petsc-dev] Kokkos/Crusher perforance
    Junchao Zhang
    junchao.zhang at gmail.com
    Mon Jan 24 12:38:45 CST 2022
Mark, I think you can benchmark individual vector operations, and once we
get reasonable profiling results, we can move to solvers etc.
--Junchao Zhang
On Mon, Jan 24, 2022 at 12:09 PM Mark Adams <mfadams at lbl.gov> wrote:
> On Mon, Jan 24, 2022 at 12:44 PM Barry Smith <bsmith at petsc.dev> wrote:
>>   Here except for VecNorm the GPU is used effectively in that most of the
>> time is time is spent doing real work on the GPU
>> VecNorm              402 1.0 4.4100e-01 6.1 1.69e+09 1.0 0.0e+00 0.0e+00
>> 4.0e+02  0  1  0  0 20   9  1  0  0 33 30230   225393      0 0.00e+00    0
>> 0.00e+00 100
>> Even the dots are very effective, only the VecNorm flop rate over the
>> full time is much much lower than the vecdot. Which is somehow due to the
>> use of the GPU or CPU MPI in the allreduce?
> The VecNorm GPU rate is relatively high on Crusher and the CPU rate is
> about the same as the other vec ops. I don't know what to make of that.
> But Crusher is clearly not crushing it.
> Junchao: Perhaps we should ask Kokkos if they have any experience with
> Crusher that they can share. They could very well find some low level magic.
>> On Jan 24, 2022, at 12:14 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> Mark, can we compare with Spock?
>>  Looks much better. This puts two processes/GPU because there are only 4.
>> <jac_out_001_kokkos_Spock_6_1_notpl.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220124/13bdaf2b/attachment.html>
