[petsc-dev] Kokkos/Crusher perforance
    Barry Smith
    bsmith at petsc.dev
    Sun Jan 23 21:55:18 CST 2022
> On Jan 23, 2022, at 10:47 PM, Jacob Faibussowitsch <jacob.fai at gmail.com> wrote:
>> The outer LogEventBegin/End captures the entire time, including copies, kernel launches etc.
> Not if the GPU call is asynchronous. To time the call the stream must also be synchronized with the host. The only way to truly time only the kernel calls themselves is to wrap the actual call itself:
> cublasXaxpy_petsc(…)
>   PetscLogGpuTimeBegin();
>   cublasXaxpy(…);
>   PetscLogGpuTimeEnd();
  Indeed, they are wrapped as above.
> Note that
> #define cublasXaxpy_petsc(…) PetscLogGpuTimeBegin();cublasXaxpy(…);PetscLogGpuTimeEnd();
> Is not sufficient, as this would still include transfers if those transfers happen as direct arguments to the function:
> cublasXaxpy_petsc(RAII_xfer_to_device(),…);
  I am not sure what you mean here? RAII_xfer_to_device()?  Do you mean unified memory transfers down? I don't think we use those.
  The PetscLogGpuTimeBegin()/End was written by Hong so it works with events to get a GPU timing, it is not suppose to include the CPU kernel launch times or the time to move the scalar arguments to the GPU. It may not be perfect but it is the best we can do to capture the time the GPU is actively doing the numerics, which is what we want.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
>> On Jan 23, 2022, at 21:37, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>> On Jan 23, 2022, at 10:01 PM, Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>>> On Sat, Jan 22, 2022 at 9:00 PM Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>>> On Sat, Jan 22, 2022 at 5:00 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>   The GPU flop rate (when 100 percent flops on the GPU) should always be higher than the overall flop rate (the previous column). For large problems they should be similar, for small problems the GPU one may be much higher.
>>>   If the CPU one is higher (when 100 percent flops on the GPU) something must be wrong with the logging. I looked at the code for the two cases and didn't see anything obvious.
>>>   Junchao and Jacob,
>>>       I think some of the timing code in the Kokkos interface is wrong.
>>>     *  The PetscLogGpuTimeBegin/End should be inside the viewer access code not outside it. (The GPU time is an attempt to best time the kernels, not other processing around the use of the kernels, that other stuff is captured in the general LogEventBegin/End.
>>> What about potential host to device memory copy before calling a kernel?  Should we count it in the kernel time?
>>   Nope, absolutely not. The GPU time represents the time the GPU is doing active work. The outer LogEventBegin/End captures the entire time, including copies, kernel launches etc. No reason to put the copy time in the GPU time because then there would be no need for the GPU since it would be the LogEventBegin/End. The LogEventBegin/End minus the GPU time represents any overhead from transfers.
>>> Good point
>>>     *  The use of WaitForKokkos() is confusing and seems inconsistent.
>>> I need to have a look. Until now, I have not paid much attention to kokkos profiling.
>>>              -For example it is used in VecTDot_SeqKokkos() which I would think has a barrier anyways because it puts a scalar result into update?
>>>              -Plus PetscLogGpuTimeBegin/End is suppose to already have suitable system (that Hong added) to ensure the kernel is complete; reading the manual page and looking at Jacobs cupmcontext.hpp it seems to be there so I don't think WaitForKokkos() is needed in most places (or is Kokkos asynchronous and needs this for correctness?)
>>> But these won't explain the strange result of overall flop rate being higher than GPU flop rate.
>>>   Barry
>>>> On Jan 22, 2022, at 11:44 AM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>>> I am getting some funny timings and I'm trying to figure it out.
>>>> I figure the gPU flop rates are bit higher because the timers are inside of the CPU timers, but some are a lot bigger or inverted
>>>> --- Event Stage 2: KSP Solve only
>>>> MatMult              400 1.0 1.0094e+01 1.2 1.07e+11 1.0 3.7e+05 6.1e+04 0.0e+00  2 55 62 54  0  68 91100100  0 671849   857147      0 0.00e+00    0 0.00e+00 100
>>>> MatView                2 1.0 4.5257e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
>>>> KSPSolve               2 1.0 1.4591e+01 1.1 1.18e+11 1.0 3.7e+05 6.1e+04 1.2e+03  2 60 62 54 60 100100100100100 512399   804048      0 0.00e+00    0 0.00e+00 100
>>>> SFPack               400 1.0 2.4545e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
>>>> SFUnpack             400 1.0 9.4637e-05 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
>>>> VecTDot              802 1.0 3.0577e+00 2.1 3.36e+09 1.0 0.0e+00 0.0e+00 8.0e+02  0  2  0  0 40  13  3  0  0 67 69996   488328      0 0.00e+00    0 0.00e+00 100
>>>> VecNorm              402 1.0 1.9597e+00 3.4 1.69e+09 1.0 0.0e+00 0.0e+00 4.0e+02  0  1  0  0 20   6  1  0  0 33 54744   571507      0 0.00e+00    0 0.00e+00 100
>>>> VecCopy                4 1.0 1.7143e-0228.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
>>>> VecSet                 4 1.0 3.8051e-0316.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
>>>> VecAXPY              800 1.0 8.6160e-0113.6 3.36e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   6  3  0  0  0 247787   448304      0 0.00e+00    0 0.00e+00 100
>>>> VecAYPX              398 1.0 1.6831e+0031.1 1.67e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   5  1  0  0  0 63107   77030      0 0.00e+00    0 0.00e+00 100
>>>> VecPointwiseMult     402 1.0 3.8729e-01 9.3 8.43e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  1  0  0  0 138502   262413      0 0.00e+00    0 0.00e+00 100
>>>> VecScatterBegin      400 1.0 1.1947e+0035.1 0.00e+00 0.0 3.7e+05 6.1e+04 0.0e+00  0  0 62 54  0   5  0100100  0     0       0      0 0.00e+00    0 0.00e+00  0
>>>> VecScatterEnd        400 1.0 6.2969e+00 8.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  10  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
>>>> PCApply              402 1.0 3.8758e-01 9.3 8.43e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  1  0  0  0 138396   262413      0 0.00e+00    0 0.00e+00 100
>>>> On Sat, Jan 22, 2022 at 11:10 AM Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>>>> On Sat, Jan 22, 2022 at 10:04 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>>> Logging GPU flops should be inside of PetscLogGpuTimeBegin()/End()  right?
>>>> No, PetscLogGpuTime() does not know the flops of the caller.
>>>> On Fri, Jan 21, 2022 at 9:47 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>   Mark,
>>>>   Fix the logging before you run more. It will help with seeing the true disparity between the MatMult and the vector ops.
>>>>> On Jan 21, 2022, at 9:37 PM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>>>> Here is one with 2M / GPU. Getting better.
>>>>> On Fri, Jan 21, 2022 at 9:17 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>>    Matt is correct, vectors are way too small.
>>>>>    BTW: Now would be a good time to run some of the Report I benchmarks on Crusher to get a feel for the kernel launch times and performance on VecOps.
>>>>>    Also Report 2.
>>>>>   Barry
>>>>>> On Jan 21, 2022, at 7:58 PM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>>>> On Fri, Jan 21, 2022 at 6:41 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>>>>> I am looking at performance of a CG/Jacobi solve on a 3D Q2 Laplacian (ex13) on one Crusher node (8 GPUs on 4 GPU sockets, MI250X or is it MI200?).
>>>>>> This is with a 16M equation problem. GPU-aware MPI and non GPU-aware MPI are similar (mat-vec is a little faster w/o, the total is about the same, call it noise)
>>>>>> I found that MatMult was about 3x faster using 8 cores/GPU, that is all 64 cores on the node, then when using 1 core/GPU. With the same size problem of course.
>>>>>> I was thinking MatMult should be faster with just one MPI process. Oh well, worry about that later.
>>>>>> The bigger problem, and I have observed this to some extent with the Landau TS/SNES/GPU-solver on the V/A100s, is that the vector operations are expensive or crazy expensive.
>>>>>> You can see (attached) and the times here that the solve is dominated by not-mat-vec:
>>>>>> Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total   GPU    - CpuToGpu -   - GpuToCpu - GPU
>>>>>>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s Mflop/s Count   Size   Count   Size  %F
>>>>>> 17:15 main= /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tests/data$ grep "MatMult              400" jac_out_00*5_8_gpuawaremp*
>>>>>> MatMult              400 1.0 1.2507e+00 1.3 1.34e+10 1.1 3.7e+05 1.6e+04 0.0e+00  1 55 62 54  0  27 91100100  0 668874       0      0 0.00e+00    0 0.00e+00 100
>>>>>> 17:15 main= /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tests/data$ grep "KSPSolve               2" jac_out_001*_5_8_gpuawaremp*
>>>>>> KSPSolve               2 1.0 4.4173e+00 1.0 1.48e+10 1.1 3.7e+05 1.6e+04 1.2e+03  4 60 62 54 61 100100100100100 208923   1094405      0 0.00e+00    0 0.00e+00 100
>>>>>> Notes about flop counters here,
>>>>>> * that MatMult flops are not logged as GPU flops but something is logged nonetheless.
>>>>>> * The GPU flop rate is 5x the total flop rate  in KSPSolve :\
>>>>>> * I think these nodes have an FP64 peak flop rate of 200 Tflops, so we are at < 1%.
>>>>>> This looks complicated, so just a single remark:
>>>>>> My understanding of the benchmarking of vector ops led by Hannah was that you needed to be much
>>>>>> bigger than 16M to hit peak. I need to get the tech report, but on 8 GPUs I would think you would be
>>>>>> at 10% of peak or something right off the bat at these sizes. Barry, is that right?
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>> Anway, not sure how to proceed but I thought I would share.
>>>>>> Maybe ask the Kokkos guys if the have looked at Crusher.
>>>>>> Mark
>>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>>>>> <jac_out_001_kokkos_Crusher_6_8_gpuawarempi.txt>
>>>> <jac_out_001_kokkos_Crusher_5_8_notpl.txt><jac_out_001_kokkos_Crusher_6_8_notpl.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220123/5e6b9675/attachment-0001.html>
