[petsc-dev] Kokkos/Crusher perforance
    Barry Smith
    bsmith at petsc.dev
    Sun Jan 23 18:12:50 CST 2022
 You have debugging turned on on crusher but not permutter
> On Jan 23, 2022, at 6:37 PM, Mark Adams <mfadams at lbl.gov> wrote:
> * Perlmutter is roughly 5x faster than Crusher on the one node 2M eq test. (small)
> This is with 8 processes.
> * The next largest version of this test, 16M eq total and 8 processes, fails in memory allocation in the mat-mult setup in the Kokkos Mat.
> * If I try to run with 64 processes on Perlmutter I get this error in initialization. These nodes have 160 Gb of memory.
> (I assume this is related to these large memory requirements from loading packages, etc....)
> Thanks,
> Mark
> + srun -n64 -N1 --cpu-bind=cores --ntasks-per-core=1 ../ex13 -dm_plex_box_faces 4,4,4 -petscpartitioner_simple_process_grid 4,4,4 -dm_plex_box_upper 1,1,1 -petscpartitioner_simple_node_grid 1,1,1 -dm_refine 6 -dm_view -pc_type jacobi -log
> _view -ksp_view -use_gpu_aware_mpi false -dm_mat_type aijkokkos -dm_vec_type kokkos -log_trace
> + tee jac_out_001_kokkos_Perlmutter_6_8.txt
> [48]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [48]PETSC ERROR: GPU error
> [48]PETSC ERROR: cuda error 2 (cudaErrorMemoryAllocation) : out of memory
> [48]PETSC ERROR: See https://petsc.org/release/faq/ <https://petsc.org/release/faq/> for trouble shooting.
> [48]PETSC ERROR: Petsc Development GIT revision: v3.16.3-683-gbc458ed4d8  GIT Date: 2022-01-22 12:18:02 -0600
> [48]PETSC ERROR: /global/u2/m/madams/petsc/src/snes/tests/data/../ex13 on a arch-perlmutter-opt-gcc-kokkos-cuda named nid001424 by madams Sun Jan 23 15:19:56 2022
> [48]PETSC ERROR: Configure options --CFLAGS="   -g -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4" --CXXFLAGS=" -g -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4" --CUDAFLAGS="-g -Xcompiler -rdynamic -DLANDAU_DIM=2 -DLAN
> DAU_MAX_SPECIES=10 -DLANDAU_MAX_Q=4" --with-cc=cc --with-cxx=CC --with-fc=ftn --LDFLAGS=-lmpifort_gnu_91 --with-cudac=/global/common/software/nersc/cos1.3/cuda/11.3.0/bin/nvcc --COPTFLAGS="   -O3" --CXXOPTFLAGS=" -O3" --FOPTFLAGS="   -O3"
>  --with-debugging=0 --download-metis --download-parmetis --with-cuda=1 --with-cuda-arch=80 --with-mpiexec=srun --with-batch=0 --download-p4est=1 --with-zlib=1 --download-kokkos --download-kokkos-kernels --with-kokkos-kernels-tpl=0 --with-
> make-np=8 PETSC_ARCH=arch-perlmutter-opt-gcc-kokkos-cuda
> [48]PETSC ERROR: #1 initialize() at /global/u2/m/madams/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:72
> [48]PETSC ERROR: #2 initialize() at /global/u2/m/madams/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:343
> [48]PETSC ERROR: #3 PetscDeviceInitializeTypeFromOptions_Private() at /global/u2/m/madams/petsc/src/sys/objects/device/interface/device.cxx:319
> [48]PETSC ERROR: #4 PetscDeviceInitializeFromOptions_Internal() at /global/u2/m/madams/petsc/src/sys/objects/device/interface/device.cxx:449
> [48]PETSC ERROR: #5 PetscInitialize_Common() at /global/u2/m/madams/petsc/src/sys/objects/pinit.c:963
> [48]PETSC ERROR: #6 PetscInitialize() at /global/u2/m/madams/petsc/src/sys/objects/pinit.c:1238
> On Sun, Jan 23, 2022 at 8:58 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> On Sat, Jan 22, 2022 at 6:22 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>    I cleaned up Mark's last run and put it in a fixed-width font. I realize this may be too difficult but it would be great to have identical runs to compare with on Summit.
> I was planning on running this on Perlmutter today, as well as some sanity checks like all GPUs are being used. I'll try PetscDeviceView.
> Junchao modified the timers and all GPU > CPU now, but he seemed to move the timers more outside and Barry wants them tight on the "kernel".
> I think Junchao is going to work on that so I will hold off.
> (I removed the the Kokkos wait stuff and seemed to run a little faster but I am not sure how deterministic the timers are, and I did a test with GAMG and it was fine.)
>    As Jed noted Scatter takes a long time but the pack and unpack take no time? Is this not timed if using Kokkos?
> --- Event Stage 2: KSP Solve only
> MatMult              400 1.0 8.8003e+00 1.1 1.06e+11 1.0 2.2e+04 8.5e+04 0.0e+00  2 55 61 54  0  70 91100100   95,058   132,242      0 0.00e+00    0 0.00e+00 100
> VecScatterBegin      400 1.0 1.3391e+00 2.6 0.00e+00 0.0 2.2e+04 8.5e+04 0.0e+00  0  0 61 54  0   7  0100100        0         0      0 0.00e+00    0 0.00e+00  0
> VecScatterEnd        400 1.0 1.3240e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   9  0  0  0        0         0      0 0.00e+00    0 0.00e+00  0
> SFPack               400 1.0 1.8276e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0        0         0      0 0.00e+00    0 0.00e+00  0
> SFUnpack             400 1.0 6.2653e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0        0         0      0 0.00e+00    0 0.00e+00  0
> KSPSolve               2 1.0 1.2540e+01 1.0 1.17e+11 1.0 2.2e+04 8.5e+04 1.2e+03  3 60 61 54 60 100100100      73,592   116,796      0 0.00e+00    0 0.00e+00 100
> VecTDot              802 1.0 1.3551e+00 1.2 3.36e+09 1.0 0.0e+00 0.0e+00 8.0e+02  0  2  0  0 40  10  3  0      19,627    52,599      0 0.00e+00    0 0.00e+00 100
> VecNorm              402 1.0 9.0151e-01 2.2 1.69e+09 1.0 0.0e+00 0.0e+00 4.0e+02  0  1  0  0 20   5  1  0  0   14,788   125,477      0 0.00e+00    0 0.00e+00 100
> VecAXPY              800 1.0 8.2617e-01 1.0 3.36e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   7  3  0  0   32,112    61,644      0 0.00e+00    0 0.00e+00 100
> VecAYPX              398 1.0 8.1525e-01 1.6 1.67e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   5  1  0  0   16,190    20,689      0 0.00e+00    0 0.00e+00 100
> VecPointwiseMult     402 1.0 3.5694e-01 1.0 8.43e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   3  1  0  0   18,675    38,633      0 0.00e+00    0 0.00e+00 100
>> On Jan 22, 2022, at 12:40 PM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> And I have a new MR with if you want to see what I've done so far.
> <jac_out_001_kokkos_Crusher_6_1_notpl.txt><jac_out_001_kokkos_Perlmutter_6_1.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220123/24a0e3c0/attachment.html>
