[petsc-dev] Kokkos/Crusher perforance
    Junchao Zhang
    junchao.zhang at gmail.com
    Sat Jan 22 21:00:21 CST 2022
On Sat, Jan 22, 2022 at 5:00 PM Barry Smith <bsmith at petsc.dev> wrote:
>   The GPU flop rate (when 100 percent flops on the GPU) should always be
> higher than the overall flop rate (the previous column). For large problems
> they should be similar, for small problems the GPU one may be much higher.
>   If the CPU one is higher (when 100 percent flops on the GPU) something
> must be wrong with the logging. I looked at the code for the two cases and
> didn't see anything obvious.
>   Junchao and Jacob,
>       I think some of the timing code in the Kokkos interface is wrong.
>     *  The PetscLogGpuTimeBegin/End should be inside the viewer access
> code not outside it. (The GPU time is an attempt to best time the kernels,
> not other processing around the use of the kernels, that other stuff is
> captured in the general LogEventBegin/End.
Good point
>     *  The use of WaitForKokkos() is confusing and seems inconsistent.
I need to have a look. Until now, I have not paid much attention to kokkos
profiling.
>              -For example it is used in VecTDot_SeqKokkos() which I would
> think has a barrier anyways because it puts a scalar result into update?
>              -Plus PetscLogGpuTimeBegin/End is suppose to already have
> suitable system (that Hong added) to ensure the kernel is complete; reading
> the manual page and looking at Jacobs cupmcontext.hpp it seems to be there
> so I don't think WaitForKokkos() is needed in most places (or is Kokkos
> asynchronous and needs this for correctness?)
> But these won't explain the strange result of overall flop rate being
> higher than GPU flop rate.
>   Barry
> On Jan 22, 2022, at 11:44 AM, Mark Adams <mfadams at lbl.gov> wrote:
> I am getting some funny timings and I'm trying to figure it out.
> I figure the gPU flop rates are bit higher because the timers are inside
> of the CPU timers, but *some are a lot bigger or inverted*
> --- Event Stage 2: KSP Solve only
> MatMult              400 1.0 1.0094e+01 1.2 1.07e+11 1.0 3.7e+05 6.1e+04
> 0.0e+00  2 55 62 54  0  68 91100100  0 671849   857147      0 0.00e+00    0
> 0.00e+00 100
> MatView                2 1.0 4.5257e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> KSPSolve               2 1.0 1.4591e+01 1.1 1.18e+11 1.0 3.7e+05 6.1e+04
> 1.2e+03  2 60 62 54 60 100100100100100 512399   804048      0 0.00e+00    0
> 0.00e+00 100
> SFPack               400 1.0 2.4545e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> SFUnpack             400 1.0 9.4637e-05 1.7 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> VecTDot              802 1.0 3.0577e+00 2.1 3.36e+09 1.0 0.0e+00 0.0e+00
> 8.0e+02  0  2  0  0 40  13  3  0  0 67 *69996   488328*      0 0.00e+00
>  0 0.00e+00 100
> VecNorm              402 1.0 1.9597e+00 3.4 1.69e+09 1.0 0.0e+00 0.0e+00
> 4.0e+02  0  1  0  0 20   6  1  0  0 33 54744   571507      0 0.00e+00    0
> 0.00e+00 100
> VecCopy                4 1.0 1.7143e-0228.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> VecSet                 4 1.0 3.8051e-0316.9 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> VecAXPY              800 1.0 8.6160e-0113.6 3.36e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  2  0  0  0   6  3  0  0  0 *247787   448304*      0 0.00e+00
>    0 0.00e+00 100
> VecAYPX              398 1.0 1.6831e+0031.1 1.67e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   5  1  0  0  0 63107   77030      0 0.00e+00    0
> 0.00e+00 100
> VecPointwiseMult     402 1.0 3.8729e-01 9.3 8.43e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   2  1  0  0  0 138502   262413      0 0.00e+00    0
> 0.00e+00 100
> VecScatterBegin      400 1.0 1.1947e+0035.1 0.00e+00 0.0 3.7e+05 6.1e+04
> 0.0e+00  0  0 62 54  0   5  0100100  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> VecScatterEnd        400 1.0 6.2969e+00 8.8 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0  10  0  0  0  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> PCApply              402 1.0 3.8758e-01 9.3 8.43e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   2  1  0  0  0 138396   262413      0 0.00e+00    0
> 0.00e+00 100
> On Sat, Jan 22, 2022 at 11:10 AM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> On Sat, Jan 22, 2022 at 10:04 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> Logging GPU flops should be inside of PetscLogGpuTimeBegin()/End()
>>> right?
>> No, PetscLogGpuTime() does not know the flops of the caller.
>>> On Fri, Jan 21, 2022 at 9:47 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>   Mark,
>>>>   Fix the logging before you run more. It will help with seeing the
>>>> true disparity between the MatMult and the vector ops.
>>>> On Jan 21, 2022, at 9:37 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> Here is one with 2M / GPU. Getting better.
>>>> On Fri, Jan 21, 2022 at 9:17 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>    Matt is correct, vectors are way too small.
>>>>>    BTW: Now would be a good time to run some of the Report I
>>>>> benchmarks on Crusher to get a feel for the kernel launch times and
>>>>> performance on VecOps.
>>>>>    Also Report 2.
>>>>>   Barry
>>>>> On Jan 21, 2022, at 7:58 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>> On Fri, Jan 21, 2022 at 6:41 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> I am looking at performance of a CG/Jacobi solve on a 3D Q2 Laplacian
>>>>>> (ex13) on one Crusher node (8 GPUs on 4 GPU sockets, MI250X or is it
>>>>>> MI200?).
>>>>>> This is with a 16M equation problem. GPU-aware MPI and non GPU-aware
>>>>>> MPI are similar (mat-vec is a little faster w/o, the total is about the
>>>>>> same, call it noise)
>>>>>> I found that MatMult was about 3x faster using 8 cores/GPU, that is
>>>>>> all 64 cores on the node, then when using 1 core/GPU. With the same size
>>>>>> problem of course.
>>>>>> I was thinking MatMult should be faster with just one MPI process. Oh
>>>>>> well, worry about that later.
>>>>>> The bigger problem, and I have observed this to some extent with the
>>>>>> Landau TS/SNES/GPU-solver on the V/A100s, is that the vector operations are
>>>>>> expensive or crazy expensive.
>>>>>> You can see (attached) and the times here that the solve is dominated
>>>>>> by not-mat-vec:
>>>>>> Event                Count      Time (sec)     Flop
>>>>>>            --- Global ---  --- Stage ----  *Total   GPU *   -
>>>>>> CpuToGpu -   - GpuToCpu - GPU
>>>>>>                    Max Ratio  Max     Ratio   Max  Ratio  Mess
>>>>>> AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R *Mflop/s Mflop/s*
>>>>>> Count   Size   Count   Size  %F
>>>>>> 17:15 main=
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tests/data$ grep "MatMult
>>>>>>              400" jac_out_00*5_8_gpuawaremp*
>>>>>> MatMult              400 1.0 *1.2507e+00* 1.3 1.34e+10 1.1 3.7e+05
>>>>>> 1.6e+04 0.0e+00  1 55 62 54  0  27 91100100  0 *668874       0*
>>>>>>  0 0.00e+00    0 0.00e+00 100
>>>>>> 17:15 main=
>>>>>> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tests/data$ grep "KSPSolve
>>>>>>               2" jac_out_001*_5_8_gpuawaremp*
>>>>>> KSPSolve               2 1.0 *4.4173e+00* 1.0 1.48e+10 1.1 3.7e+05
>>>>>> 1.6e+04 1.2e+03  4 60 62 54 61 100100100100100 *208923   1094405*
>>>>>> Notes about flop counters here,
>>>>>> * that MatMult flops are not logged as GPU flops but something is
>>>>>> logged nonetheless.
>>>>>> * The GPU flop rate is 5x the total flop rate  in KSPSolve :\
>>>>>> * I think these nodes have an FP64 peak flop rate of 200 Tflops, so
>>>>>> we are at < 1%.
>>>>> This looks complicated, so just a single remark:
>>>>> My understanding of the benchmarking of vector ops led by Hannah was
>>>>> that you needed to be much
>>>>> bigger than 16M to hit peak. I need to get the tech report, but on 8
>>>>> GPUs I would think you would be
>>>>> at 10% of peak or something right off the bat at these sizes. Barry,
>>>>> is that right?
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Anway, not sure how to proceed but I thought I would share.
>>>>>> Maybe ask the Kokkos guys if the have looked at Crusher.
>>>>>> Mark
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> <jac_out_001_kokkos_Crusher_6_8_gpuawarempi.txt>
>>>> <jac_out_001_kokkos_Crusher_5_8_notpl.txt>
> <jac_out_001_kokkos_Crusher_6_8_notpl.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220122/c67408d0/attachment-0001.html>
