[petsc-dev] Kokkos/Crusher perforance
    Barry Smith
    bsmith at petsc.dev
    Sat Jan 22 17:21:53 CST 2022
   I cleaned up Mark's last run and put it in a fixed-width font. I realize this may be too difficult but it would be great to have identical runs to compare with on Summit.
   As Jed noted Scatter takes a long time but the pack and unpack take no time? Is this not timed if using Kokkos?
--- Event Stage 2: KSP Solve only
MatMult              400 1.0 8.8003e+00 1.1 1.06e+11 1.0 2.2e+04 8.5e+04 0.0e+00  2 55 61 54  0  70 91100100   95,058   132,242      0 0.00e+00    0 0.00e+00 100
VecScatterBegin      400 1.0 1.3391e+00 2.6 0.00e+00 0.0 2.2e+04 8.5e+04 0.0e+00  0  0 61 54  0   7  0100100        0         0      0 0.00e+00    0 0.00e+00  0
VecScatterEnd        400 1.0 1.3240e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   9  0  0  0        0         0      0 0.00e+00    0 0.00e+00  0
SFPack               400 1.0 1.8276e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0        0         0      0 0.00e+00    0 0.00e+00  0
SFUnpack             400 1.0 6.2653e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0        0         0      0 0.00e+00    0 0.00e+00  0
KSPSolve               2 1.0 1.2540e+01 1.0 1.17e+11 1.0 2.2e+04 8.5e+04 1.2e+03  3 60 61 54 60 100100100      73,592   116,796      0 0.00e+00    0 0.00e+00 100
VecTDot              802 1.0 1.3551e+00 1.2 3.36e+09 1.0 0.0e+00 0.0e+00 8.0e+02  0  2  0  0 40  10  3  0      19,627    52,599      0 0.00e+00    0 0.00e+00 100
VecNorm              402 1.0 9.0151e-01 2.2 1.69e+09 1.0 0.0e+00 0.0e+00 4.0e+02  0  1  0  0 20   5  1  0  0   14,788   125,477      0 0.00e+00    0 0.00e+00 100
VecAXPY              800 1.0 8.2617e-01 1.0 3.36e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   7  3  0  0   32,112    61,644      0 0.00e+00    0 0.00e+00 100
VecAYPX              398 1.0 8.1525e-01 1.6 1.67e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   5  1  0  0   16,190    20,689      0 0.00e+00    0 0.00e+00 100
VecPointwiseMult     402 1.0 3.5694e-01 1.0 8.43e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   3  1  0  0   18,675    38,633      0 0.00e+00    0 0.00e+00 100
> On Jan 22, 2022, at 12:40 PM, Mark Adams <mfadams at lbl.gov> wrote:
> And I have a new MR with if you want to see what I've done so far.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220122/482f12aa/attachment.html>
