[petsc-dev] Kokkos/Crusher perforance
Barry Smith
bsmith at petsc.dev
Sat Jan 22 12:55:57 CST 2022
I suggested years ago that -log_view automatically print useful information about the GPU setup (when GPUs are used) but everyone seemed comfortable with the lack of information so no one improved it. I think for a small number of GPUs -log_view should just print details and for a larger number print some statistics (how many physical ones etc). Currently, it does not even print how many are used. I think requiring another option to get this basic information is a mistake, we already print a ton of background with -log_view it is just sad no background on the GPU usage.
> On Jan 22, 2022, at 1:06 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
>>>>>> VecPointwiseMult 402 1.0 2.9605e-01 3.6 1.05e+08 1.0 0.0e+00
>>> 0.0e+00
>>>>> 0.0e+00 0 0 0 0 0 5 1 0 0 0 22515 70608 0 0.00e+00
>>> 0
>>>>> 0.00e+00 100
>>>>>> VecScatterBegin 400 1.0 1.6791e-01 6.0 0.00e+00 0.0 3.7e+05
>>> 1.6e+04
>>>>> 0.0e+00 0 0 62 54 0 2 0100100 0 0 0 0 0.00e+00
>>> 0
>>>>> 0.00e+00 0
>>>>>> VecScatterEnd 400 1.0 1.0057e+00 7.0 0.00e+00 0.0 0.0e+00
>>> 0.0e+00
>>>>> 0.0e+00 0 0 0 0 0 5 0 0 0 0 0 0 0 0.00e+00
>>> 0
>>>>> 0.00e+00 0
>>>>>> PCApply 402 1.0 2.9638e-01 3.6 1.05e+08 1.0 0.0e+00
>>> 0.0e+00
>>>>> 0.0e+00 0 0 0 0 0 5 1 0 0 0 22490 70608 0 0.00e+00
>>> 0
>>>>> 0.00e+00 100
>>>>> Most of the MatMult time is attributed to VecScatterEnd here. Can you
>>>>> share a run of the same total problem size on 8 ranks (one rank per
>>> GPU)?
>>>> attached. I ran out of memory with the same size problem so this is the
>>>> 262K / GPU version.
>>> How was this launched? Is it possible all 8 ranks were using the same GPU?
>>> (Perf is that bad.)
>> srun -n8 -N1 *--ntasks-per-gpu=1* --gpu-bind=closest ../ex13
>> -dm_plex_box_faces 2,2,2 -petscpartitioner_simple_process_grid 2,2,2
>> -dm_plex_box_upper 1,1,1 -petscpartitioner_simple_node_grid 1,1,1
>> -dm_refine 6 -dm_view -dm_mat_type aijkokkos -dm_vec_type kokkos -pc_type
>> jacobi -log_view -ksp_view -use_gpu_aware_mpi true
> I'm still worried because the results are so unreasonable. We should add an option like -view_gpu_busid that prints this information per rank.
> https://code.ornl.gov/olcf/hello_jobstep/-/blob/master/hello_jobstep.cpp
> A single-process/single-GPU comparison would also be a useful point of comparison.
