[petsc-dev] Kokkos/Crusher perforance
Mark Adams mfadams at lbl.gov
Sat Jan 22 11:36:23 CST 2022
On Sat, Jan 22, 2022 at 12:29 PM Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> >> > VecPointwiseMult     402 1.0 2.9605e-01 3.6 1.05e+08 1.0 0.0e+00
> 0.0e+00
> >> 0.0e+00  0  0  0  0  0   5  1  0  0  0 22515   70608      0 0.00e+00
> 0
> >> 0.00e+00 100
> >> > VecScatterBegin      400 1.0 1.6791e-01 6.0 0.00e+00 0.0 3.7e+05
> 1.6e+04
> >> 0.0e+00  0  0 62 54  0   2  0100100  0     0       0      0 0.00e+00
> 0
> >> 0.00e+00  0
> >> > VecScatterEnd        400 1.0 1.0057e+00 7.0 0.00e+00 0.0 0.0e+00
> 0.0e+00
> >> 0.0e+00  0  0  0  0  0   5  0  0  0  0     0       0      0 0.00e+00
> 0
> >> 0.00e+00  0
> >> > PCApply              402 1.0 2.9638e-01 3.6 1.05e+08 1.0 0.0e+00
> 0.0e+00
> >> 0.0e+00  0  0  0  0  0   5  1  0  0  0 22490   70608      0 0.00e+00
> 0
> >> 0.00e+00 100
> >> Most of the MatMult time is attributed to VecScatterEnd here. Can you
> >> share a run of the same total problem size on 8 ranks (one rank per
> GPU)?
> > attached. I ran out of memory with the same size problem so this is the
> > 262K / GPU version.
> How was this launched? Is it possible all 8 ranks were using the same GPU?
> (Perf is that bad.)
srun -n8 -N1 *--ntasks-per-gpu=1* --gpu-bind=closest ../ex13
-dm_plex_box_faces 2,2,2 -petscpartitioner_simple_process_grid 2,2,2
-dm_plex_box_upper 1,1,1 -petscpartitioner_simple_node_grid 1,1,1
-dm_refine 6 -dm_view -dm_mat_type aijkokkos -dm_vec_type kokkos -pc_type
jacobi -log_view -ksp_view -use_gpu_aware_mpi true
+ a large .petscrc file
> >> From the other log file (10x bigger problem)
> You had attached two files and the difference seemed to be that the second
> was 10x more dofs/rank.
I am refining a cube so it goes by 8x.
jac_out_001_kokkos_Crusher_6_1_notpl.txt
number of nodes
number of refinements
number of process per GPU
> > --- Event Stage 2: KSP Solve only
> > MatMult              400 1.0 8.8003e+00 1.1 1.06e+11 1.0 2.2e+04 8.5e+04
> 0.0e+00  2 55 61 54  0  70 91100100  0 95058   132242      0 0.00e+00    0
> 0.00e+00 100
> > MatView                2 1.0 1.1643e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> > KSPSolve               2 1.0 1.2540e+01 1.0 1.17e+11 1.0 2.2e+04 8.5e+04
> 1.2e+03  3 60 61 54 60 100100100100100 73592   116796      0 0.00e+00    0
> 0.00e+00 100
> > SFPack               400 1.0 1.8276e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> > SFUnpack             400 1.0 6.2653e-05 1.6 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> > VecTDot              802 1.0 1.3551e+00 1.2 3.36e+09 1.0 0.0e+00 0.0e+00
> 8.0e+02  0  2  0  0 40  10  3  0  0 67 19627   52599      0 0.00e+00    0
> 0.00e+00 100
> > VecNorm              402 1.0 9.0151e-01 2.2 1.69e+09 1.0 0.0e+00 0.0e+00
> 4.0e+02  0  1  0  0 20   5  1  0  0 33 14788   125477      0 0.00e+00    0
> 0.00e+00 100
> > VecCopy                4 1.0 7.3905e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> > VecSet                 4 1.0 3.1814e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00  0
> > VecAXPY              800 1.0 8.2617e-01 1.0 3.36e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  2  0  0  0   7  3  0  0  0 32112   61644      0 0.00e+00    0
> 0.00e+00 100
> > VecAYPX              398 1.0 8.1525e-01 1.6 1.67e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  1  0  0  0   5  1  0  0  0 16190   20689      0 0.00e+00    0
> 0.00e+00 100
> > VecPointwiseMult     402 1.0 3.5694e-01 1.0 8.43e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   3  1  0  0  0 18675   38633      0 0.00e+00    0
> 0.00e+00 100
> > VecScatterBegin      400 1.0 1.3391e+00 2.6 0.00e+00 0.0 2.2e+04 8.5e+04
> 0.0e+00  0  0 61 54  0   7  0100100  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> > VecScatterEnd        400 1.0 1.3240e+00 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   9  0  0  0  0     0       0      0 0.00e+00    0
> 0.00e+00  0
> > PCApply              402 1.0 3.5712e-01 1.0 8.43e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00  0  0  0  0  0   3  1  0  0  0 18665   38633      0 0.00e+00    0
> 0.00e+00 100
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220122/87eec1e0/attachment-0001.html>
