[petsc-dev] Kokkos/Crusher perforance
    Mark Adams
    mfadams at lbl.gov
    Sat Jan 22 06:52:42 CST 2022
On Fri, Jan 21, 2022 at 9:55 PM Barry Smith <bsmith at petsc.dev> wrote:
> Interesting, Is this with all native Kokkos kernels or do some kokkos
> kernels use rocm?
Ah, good question. I often run with tpl=0 but I did not specify here on
Crusher. In looking at the log files I see
-I/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-crusher/externalpackages/git.kokkos-kernels/src/impl/tpls
Here is a run with tpls turned off. These tpl includes are gone.
It looks pretty much the same. A little slower but that could be noise.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220122/82f17595/attachment-0001.html>
DM Object: box 64 MPI processes
  type: plex
box in 3 dimensions:
  Number of 0-cells per rank: 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937 35937
  Number of 1-cells per rank: 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544 104544
  Number of 2-cells per rank: 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376 101376
  Number of 3-cells per rank: 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768 32768
Labels:
  celltype: 4 strata with value/size (0 (35937), 1 (104544), 4 (101376), 7 (32768))
  depth: 4 strata with value/size (0 (35937), 1 (104544), 2 (101376), 3 (32768))
  marker: 1 strata with value/size (1 (12474))
  Face Sets: 3 strata with value/size (1 (3969), 3 (3969), 6 (3969))
  Linear solve did not converge due to DIVERGED_ITS iterations 200
KSP Object: 64 MPI processes
  type: cg
  maximum iterations=200, initial guess is zero
  tolerances:  relative=1e-12, absolute=1e-50, divergence=10000.
  left preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object: 64 MPI processes
  type: jacobi
    type DIAGONAL
  linear system matrix = precond matrix:
  Mat Object: 64 MPI processes
    type: mpiaijkokkos
    rows=16581375, cols=16581375
    total: nonzeros=1045678375, allocated nonzeros=1045678375
    total number of mallocs used during MatSetValues calls=0
      not using I-node (on process 0) routines
  type: cg
  type: jacobi
    type DIAGONAL
    type: mpiaijkokkos
  type: cg
  type: jacobi
    type DIAGONAL
    type: mpiaijkokkos
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
/gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tests/data/../ex13 on a arch-olcf-crusher named crusher001 with 64 processors, by adams Fri Jan 21 23:48:31 2022
Using Petsc Development GIT revision: v3.16.3-665-g1012189b9a  GIT Date: 2022-01-21 16:28:20 +0000
                         Max       Max/Min     Avg       Total
Time (sec):           7.919e+01     1.000   7.918e+01
Objects:              2.088e+03     1.164   1.852e+03
Flop:                 2.448e+10     1.074   2.393e+10  1.532e+12
Flop/sec:             3.091e+08     1.074   3.023e+08  1.935e+10
MPI Messages:         1.651e+04     3.673   9.388e+03  6.009e+05
MPI Message Lengths:  2.278e+08     2.093   1.788e+04  1.074e+10
MPI Reductions:       1.988e+03     1.000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flop
                            and VecAXPY() for complex vectors of length N --> 8N flop
Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total    Count   %Total     Avg         %Total    Count   %Total
 0:      Main Stage: 7.4289e+01  93.8%  6.0889e+11  39.8%  2.265e+05  37.7%  2.175e+04       45.8%  7.630e+02  38.4%
 1:         PCSetUp: 3.1604e-02   0.0%  0.0000e+00   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 2:  KSP Solve only: 4.8576e+00   6.1%  9.2287e+11  60.2%  3.744e+05  62.3%  1.554e+04       54.2%  1.206e+03  60.7%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flop: Max - maximum over all processors
                  Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   AvgLen: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flop in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
   GPU Mflop/s: 10e-6 * (sum of flop on GPU over all processors)/(max GPU time over all processors)
   CpuToGpu Count: total number of CPU to GPU copies per processor
   CpuToGpu Size (Mbytes): 10e-6 * (total size of CPU to GPU copies per processor)
   GpuToCpu Count: total number of GPU to CPU copies per processor
   GpuToCpu Size (Mbytes): 10e-6 * (total size of GPU to CPU copies per processor)
   GPU %F: percent flops on GPU in this event
Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total   GPU    - CpuToGpu -   - GpuToCpu - GPU
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s Mflop/s Count   Size   Count   Size  %F
--- Event Stage 0: Main Stage
PetscBarrier           5 1.0 2.0665e-01 1.1 0.00e+00 0.0 1.1e+04 8.0e+02 1.8e+01  0  0  2  0  1   0  0  5  0  2     0       0      0 0.00e+00    0 0.00e+00  0
BuildTwoSided         40 1.0 2.6017e+0010.5 0.00e+00 0.0 9.9e+03 4.0e+00 4.0e+01  3  0  2  0  2   3  0  4  0  5     0       0      0 0.00e+00    0 0.00e+00  0
BuildTwoSidedF         6 1.0 2.5318e+0010.9 0.00e+00 0.0 2.2e+03 4.0e+05 6.0e+00  3  0  0  8  0   3  0  1 18  1     0       0      0 0.00e+00    0 0.00e+00  0
MatMult            1210960.2 1.2055e+00 2.1 6.71e+09 1.1 1.9e+05 1.5e+04 2.0e+00  1 27 32 27  0   1 69 85 59  0 346972       0      1 1.14e-01    0 0.00e+00 100
MatAssemblyBegin      43 1.0 2.6856e+00 6.9 0.00e+00 0.0 2.2e+03 4.0e+05 6.0e+00  3  0  0  8  0   3  0  1 18  1     0       0      0 0.00e+00    0 0.00e+00  0
MatAssemblyEnd        43 1.0 4.6070e-01 2.5 1.18e+06 0.0 0.0e+00 0.0e+00 9.0e+00  0  0  0  0  0   1  0  0  0  1   120       0      0 0.00e+00    0 0.00e+00  0
MatZeroEntries         3 1.0 5.4884e-04 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
MatView                1 1.0 2.5364e-03 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
KSPSetUp               1 1.0 2.4612e-03 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
KSPSolve               1 1.0 3.1074e+00 1.0 7.39e+09 1.1 1.9e+05 1.5e+04 6.0e+02  4 30 31 27 30   4 76 83 59 79 148494   1022941      1 1.14e-01    0 0.00e+00 100
SNESSolve              1 1.0 2.7026e+01 1.0 8.56e+09 1.1 1.9e+05 1.8e+04 6.1e+02 34 35 32 31 31  36 88 84 69 80 19853   1022661      3 2.36e+00    2 3.62e+00 86
SNESSetUp              1 1.0 7.6240e+00 1.0 0.00e+00 0.0 5.3e+03 1.9e+05 1.8e+01 10  0  1  9  1  10  0  2 21  2     0       0      0 0.00e+00    0 0.00e+00  0
SNESFunctionEval       2 1.0 6.2213e+00 1.1 7.96e+08 1.0 1.7e+03 1.3e+04 3.0e+00  8  3  0  0  0   8  8  1  0  0  8149   21036      3 4.32e+00    2 3.62e+00  0
SNESJacobianEval       2 1.0 5.7439e+01 1.0 1.52e+09 1.0 1.7e+03 5.4e+05 2.0e+00 72  6  0  8  0  77 16  1 18  0  1683       0      0 0.00e+00    2 3.62e+00  0
DMCreateInterp         1 1.0 1.0837e-02 1.0 8.29e+04 1.0 1.1e+03 8.0e+02 1.6e+01  0  0  0  0  1   0  0  0  0  2   490       0      0 0.00e+00    0 0.00e+00  0
DMCreateMat            1 1.0 7.6222e+00 1.0 0.00e+00 0.0 5.3e+03 1.9e+05 1.8e+01 10  0  1  9  1  10  0  2 21  2     0       0      0 0.00e+00    0 0.00e+00  0
Mesh Partition         1 1.0 2.5208e-02 1.0 0.00e+00 0.0 3.2e+02 1.1e+02 8.0e+00  0  0  0  0  0   0  0  0  0  1     0       0      0 0.00e+00    0 0.00e+00  0
Mesh Migration         1 1.0 9.2974e-03 1.0 0.00e+00 0.0 1.8e+03 8.3e+01 2.9e+01  0  0  0  0  1   0  0  1  0  4     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexPartSelf         1 1.0 8.4227e-0493.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexPartLblInv       1 1.0 1.0979e-03 4.5 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexPartLblSF        1 1.0 4.5747e-03 1.7 0.00e+00 0.0 1.3e+02 5.6e+01 1.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexPartStrtSF       1 1.0 1.8253e-02 1.7 0.00e+00 0.0 6.3e+01 2.2e+02 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexPointSF          1 1.0 1.9011e-03 1.1 0.00e+00 0.0 1.3e+02 2.7e+02 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexInterp          19 1.0 1.0434e-03 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexDistribute       1 1.0 3.6410e-02 1.0 0.00e+00 0.0 2.2e+03 9.7e+01 3.7e+01  0  0  0  0  2   0  0  1  0  5     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexDistCones        1 1.0 1.1016e-03 1.2 0.00e+00 0.0 3.8e+02 1.4e+02 2.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexDistLabels       1 1.0 1.5538e-03 1.0 0.00e+00 0.0 9.0e+02 6.6e+01 2.4e+01  0  0  0  0  1   0  0  0  0  3     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexDistField        1 1.0 6.3540e-03 1.0 0.00e+00 0.0 4.4e+02 5.9e+01 2.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexStratify        33 1.0 1.4687e-02 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 7.0e+00  0  0  0  0  0   0  0  0  0  1     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexSymmetrize      33 1.0 1.9498e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexPrealloc         1 1.0 7.6108e+00 1.0 0.00e+00 0.0 5.3e+03 1.9e+05 1.6e+01 10  0  1  9  1  10  0  2 21  2     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexResidualFE       2 1.0 3.7908e+00 1.1 7.87e+08 1.0 0.0e+00 0.0e+00 0.0e+00  5  3  0  0  0   5  8  0  0  0 13285       0      0 0.00e+00    0 0.00e+00  0
DMPlexJacobianFE       2 1.0 5.7067e+01 1.0 1.51e+09 1.0 1.1e+03 8.0e+05 2.0e+00 72  6  0  8  0  77 16  0 18  0  1689       0      0 0.00e+00    0 0.00e+00  0
DMPlexInterpFE         1 1.0 1.0649e-02 1.0 8.29e+04 1.0 1.1e+03 8.0e+02 1.6e+01  0  0  0  0  1   0  0  0  0  2   498       0      0 0.00e+00    0 0.00e+00  0
SFSetGraph            43 1.0 1.0816e-03 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
SFSetUp               34 1.0 1.5032e-01 1.5 0.00e+00 0.0 1.8e+04 2.1e+04 3.4e+01  0  0  3  3  2   0  0  8  7  4     0       0      0 0.00e+00    0 0.00e+00  0
SFBcastBegin          65 1.0 2.2730e+00145.4 0.00e+00 0.0 1.3e+04 1.3e+04 0.0e+00  2  0  2  2  0   2  0  6  3  0     0       0      1 1.68e-01    4 7.24e+00  0
SFBcastEnd            65 1.0 1.7421e+0062.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0       0      0 6.24e-03    0 0.00e+00  0
SFReduceBegin         16 1.0 1.9556e-0184.2 5.24e+05 1.0 4.2e+03 8.5e+04 0.0e+00  0  0  1  3  0   0  0  2  7  0   170       0      2 4.15e+00    0 0.00e+00 100
SFReduceEnd           16 1.0 9.7152e-0132.7 2.50e+04 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     1       0      0 0.00e+00    0 0.00e+00 100
SFFetchOpBegin         2 1.0 3.1814e-03104.2 0.00e+00 0.0 5.6e+02 2.0e+05 0.0e+00  0  0  0  1  0   0  0  0  2  0     0       0      0 0.00e+00    0 0.00e+00  0
SFFetchOpEnd           2 1.0 2.8296e-02 3.6 0.00e+00 0.0 5.6e+02 2.0e+05 0.0e+00  0  0  0  1  0   0  0  0  2  0     0       0      0 0.00e+00    0 0.00e+00  0
SFCreateEmbed          8 1.0 1.0733e-0172.8 0.00e+00 0.0 2.0e+03 7.0e+02 0.0e+00  0  0  0  0  0   0  0  1  0  0     0       0      0 0.00e+00    0 0.00e+00  0
SFDistSection          9 1.0 1.0892e-02 2.3 0.00e+00 0.0 4.1e+03 5.9e+03 1.1e+01  0  0  1  0  1   0  0  2  0  1     0       0      0 0.00e+00    0 0.00e+00  0
SFSectionSF           16 1.0 5.2589e-02 2.2 0.00e+00 0.0 5.8e+03 2.0e+04 1.6e+01  0  0  1  1  1   0  0  3  2  2     0       0      0 0.00e+00    0 0.00e+00  0
SFRemoteOff            7 1.0 1.2178e-0124.0 0.00e+00 0.0 6.1e+03 1.3e+03 4.0e+00  0  0  1  0  0   0  0  3  0  1     0       0      0 0.00e+00    0 0.00e+00  0
SFPack               290 1.0 7.5146e-01155.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0       0      2 1.51e-01    0 0.00e+00  0
SFUnpack             292 1.0 1.9789e-0158.9 5.49e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   174       0      0 6.24e-03    0 0.00e+00 100
VecTDot              401 1.0 1.4788e+00 1.8 2.10e+08 1.0 0.0e+00 0.0e+00 4.0e+02  2  1  0  0 20   2  2  0  0 53  8992   109803      0 0.00e+00    0 0.00e+00 100
VecNorm              201 1.0 7.4026e-01 2.4 1.05e+08 1.0 0.0e+00 0.0e+00 2.0e+02  0  0  0  0 10   0  1  0  0 26  9004   127483      0 0.00e+00    0 0.00e+00 100
VecCopy                2 1.0 1.4854e-0310.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
VecSet                54 1.0 8.7686e-03 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
VecAXPY              400 1.0 3.9120e-0120.9 2.10e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  2  0  0  0 33909   73190      0 0.00e+00    0 0.00e+00 100
VecAYPX              199 1.0 1.3597e-01 6.9 1.04e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 48535   138139      0 0.00e+00    0 0.00e+00 100
VecPointwiseMult     201 1.0 1.4152e-0110.2 5.27e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 23550   69371      0 0.00e+00    0 0.00e+00 100
VecScatterBegin      201 1.0 6.5846e-0117.0 0.00e+00 0.0 1.9e+05 1.5e+04 2.0e+00  0  0 32 27  0   0  0 85 59  0     0       0      1 1.14e-01    0 0.00e+00  0
VecScatterEnd        201 1.0 6.6968e-01 9.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DualSpaceSetUp         2 1.0 5.2698e-03 1.2 1.80e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    22       0      0 0.00e+00    0 0.00e+00  0
FESetUp                2 1.0 3.3009e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
PCSetUp                1 1.0 9.6290e-06 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
PCApply              201 1.0 1.9920e-01 2.9 5.27e+07 1.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  1  0  0  0 16731   47897      0 0.00e+00    0 0.00e+00 100
--- Event Stage 1: PCSetUp
PCSetUp                1 1.0 3.6638e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0 100  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
--- Event Stage 2: KSP Solve only
MatMult              400 1.0 1.3375e+00 1.3 1.34e+10 1.1 3.7e+05 1.6e+04 0.0e+00  1 55 62 54  0  24 91100100  0 625440       0      0 0.00e+00    0 0.00e+00 100
MatView                2 1.0 4.3457e-03 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
KSPSolve               2 1.0 4.9810e+00 1.0 1.48e+10 1.1 3.7e+05 1.6e+04 1.2e+03  6 60 62 54 61 100100100100100 185277   1102535      0 0.00e+00    0 0.00e+00 100
SFPack               400 1.0 2.6830e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
SFUnpack             400 1.0 2.2198e-04 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
VecTDot              802 1.0 2.0418e+00 1.2 4.20e+08 1.0 0.0e+00 0.0e+00 8.0e+02  2  2  0  0 40  38  3  0  0 67 13026   112538      0 0.00e+00    0 0.00e+00 100
VecNorm              402 1.0 1.4270e+00 2.4 2.11e+08 1.0 0.0e+00 0.0e+00 4.0e+02  1  1  0  0 20  14  1  0  0 33  9343   134367      0 0.00e+00    0 0.00e+00 100
VecCopy                4 1.0 5.9396e-0324.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
VecSet                 4 1.0 3.7188e-0313.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
VecAXPY              800 1.0 7.4812e-0121.6 4.19e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0  14  3  0  0  0 35463   73999      0 0.00e+00    0 0.00e+00 100
VecAYPX              398 1.0 2.5369e-01 6.5 2.09e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   4  1  0  0  0 52028   142028      0 0.00e+00    0 0.00e+00 100
VecPointwiseMult     402 1.0 2.9605e-01 3.6 1.05e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   5  1  0  0  0 22515   70608      0 0.00e+00    0 0.00e+00 100
VecScatterBegin      400 1.0 1.6791e-01 6.0 0.00e+00 0.0 3.7e+05 1.6e+04 0.0e+00  0  0 62 54  0   2  0100100  0     0       0      0 0.00e+00    0 0.00e+00  0
VecScatterEnd        400 1.0 1.0057e+00 7.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   5  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
PCApply              402 1.0 2.9638e-01 3.6 1.05e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   5  1  0  0  0 22490   70608      0 0.00e+00    0 0.00e+00 100
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
           Container    32             32        18432     0.
                SNES     1              1         1540     0.
              DMSNES     1              1          688     0.
       Krylov Solver     1              1         1664     0.
     DMKSP interface     1              1          656     0.
              Matrix    75             75    195551600     0.
    Distributed Mesh    70             70      7840024     0.
            DM Label   172            172       108704     0.
          Quadrature   148            148        87616     0.
      Mesh Transform     5              5         3780     0.
           Index Set   801            801      1598436     0.
   IS L to G Mapping     2              2      1102568     0.
             Section   249            249       177288     0.
   Star Forest Graph   173            173       188592     0.
     Discrete System   116            116       111364     0.
           Weak Form   117            117        72072     0.
    GraphPartitioner    33             33        22704     0.
              Vector    54             54     19591688     0.
        Linear Space     5              5         3416     0.
          Dual Space    26             26        24336     0.
            FE Space     2              2         1576     0.
              Viewer     2              1          840     0.
      Preconditioner     1              1          872     0.
       Field over DM     1              1          704     0.
Average time to get PetscTime(): 5.31e-08
Average time for MPI_Barrier(): 4.0698e-06
Average time for zero size MPI_Send(): 9.52547e-06
#PETSc Option Table entries:
-benchmark_it 2
-dm_distribute
-dm_mat_type aijkokkos
-dm_plex_box_faces 4,4,4
-dm_plex_box_lower 0,0,0
-dm_plex_box_upper 1,1,1
-dm_plex_dim 3
-dm_plex_simplex 0
-dm_refine 5
-dm_vec_type kokkos
-dm_view
-ksp_converged_reason
-ksp_max_it 200
-ksp_norm_type unpreconditioned
-ksp_rtol 1.e-12
-ksp_type cg
-ksp_view
-log_view
-mg_levels_esteig_ksp_max_it 10
-mg_levels_esteig_ksp_type cg
-mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05
-mg_levels_ksp_type chebyshev
-mg_levels_pc_type jacobi
-options_left
-pc_gamg_coarse_eq_limit 100
-pc_gamg_coarse_grid_layout_type compact
-pc_gamg_esteig_ksp_max_it 10
-pc_gamg_esteig_ksp_type cg
-pc_gamg_process_eq_limit 400
-pc_gamg_repartition false
-pc_gamg_reuse_interpolation true
-pc_gamg_square_graph 0
-pc_gamg_threshold -0.01
-pc_type jacobi
-petscpartitioner_simple_node_grid 1,1,1
-petscpartitioner_simple_process_grid 4,4,4
-petscpartitioner_type simple
-potential_petscspace_degree 2
-snes_max_it 1
-snes_rtol 1.e-8
-snes_type ksponly
-use_gpu_aware_mpi true
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: --with-cc=cc --with-cxx=CC --with-fc=ftn --with-fortran-bindings=0 LIBS="-L/opt/cray/pe/mpich/8.1.12/gtl/lib -lmpi_gtl_hsa" --with-debugging=0 --with-mpiexec="srun -p batch -N 1 -A csc314_crusher -t 00:10:00" --with-hip --with-hipc=hipcc --download-hypre --download-hypre-configure-arguments=--enable-unified-memory --with-hip-arch=gfx90a --download-kokkos --download-kokkos-kernels --with-kokkos-kernels-tpl=0 PETSC_ARCH=arch-olcf-crusher
Libraries compiled on 2022-01-22 03:06:22 on login2
Machine characteristics: Linux-5.3.18-59.16_11.0.39-cray_shasta_c-x86_64-with-glibc2.3.4
Using PETSc directory: /gpfs/alpine/csc314/scratch/adams/petsc
Using PETSc arch: arch-olcf-crusher
Using C compiler: cc  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -Qunused-arguments -fvisibility=hidden -g -O3
Using Fortran compiler: ftn  -fPIC
Using include paths: -I/gpfs/alpine/csc314/scratch/adams/petsc/include -I/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-crusher/include -I/opt/rocm-4.5.0/include
Using C linker: cc
Using Fortran linker: ftn
Using libraries: -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-crusher/lib -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-crusher/lib -lpetsc -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-crusher/lib -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-olcf-crusher/lib -Wl,-rpath,/opt/rocm-4.5.0/lib -L/opt/rocm-4.5.0/lib -Wl,-rpath,/opt/cray/pe/mpich/8.1.12/gtl/lib -L/opt/cray/pe/mpich/8.1.12/gtl/lib -Wl,-rpath,/opt/cray/pe/gcc/8.1.0/snos/lib64 -L/opt/cray/pe/gcc/8.1.0/snos/lib64 -Wl,-rpath,/opt/cray/pe/libsci/21.08.1.2/CRAY/9.0/x86_64/lib -L/opt/cray/pe/libsci/21.08.1.2/CRAY/9.0/x86_64/lib -Wl,-rpath,/opt/cray/pe/mpich/8.1.12/ofi/cray/10.0/lib -L/opt/cray/pe/mpich/8.1.12/ofi/cray/10.0/lib -Wl,-rpath,/opt/cray/pe/dsmml/0.2.2/dsmml/lib -L/opt/cray/pe/dsmml/0.2.2/dsmml/lib -Wl,-rpath,/opt/cray/pe/pmi/6.0.16/lib -L/opt/cray/pe/pmi/6.0.16/lib -Wl,-rpath,/opt/cray/pe/cce/13.0.0/cce/x86_64/lib -L/opt/cray/pe/cce/13.0.0/cce/x86_64/lib -Wl,-rpath,/opt/cray/xpmem/2.3.2-2.2_1.16__g9ea452c.shasta/lib64 -L/opt/cray/xpmem/2.3.2-2.2_1.16__g9ea452c.shasta/lib64 -Wl,-rpath,/opt/cray/pe/cce/13.0.0/cce-clang/x86_64/lib/clang/13.0.0/lib/linux -L/opt/cray/pe/cce/13.0.0/cce-clang/x86_64/lib/clang/13.0.0/lib/linux -Wl,-rpath,/opt/cray/pe/gcc/8.1.0/snos/lib/gcc/x86_64-suse-linux/8.1.0 -L/opt/cray/pe/gcc/8.1.0/snos/lib/gcc/x86_64-suse-linux/8.1.0 -Wl,-rpath,/opt/cray/pe/cce/13.0.0/binutils/x86_64/x86_64-unknown-linux-gnu/lib -L/opt/cray/pe/cce/13.0.0/binutils/x86_64/x86_64-unknown-linux-gnu/lib -Wl,-rpath,/opt/cray/pe/cce/13.0.0/binutils/x86_64/x86_64-pc-linux-gnu/..//x86_64-unknown-linux-gnu/lib -L/opt/cray/pe/cce/13.0.0/binutils/x86_64/x86_64-pc-linux-gnu/..//x86_64-unknown-linux-gnu/lib -lHYPRE -lkokkoskernels -lkokkoscontainers -lkokkoscore -lhipsparse -lhipblas -lrocsparse -lrocsolver -lrocblas -lrocrand -lamdhip64 -ldl -lmpi_gtl_hsa -lmpifort_cray -lmpi_cray -ldsmml -lpmi -lpmi2 -lxpmem -lstdc++ -lpgas-shmem -lquadmath -lcrayacc_amdgpu -lopenacc -lmodules -lfi -lcraymath -lf -lu -lcsup -lgfortran -lpthread -lgcc_eh -lm -lclang_rt.craypgo-x86_64 -lclang_rt.builtins-x86_64 -lquadmath -ldl -lmpi_gtl_hsa
-benchmark_it 2
-dm_distribute
-dm_plex_dim 3
-dm_plex_simplex 0
-dm_refine 5
-dm_vec_type kokkos
-dm_view
-ksp_max_it 200
-ksp_rtol 1.e-12
-ksp_type cg
-ksp_view
-log_view
-options_left
-pc_type jacobi
-snes_max_it 1
-snes_rtol 1.e-8
-snes_type ksponly
WARNING! There are options you set that were not used!
WARNING! could be spelling mistake, etc!
There are 14 unused database options. They are:
Option left: name:-mg_levels_esteig_ksp_max_it value: 10
Option left: name:-mg_levels_esteig_ksp_type value: cg
Option left: name:-mg_levels_ksp_chebyshev_esteig value: 0,0.05,0,1.05
Option left: name:-mg_levels_ksp_type value: chebyshev
Option left: name:-mg_levels_pc_type value: jacobi
Option left: name:-pc_gamg_coarse_eq_limit value: 100
Option left: name:-pc_gamg_coarse_grid_layout_type value: compact
Option left: name:-pc_gamg_esteig_ksp_max_it value: 10
Option left: name:-pc_gamg_esteig_ksp_type value: cg
Option left: name:-pc_gamg_process_eq_limit value: 400
Option left: name:-pc_gamg_repartition value: false
Option left: name:-pc_gamg_reuse_interpolation value: true
Option left: name:-pc_gamg_square_graph value: 0
Option left: name:-pc_gamg_threshold value: -0.01
  type: plex
  Number of 0-cells per rank: 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625 274625
  Number of 1-cells per rank: 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200 811200
  Number of 2-cells per rank: 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720 798720
  Number of 3-cells per rank: 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144 262144
Labels:
  celltype: 4 strata with value/size (0 (274625), 1 (811200), 4 (798720), 7 (262144))
  depth: 4 strata with value/size (0 (274625), 1 (811200), 2 (798720), 3 (262144))
  marker: 1 strata with value/size (1 (49530))
  Face Sets: 3 strata with value/size (1 (16129), 3 (16129), 6 (16129))
  type: cg
  type: jacobi
    type DIAGONAL
    type: mpiaijkokkos
    rows=133432831, cols=133432831
    total: nonzeros=8477185319, allocated nonzeros=8477185319
  type: cg
  type: jacobi
    type DIAGONAL
    type: mpiaijkokkos
  type: cg
  type: jacobi
    type DIAGONAL
    type: mpiaijkokkos
/gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tests/data/../ex13 on a arch-olcf-crusher named crusher001 with 64 processors, by adams Fri Jan 21 23:57:45 2022
Time (sec):           5.510e+02     1.000   5.510e+02
Objects:              2.158e+03     1.163   1.919e+03
Flop:                 1.958e+11     1.036   1.936e+11  1.239e+13
Flop/sec:             3.554e+08     1.036   3.514e+08  2.249e+10
MPI Messages:         1.656e+04     3.672   9.423e+03  6.031e+05
MPI Message Lengths:  8.942e+08     2.047   7.055e+04  4.255e+10
MPI Reductions:       1.991e+03     1.000
 0:      Main Stage: 5.3734e+02  97.5%  4.9150e+12  39.7%  2.287e+05  37.9%  8.566e+04       46.0%  7.660e+02  38.5%
 1:         PCSetUp: 2.4256e-01   0.0%  0.0000e+00   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 2:  KSP Solve only: 1.3391e+01   2.4%  7.4764e+12  60.3%  3.744e+05  62.1%  6.133e+04       54.0%  1.206e+03  60.6%
Phase summary info:
PetscBarrier           6 1.0 1.5685e+00 1.0 0.00e+00 0.0 1.4e+04 2.6e+03 2.1e+01  0  0  2  0  1   0  0  6  0  3     0       0      0 0.00e+00    0 0.00e+00  0
BuildTwoSided         42 1.0 5.7396e+00 6.2 0.00e+00 0.0 1.0e+04 4.0e+00 4.2e+01  1  0  2  0  2   1  0  5  0  5     0       0      0 0.00e+00    0 0.00e+00  0
BuildTwoSidedF         6 1.0 5.6774e+00 6.4 0.00e+00 0.0 2.2e+03 1.6e+06 6.0e+00  1  0  0  8  0   1  0  1 18  1     0       0      0 0.00e+00    0 0.00e+00  0
MatMult            48589241.7 5.0181e+00 1.2 5.37e+10 1.0 1.9e+05 6.0e+04 2.0e+00  1 27 32 27  0   1 69 84 59  0 675743       0      1 4.48e-01    0 0.00e+00 100
MatAssemblyBegin      43 1.0 6.3288e+00 4.1 0.00e+00 0.0 2.2e+03 1.6e+06 6.0e+00  1  0  0  8  0   1  0  1 18  1     0       0      0 0.00e+00    0 0.00e+00  0
MatAssemblyEnd        43 1.0 2.0404e+00 2.2 4.71e+06 0.0 0.0e+00 0.0e+00 9.0e+00  0  0  0  0  0   0  0  0  0  1   110       0      0 0.00e+00    0 0.00e+00  0
MatZeroEntries         3 1.0 5.1707e-03 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
MatView                1 1.0 2.6576e-03 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
KSPSetUp               1 1.0 1.8340e-02 4.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
KSPSolve               1 1.0 7.6610e+00 1.1 5.91e+10 1.0 1.9e+05 6.1e+04 6.0e+02  1 30 31 27 30   1 76 83 59 79 487953   2891172      1 4.48e-01    0 0.00e+00 100
SNESSolve              1 1.0 1.8233e+02 1.0 6.85e+10 1.0 1.9e+05 7.0e+04 6.1e+02 33 35 32 31 31  34 88 84 68 80 23790   2890722      3 1.83e+01    2 2.92e+01 86
SNESSetUp              1 1.0 5.8476e+01 1.0 0.00e+00 0.0 5.3e+03 7.7e+05 1.8e+01 11  0  1 10  1  11  0  2 21  2     0       0      0 0.00e+00    0 0.00e+00  0
SNESFunctionEval       2 1.0 3.3646e+01 1.1 6.33e+09 1.0 1.7e+03 5.1e+04 3.0e+00  6  3  0  0  0   6  8  1  0  0 12010   152293      3 3.46e+01    2 2.92e+01  0
SNESJacobianEval       2 1.0 4.3741e+02 1.0 1.21e+10 1.0 1.7e+03 2.2e+06 2.0e+00 79  6  0  9  0  81 16  1 19  0  1766       0      0 0.00e+00    2 2.92e+01  0
DMCreateInterp         1 1.0 2.9766e-03 1.1 8.29e+04 1.0 1.1e+03 8.0e+02 1.6e+01  0  0  0  0  1   0  0  0  0  2  1783       0      0 0.00e+00    0 0.00e+00  0
DMCreateMat            1 1.0 5.8460e+01 1.0 0.00e+00 0.0 5.3e+03 7.7e+05 1.8e+01 11  0  1 10  1  11  0  2 21  2     0       0      0 0.00e+00    0 0.00e+00  0
Mesh Partition         1 1.0 3.4383e-03 1.4 0.00e+00 0.0 3.2e+02 1.1e+02 8.0e+00  0  0  0  0  0   0  0  0  0  1     0       0      0 0.00e+00    0 0.00e+00  0
Mesh Migration         1 1.0 8.5458e-03 1.0 0.00e+00 0.0 1.8e+03 8.3e+01 2.9e+01  0  0  0  0  1   0  0  1  0  4     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexPartSelf         1 1.0 8.8702e-04132.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexPartLblInv       1 1.0 1.2961e-03 4.9 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexPartLblSF        1 1.0 4.1699e-04 2.9 0.00e+00 0.0 1.3e+02 5.6e+01 1.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexPartStrtSF       1 1.0 3.4840e-04 1.6 0.00e+00 0.0 6.3e+01 2.2e+02 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexPointSF          1 1.0 1.6911e-03 1.1 0.00e+00 0.0 1.3e+02 2.7e+02 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexInterp          19 1.0 1.3618e-03 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexDistribute       1 1.0 1.3544e-02 1.1 0.00e+00 0.0 2.2e+03 9.7e+01 3.7e+01  0  0  0  0  2   0  0  1  0  5     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexDistCones        1 1.0 6.2767e-04 1.0 0.00e+00 0.0 3.8e+02 1.4e+02 2.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexDistLabels       1 1.0 1.4716e-03 1.0 0.00e+00 0.0 9.0e+02 6.6e+01 2.4e+01  0  0  0  0  1   0  0  0  0  3     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexDistField        1 1.0 6.0844e-03 1.0 0.00e+00 0.0 4.4e+02 5.9e+01 2.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexStratify        34 1.0 1.1206e-01 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00  0  0  0  0  0   0  0  0  0  1     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexSymmetrize      34 1.0 1.7210e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexPrealloc         1 1.0 5.8338e+01 1.0 0.00e+00 0.0 5.3e+03 7.7e+05 1.6e+01 11  0  1 10  1  11  0  2 21  2     0       0      0 0.00e+00    0 0.00e+00  0
DMPlexResidualFE       2 1.0 3.1420e+01 1.1 6.29e+09 1.0 0.0e+00 0.0e+00 0.0e+00  5  3  0  0  0   5  8  0  0  0 12818       0      0 0.00e+00    0 0.00e+00  0
DMPlexJacobianFE       2 1.0 4.3674e+02 1.0 1.21e+10 1.0 1.1e+03 3.2e+06 2.0e+00 79  6  0  8  0  81 16  0 18  0  1767       0      0 0.00e+00    0 0.00e+00  0
DMPlexInterpFE         1 1.0 2.8815e-03 1.1 8.29e+04 1.0 1.1e+03 8.0e+02 1.6e+01  0  0  0  0  1   0  0  0  0  2  1842       0      0 0.00e+00    0 0.00e+00  0
SFSetGraph            46 1.0 9.6775e-03 3.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
SFSetUp               36 1.0 7.7526e-01 1.3 0.00e+00 0.0 1.9e+04 7.8e+04 3.6e+01  0  0  3  3  2   0  0  8  7  5     0       0      0 0.00e+00    0 0.00e+00  0
SFBcastBegin          68 1.0 1.3188e+0062.9 0.00e+00 0.0 1.4e+04 4.8e+04 0.0e+00  0  0  2  2  0   0  0  6  3  0     0       0      1 1.20e+00    4 5.83e+01  0
SFBcastEnd            68 1.0 3.1105e+0013.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 2.48e-02    0 0.00e+00  0
SFReduceBegin         17 1.0 2.0149e-0121.8 4.19e+06 1.0 4.5e+03 3.2e+05 0.0e+00  0  0  1  3  0   0  0  2  7  0  1324       0      2 3.34e+01    0 0.00e+00 100
SFReduceEnd           17 1.0 4.1475e+0023.7 9.91e+04 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     1       0      0 0.00e+00    0 0.00e+00 100
SFFetchOpBegin         2 1.0 1.7922e-02255.6 0.00e+00 0.0 5.6e+02 8.2e+05 0.0e+00  0  0  0  1  0   0  0  0  2  0     0       0      0 0.00e+00    0 0.00e+00  0
SFFetchOpEnd           2 1.0 1.2086e-01 2.7 0.00e+00 0.0 5.6e+02 8.2e+05 0.0e+00  0  0  0  1  0   0  0  0  2  0     0       0      0 0.00e+00    0 0.00e+00  0
SFCreateEmbed          9 1.0 4.7403e-0130.7 0.00e+00 0.0 2.3e+03 2.4e+03 0.0e+00  0  0  0  0  0   0  0  1  0  0     0       0      0 0.00e+00    0 0.00e+00  0
SFDistSection          9 1.0 6.8144e-02 2.9 0.00e+00 0.0 4.1e+03 2.3e+04 1.1e+01  0  0  1  0  1   0  0  2  0  1     0       0      0 0.00e+00    0 0.00e+00  0
SFSectionSF           17 1.0 2.5789e-01 2.9 0.00e+00 0.0 6.4e+03 7.4e+04 1.7e+01  0  0  1  1  1   0  0  3  2  2     0       0      0 0.00e+00    0 0.00e+00  0
SFRemoteOff            8 1.0 5.0936e-0113.1 0.00e+00 0.0 7.3e+03 4.3e+03 5.0e+00  0  0  1  0  0   0  0  3  0  1     0       0      0 0.00e+00    0 0.00e+00  0
SFPack               294 1.0 6.9303e-0124.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      2 5.96e-01    0 0.00e+00  0
SFUnpack             296 1.0 2.1804e-01 9.4 4.29e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1246       0      0 2.48e-02    0 0.00e+00 100
VecTDot              401 1.0 1.4922e+00 1.9 1.68e+09 1.0 0.0e+00 0.0e+00 4.0e+02  0  1  0  0 20   0  2  0  0 52 71714   324873      0 0.00e+00    0 0.00e+00 100
VecNorm              201 1.0 9.2573e-01 3.8 8.43e+08 1.0 0.0e+00 0.0e+00 2.0e+02  0  0  0  0 10   0  1  0  0 26 57943   538637      0 0.00e+00    0 0.00e+00 100
VecCopy                2 1.0 1.6417e-03 8.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
VecSet                55 1.0 3.4422e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
VecAXPY              400 1.0 4.3082e-0112.1 1.68e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  2  0  0  0 247773   439060      0 0.00e+00    0 0.00e+00 100
VecAYPX              199 1.0 9.2046e-0130.5 8.35e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 57695   69274      0 0.00e+00    0 0.00e+00 100
VecPointwiseMult     201 1.0 2.0488e-01 8.9 4.22e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 130904   305411      0 0.00e+00    0 0.00e+00 100
VecScatterBegin      201 1.0 8.3090e-01 4.9 0.00e+00 0.0 1.9e+05 6.0e+04 2.0e+00  0  0 32 27  0   0  0 84 59  0     0       0      1 4.48e-01    0 0.00e+00  0
VecScatterEnd        201 1.0 2.9748e+00 6.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
DualSpaceSetUp         2 1.0 3.8129e-03 1.3 1.80e+03 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    30       0      0 0.00e+00    0 0.00e+00  0
FESetUp                2 1.0 5.1432e-03 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
PCSetUp                1 1.0 1.3717e-05 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
PCApply              201 1.0 5.3934e-01 1.5 4.22e+08 1.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  1  0  0  0 49728   237264      0 0.00e+00    0 0.00e+00 100
PCSetUp                1 1.0 2.7733e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0 100  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
MatMult              400 1.0 9.4001e+00 1.2 1.07e+11 1.0 3.7e+05 6.1e+04 0.0e+00  2 55 62 54  0  65 91100100  0 721451       0      0 0.00e+00    0 0.00e+00 100
MatView                2 1.0 4.4729e-03 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
KSPSolve               2 1.0 1.3945e+01 1.1 1.18e+11 1.0 3.7e+05 6.1e+04 1.2e+03  2 60 62 54 60 100100100100100 536128   2881308      0 0.00e+00    0 0.00e+00 100
SFPack               400 1.0 2.4445e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
SFUnpack             400 1.0 1.2255e-04 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
VecTDot              802 1.0 2.7256e+00 1.9 3.36e+09 1.0 0.0e+00 0.0e+00 8.0e+02  0  2  0  0 40  14  3  0  0 67 78523   335526      0 0.00e+00    0 0.00e+00 100
VecNorm              402 1.0 1.9145e+00 3.7 1.69e+09 1.0 0.0e+00 0.0e+00 4.0e+02  0  1  0  0 20   6  1  0  0 33 56035   533339      0 0.00e+00    0 0.00e+00 100
VecCopy                4 1.0 6.3156e-03 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
VecSet                 4 1.0 3.8228e-0315.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
VecAXPY              800 1.0 9.0587e-0111.1 3.36e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   6  3  0  0  0 235676   444654      0 0.00e+00    0 0.00e+00 100
VecAYPX              398 1.0 1.9393e+0029.6 1.67e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   6  1  0  0  0 54767   65448      0 0.00e+00    0 0.00e+00 100
VecPointwiseMult     402 1.0 3.5580e-01 6.2 8.43e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  1  0  0  0 150758   318605      0 0.00e+00    0 0.00e+00 100
VecScatterBegin      400 1.0 1.3900e+0028.9 0.00e+00 0.0 3.7e+05 6.1e+04 0.0e+00  0  0 62 54  0   7  0100100  0     0       0      0 0.00e+00    0 0.00e+00  0
VecScatterEnd        400 1.0 5.8686e+00 6.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  13  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
PCApply              402 1.0 3.5612e-01 6.1 8.43e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  1  0  0  0 150622   318605      0 0.00e+00    0 0.00e+00 100
           Container    33             33        19008     0.
                SNES     1              1         1540     0.
              DMSNES     1              1          688     0.
              Matrix    76             76   1627827176     0.
    Distributed Mesh    72             72     58971680     0.
            DM Label   180            180       113760     0.
      Mesh Transform     6              6         4536     0.
           Index Set   833            833      4238868     0.
   IS L to G Mapping     2              2      8590824     0.
             Section   256            256       182272     0.
   Star Forest Graph   179            179       195360     0.
     Discrete System   121            121       116164     0.
           Weak Form   122            122        75152     0.
    GraphPartitioner    34             34        23392     0.
              Vector    55             55    157137560     0.
              Viewer     2              1          840     0.
Average time for MPI_Barrier(): 3.631e-06
Average time for zero size MPI_Send(): 1.02498e-05
-benchmark_it 2
-dm_distribute
-dm_plex_dim 3
-dm_plex_simplex 0
-dm_refine 6
-dm_vec_type kokkos
-dm_view
-ksp_max_it 200
-ksp_rtol 1.e-12
-ksp_type cg
-ksp_view
-log_view
-options_left
-pc_type jacobi
-snes_max_it 1
-snes_rtol 1.e-8
-snes_type ksponly
Using C linker: cc
-benchmark_it 2
-dm_distribute
-dm_plex_dim 3
-dm_plex_simplex 0
-dm_refine 6
-dm_vec_type kokkos
-dm_view
-ksp_max_it 200
-ksp_rtol 1.e-12
-ksp_type cg
-ksp_view
-log_view
-options_left
-pc_type jacobi
-snes_max_it 1
-snes_rtol 1.e-8
-snes_type ksponly
