[petsc-dev] Using PETSC with GPUs
Rohan Yadav
rohany at alumni.cmu.edu
Thu Jan 20 16:24:29 CST 2022
Thanks barry, this is what I was looking for. However, it doesn't seem to
be working for me (the reported times are significantly different still
with -log_view on and off). Here is my exact timing code:
double avgTime = 0.0;
PetscLogDouble start, end;
PetscLogGpuTimeBegin();
for (int i = 0; i < warmup; i++) {
MatMult(A, x, y);
PetscLogGpuTimeEnd();
PetscTime(&start);
for (int i = 0; i < niter; i++) {
MatMult(A, x, y);
PetscTime(&end);
auto sec = end - start;
avgTime = double(sec) / double(niter);
I'm measuring the time for a group of MatMult's as you suggested (with some
warmup iterations).
Rohan
On Thu, Jan 20, 2022 at 1:42 PM Barry Smith <bsmith at petsc.dev> wrote:
> Some operations on the GPU are asynchronous, the CPU passes the kernel
> launch to the GPU and then immediately returns ready to do something else
> before the kernel is completed (or even started). Some like VecDot() where
> the result is stored in a CPU memory have to block until the kernel is
> complete and the result copied up to the CPU.
> -log_view forces a the calls to PetscLogGpuTimeEnd() which has (for
> CUDA)
> cerr =
> cudaEventRecord(petsc_gputimer_end,PetscDefaultCudaStream);CHKERRCUDA(cerr);
> cerr = cudaEventSynchronize(petsc_gputimer_end);CHKERRCUDA(cerr);
> cerr =
> cudaEventElapsedTime(>ime,petsc_gputimer_begin,petsc_gputimer_end);CHKERRCUDA(cerr);
> petsc_gtime += (PetscLogDouble)gtime/1000.0; /* convert milliseconds to
> seconds */
> which essentially causes the CPU to wait until the kernel is complete,
> hence your time with -log_view captures the full time to run the kernel.
> So timing with GPUs can be a tricky business (when do you want to block
> and when do you not?) For your loop, you may want to use
> start = now()
> for (int i = 0; i < 10; i++) {
> MatMult(A, x, y);
> end = now()
> print(end - start / 10)
> Now after the loop it will wait until all the multiplies are completely
> done; giving a better view of the time it takes. If you did
> start = now()
> MatMult(A, x, y);
> end = now()
> You would wait a longer time because the CPU could not tell the GPU about
> the second kernel launch until the first kernel is completely done. Hence
> there would be no overlap of GPU computation and CPU kernel launches (which
> take a long time).
> IMHO timing individual operations like a single MatMult() on GPUs only has
> a certain level of usefulness since you slow down the computation (by
> removing the asynchronous nature between the GPU and CPU) in order to get
> accurate times. It is better to time something like a complete line solver,
> nonlinear solve etc and not log at a finer granularity.
> Barry
> On Jan 20, 2022, at 4:07 PM, Rohan Yadav <rohany at alumni.cmu.edu> wrote:
> Another small question -- I'm a little confused around timing GPU codes
> with PETSc. I have a code that looks like:
> start = now()
> MatMult(A, x, y);
> end = now()
> If I run this program with `-vec_type cuda -mat_type aijcusparse`, the
> GPUs are indeed utilized, but the recorded time is very tiny (i imagine
> just tracking the cost of launching cuda kernels). However, if I add
> `-log_view` to the command line arguments, then the resulting time printed
> matches what is recorded by `nvprof`. What is the correct way to benchmark
> PETSc with GPUs without having -log_view turned on?
> Thanks,
> Rohan
> On Sat, Jan 15, 2022 at 7:37 AM Barry Smith <bsmith at petsc.dev> wrote:
>> Oh yes, you are correct for this operation since the handling of
>> different nonzero pattern is not trivial to implement well for the GPU.
>> On Jan 15, 2022, at 1:17 AM, Rohan Yadav <rohany at alumni.cmu.edu> wrote:
>> Scanning the source code for mpiseqaijcusparse confirms my thoughts --
>> when used with DIFFERENT_NONZERO_PATTERN, it falls back to calling
>> MatAXPY_SeqAIJ, copying the data back over to the host.
>> Rohan
>> On Fri, Jan 14, 2022 at 10:16 PM Rohan Yadav <rohany at alumni.cmu.edu>
>> wrote:
>>> ---------- Forwarded message ---------
>>> From: Rohan Yadav <rohany at alumni.cmu.edu>
>>> Date: Fri, Jan 14, 2022 at 10:03 PM
>>> Subject: Re: [petsc-dev] Using PETSC with GPUs
>>> To: Barry Smith <bsmith at petsc.dev>
>>> Ok, I'll try looking with greps like and see what I find.
>>> > My guess why your code is not using the seqaijcusparse is that you
>>> are not setting the type before you call MatLoad() hence it loads with
>>> SeqAIJ. -mat_type does not magically change a type once a matrix has a set
>>> type. I agree our documentation on how to make objects be GPU objects is
>>> horrible now.
>>> I printed out my matrices with the PetscViewer objects and can confirm
>>> that the type is seqaijcusparse. Perhaps for the way I'm using it
>>> (DIFFERENT_NONZERO_PATTERN) the kernel is unsupported? I'm not sure how to
>>> get any more diagnostic info about why the cuda kernel isn't called...
>>> Rohan
>>> On Fri, Jan 14, 2022 at 9:46 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>> This changes rapidly and depends on if the backend is CUDA, HIP,
>>>> Sycl, or Kokkos. The only way to find out definitively is with, for
>>>> example,
>>>> git grep MatMult_ | egrep -i "(cusparse|cublas|cuda)"
>>>> Because of our, unfortunately, earlier naming choices you need to
>>>> kind of know what to grep for, for CUDA it may be cuSparse or cuBLAS
>>>> Not yet merged branches may also have some operations that are still
>>>> being developed.
>>>> horrible now.
>>>> Barry
>>>> On Jan 15, 2022, at 12:31 AM, Rohan Yadav <rohany at alumni.cmu.edu>
>>>> wrote:
>>>> I was wondering if there is a definitive list for what operations are
>>>> and aren't supported for distributed GPU execution. For some operations,
>>>> like `MatMult`, it is clear that MPIAIJCUSPARSE implements MatMult from the
>>>> documentation, but other operations it is unclear, such as MatMatMult.
>>>> Another scenario is the MatAXPY kernel, which supposedly has a
>>>> SeqAIJCUSPARSE implementation, which I take means that it can only execute
>>>> on a single GPU. However, even if I pass -mat_type seqaijcusparse to the
>>>> kernel it doesn't seem to utilize the GPU.
>>>> Rohan
>>>> On Fri, Jan 14, 2022 at 4:05 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>> Just use 1 MPI rank.
>>>>> Event Count Time (sec) Flop
>>>>> --- Global --- --- Stage ---- Total GPU - CpuToGpu - -
>>>>> GpuToCpu - GPU
>>>>> Max Ratio Max Ratio Max Ratio Mess
>>>>> AvgLen Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s Mflop/s Count Size
>>>>> Count Size %F
>>>>> --- Event Stage 0: Main Stage
>>>>> BuildTwoSided 1 1.0 1.8650e-013467.8 0.00e+00 0.0 2.0e+00
>>>>> 4.0e+00 1.0e+00 0 0 3 0 2 0 0 3 0 4 0 0 0
>>>>> 0.00e+00 0 0.00e+00 0
>>>>> MatMult 30 1.0 6.6642e+01 1.0 1.16e+10 1.0 6.4e+01
>>>>> 6.4e+08 1.0e+00 65100 91 93 2 65100 91 93 4 346 0 0
>>>>> 0.00e+00 31 2.65e+04 0
>>>>> From this it is clear the matrix never ended up on the GPU, but the
>>>>> vector did. For each multiply, it is copying the vector from the GPU to the
>>>>> CPU and then doing the MatMult on the CPU. If the MatMult was done on the
>>>>> GPU the file number in the row would be 100% indicating all the flops were
>>>>> done on the GPU and the fifth from the end value of 0 would be some large
>>>>> number, being the flop rate on the GPU.
>>>>> On Jan 14, 2022, at 4:59 PM, Rohan Yadav <rohany at alumni.cmu.edu>
>>>>> wrote:
>>>>> A log_view is attached at the end of the mail.
>>>>> I am running on a large problem size (639 million nonzeros).
>>>>> > * I assume you are assembling the matrix on the CPU. The copy of
>>>>> data to the GPU takes time and you really should be creating the matrix on
>>>>> the GPU
>>>>> How do I do this? I'm loading the matrix in from a file, but I'm
>>>>> running the computation several times (and with a warmup), so I would
>>>>> expect that the data is copied onto the GPU the first time. My (cpu) code
>>>>> to do this is here:
>>>>> https://github.com/rohany/taco/blob/5c0a4f4419ba392838590ce24e0043f632409e7b/petsc/benchmark.cpp#L68
>>>>> Log view:
>>>>> ---------------------------------------------- PETSc Performance
>>>>> Summary: ----------------------------------------------
>>>>> ./bin/benchmark on a named lassen75 with 2 processors, by yadav2 Fri
>>>>> Jan 14 13:54:09 2022
>>>>> Using Petsc Release Version 3.16.3, unknown
>>>>> Max Max/Min Avg Total
>>>>> Time (sec): 1.026e+02 1.000 1.026e+02
>>>>> Objects: 1.200e+01 1.000 1.200e+01
>>>>> Flop: 1.156e+10 1.009 1.151e+10 2.303e+10
>>>>> Flop/sec: 1.127e+08 1.009 1.122e+08 2.245e+08
>>>>> MPI Messages: 3.500e+01 1.000 3.500e+01 7.000e+01
>>>>> MPI Message Lengths: 2.210e+10 1.000 6.313e+08 4.419e+10
>>>>> MPI Reductions: 4.100e+01 1.000
>>>>> Flop counting convention: 1 flop = 1 real number operation of type
>>>>> (multiply/divide/add/subtract)
>>>>> e.g., VecAXPY() for real vectors of length
>>>>> N --> 2N flop
>>>>> and VecAXPY() for complex vectors of
>>>>> length N --> 8N flop
>>>>> Summary of Stages: ----- Time ------ ----- Flop ------ ---
>>>>> Messages --- -- Message Lengths -- -- Reductions --
>>>>> Avg %Total Avg %Total Count
>>>>> %Total Avg %Total Count %Total
>>>>> 0: Main Stage: 1.0257e+02 100.0% 2.3025e+10 100.0% 7.000e+01
>>>>> 100.0% 6.313e+08 100.0% 2.300e+01 56.1%
>>>>> See the 'Profiling' chapter of the users' manual for details on
>>>>> interpreting output.
>>>>> Phase summary info:
>>>>> Count: number of times phase was executed
>>>>> Time and Flop: Max - maximum over all processors
>>>>> Ratio - ratio of maximum to minimum over all
>>>>> processors
>>>>> Mess: number of messages sent
>>>>> AvgLen: average message length (bytes)
>>>>> Reduct: number of global reductions
>>>>> Global: entire computation
>>>>> Stage: stages of a computation. Set stages with PetscLogStagePush()
>>>>> and PetscLogStagePop().
>>>>> %T - percent time in this phase %F - percent flop in
>>>>> this phase
>>>>> %M - percent messages in this phase %L - percent message
>>>>> lengths in this phase
>>>>> %R - percent reductions in this phase
>>>>> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time
>>>>> GPU Mflop/s: 10e-6 * (sum of flop on GPU over all processors)/(max
>>>>> GPU time over all processors)
>>>>> CpuToGpu Count: total number of CPU to GPU copies per processor
>>>>> CpuToGpu Size (Mbytes): 10e-6 * (total size of CPU to GPU copies
>>>>> per processor)
>>>>> GpuToCpu Count: total number of GPU to CPU copies per processor
>>>>> GpuToCpu Size (Mbytes): 10e-6 * (total size of GPU to CPU copies
>>>>> per processor)
>>>>> GPU %F: percent flops on GPU in this event
>>>>> GpuToCpu - GPU
>>>>> Count Size %F
>>>>> MatAssemblyBegin 1 1.0 3.1100e-07 1.1 0.00e+00 0.0 0.0e+00
>>>>> 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 0
>>>>> MatAssemblyEnd 1 1.0 1.9798e+01 1.0 0.00e+00 0.0 0.0e+00
>>>>> 0.0e+00 4.0e+00 19 0 0 0 10 19 0 0 0 17 0 0 0
>>>>> MatLoad 1 1.0 3.5519e+01 1.0 0.00e+00 0.0 6.0e+00
>>>>> 5.4e+08 1.6e+01 35 0 9 7 39 35 0 9 7 70 0 0 0
>>>>> VecSet 5 1.0 5.8959e-02 1.1 0.00e+00 0.0 0.0e+00
>>>>> VecScatterBegin 30 1.0 5.4085e+00 1.0 0.00e+00 0.0 6.4e+01
>>>>> 6.4e+08 1.0e+00 5 0 91 93 2 5 0 91 93 4 0 0 0
>>>>> VecScatterEnd 30 1.0 9.2544e+00 2.5 0.00e+00 0.0 0.0e+00
>>>>> 0.0e+00 0.0e+00 6 0 0 0 0 6 0 0 0 0 0 0 0
>>>>> VecCUDACopyFrom 31 1.0 4.0174e-01 1.0 0.00e+00 0.0 0.0e+00
>>>>> SFSetGraph 1 1.0 4.4912e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>> SFSetUp 1 1.0 5.2595e+00 1.0 0.00e+00 0.0 4.0e+00
>>>>> 1.7e+08 1.0e+00 5 0 6 2 2 5 0 6 2 4 0 0 0
>>>>> SFPack 30 1.0 3.4021e-02 1.0 0.00e+00 0.0 0.0e+00
>>>>> SFUnpack 30 1.0 1.9222e-05 1.5 0.00e+00 0.0 0.0e+00
>>>>> Memory usage is given in bytes:
>>>>> Object Type Creations Destructions Memory Descendants'
>>>>> Mem.
>>>>> Reports information only for process 0.
>>>>> Matrix 3 0 0 0.
>>>>> Viewer 2 0 0 0.
>>>>> Vector 4 1 1792 0.
>>>>> Index Set 2 2 335250404 0.
>>>>> Star Forest Graph 1 0 0 0.
>>>>> Average time to get PetscTime(): 3.77e-08
>>>>> Average time for MPI_Barrier(): 8.754e-07
>>>>> Average time for zero size MPI_Send(): 2.6755e-06
>>>>> #PETSc Option Table entries:
>>>>> -log_view
>>>>> -matrix /p/gpfs1/yadav2/tensors//petsc/kmer_V1r.petsc
>>>>> -n 20
>>>>> -vec_type cuda
>>>>> -warmup 10
>>>>> #End of PETSc Option Table entries
>>>>> Compiled without FORTRAN kernels
>>>>> Compiled with full precision matrices (default)
>>>>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>>>>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>>>>> Configure options: --download-c2html=0 --download-hwloc=0
>>>>> --download-sowing=0 --prefix=./petsc-install/ --with-64-bit-indices=0
>>>>> --with-blaslapack-lib="/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib/liblapack.so
>>>>> /usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib/libblas.so"
>>>>> --with-cc=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigcc
>>>>> --with-clanguage=C --with-cxx-dialect=C++17
>>>>> --with-cxx=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpig++
>>>>> --with-cuda=1 --with-debugging=0
>>>>> --with-fc=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigfortran
>>>>> --with-fftw=0
>>>>> --with-hdf5-dir=/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4
>>>>> --with-hdf5=1 --with-mumps=0 --with-precision=double --with-scalapack=0
>>>>> --with-scalar-type=real --with-shared-libraries=1 --with-ssl=0
>>>>> --with-suitesparse=0 --with-trilinos=0 --with-valgrind=0 --with-x=0
>>>>> --with-zlib-include=/usr/include --with-zlib-lib=/usr/lib64/libz.so
>>>>> --with-zlib=1 CFLAGS="-g -DNoChange" COPTFLAGS="-O3" CXXFLAGS="-O3"
>>>>> CXXOPTFLAGS="-O3" FFLAGS=-g CUDAFLAGS=-std=c++17 FOPTFLAGS=
>>>>> PETSC_ARCH=arch-linux-c-opt
>>>>> Libraries compiled on 2022-01-14 20:56:04 on lassen99
>>>>> Machine characteristics:
>>>>> Linux-4.14.0-115.21.2.1chaos.ch6a.ppc64le-ppc64le-with-redhat-7.6-Maipo
>>>>> Using PETSc directory: /g/g15/yadav2/taco/petsc/petsc/petsc-install
>>>>> Using PETSc arch:
>>>>> Using C compiler:
>>>>> -g -DNoChange -fPIC "-O3"
>>>>> Using Fortran compiler:
>>>>> -g -fPIC
>>>>> Using include paths:
>>>>> -I/g/g15/yadav2/taco/petsc/petsc/petsc-install/include
>>>>> -I/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/include
>>>>> -I/usr/include -I/usr/tce/packages/cuda/cuda-11.1.0/include
>>>>> Using C linker:
>>>>> Using Fortran linker:
>>>>> Using libraries:
>>>>> -Wl,-rpath,/g/g15/yadav2/taco/petsc/petsc/petsc-install/lib
>>>>> -L/g/g15/yadav2/taco/petsc/petsc/petsc-install/lib -lpetsc
>>>>> -Wl,-rpath,/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib
>>>>> -L/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib
>>>>> -Wl,-rpath,/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/lib
>>>>> -L/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/lib
>>>>> -Wl,-rpath,/usr/tce/packages/cuda/cuda-11.1.0/lib64
>>>>> -L/usr/tce/packages/cuda/cuda-11.1.0/lib64
>>>>> -Wl,-rpath,/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/lib
>>>>> -L/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/lib
>>>>> -Wl,-rpath,/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib/gcc/ppc64le-redhat-linux/8
>>>>> -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib/gcc/ppc64le-redhat-linux/8
>>>>> -Wl,-rpath,/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib64
>>>>> -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib64
>>>>> -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib -llapack -lblas -lhdf5_hl
>>>>> -lhdf5 -lm /usr/lib64/libz.so -lcuda -lcudart -lcufft -lcublas -lcusparse
>>>>> -lcusolver -lcurand -lstdc++ -ldl -lmpiprofilesupport -lmpi_ibm_usempi
>>>>> -lmpi_ibm_mpifh -lmpi_ibm -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
>>>>> -lpthread -lquadmath -lstdc++ -ldl
>>>>> On Fri, Jan 14, 2022 at 1:43 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> There are a few things:
>>>>>> * GPU have higher latencies and so you basically need a large
>>>>>> enough problem to get GPU speedup
>>>>>> * I assume you are assembling the matrix on the CPU. The copy of data
>>>>>> to the GPU takes time and you really should be creating the matrix on the
>>>>>> GPU
>>>>>> * I agree with Barry, Roughly 1M / GPU is around where you start
>>>>>> seeing a win but this depends on a lot of things.
>>>>>> * There are startup costs, like the CPU-GPU copy. It is best to run
>>>>>> one mat-vec, or whatever, push a new stage and then run the benchmark. The
>>>>>> timing for this new stage will be separate in the log view data. Look at
>>>>>> that.
>>>>>> - You can fake this by running your benchmark many times to amortize
>>>>>> any setup costs.
>>>>>> On Fri, Jan 14, 2022 at 4:27 PM Rohan Yadav <rohany at alumni.cmu.edu>
>>>>>> wrote:
>>>>>>> Hi,
>>>>>>> I'm looking to use PETSc with GPUs to do some linear algebra
>>>>>>> operations, like SpMV, SPMM etc. Building PETSc with `--with-cuda=1` and
>>>>>>> running with `-mat_type aijcusparse -vec_type cuda` gives me a large
>>>>>>> slowdown from the same code running on the CPU. This is not entirely
>>>>>>> unexpected, as things like data transfer costs across the PCIE might
>>>>>>> erroneously be included in my timing. Are there some examples of
>>>>>>> benchmarking GPU computations with PETSc, or just the proper way to write
>>>>>>> code in PETSc that will work for CPUs and GPUs?
>>>>>>> Rohan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220120/53024478/attachment-0001.html>
