[petsc-dev] PETSc init eats too much CUDA memory
    Zhang, Hong
    hongzhang at anl.gov
    Sat Jan  8 12:36:09 CST 2022
Here is an interesting thread discussing the memory issue for PyTorch (which I think is also relevant to PETSc):
https://github.com/pytorch/pytorch/issues/12873
The memory overhead (for both CPU and GPU) of PyTorch is getting worse and worse as it evolves. A conjecture is that the CUDA kernels in the library are responsible for this. But the overhead for Tensorflow2 is just around 300MB (compare to 1.5GB for PyTorch).
According to the discussion, there has not been a good way to decrease the memory overhead for PyTorch yet. Someone noticed that “removing half of the CUDA kernels can reduce the memory usage by half."
Hong
On Jan 7, 2022, at 9:23 PM, Barry Smith <bsmith at petsc.dev> wrote:
  Doesn't Nvidia supply a "valgrind" like tool that will allow tracking memory usage? I'm pretty sure I've seen one; it should be able to show memory usage as a function of time so you can see where the memory is being allocated
  Barry
On Jan 7, 2022, at 1:56 PM, Jacob Faibussowitsch <jacob.fai at gmail.com<mailto:jacob.fai at gmail.com>> wrote:
it seems that PETSc consumes 0.73GB CUDA memory and this overhead persists across the entire running time of an application. cupm_initialize contributes 0.36GB out of 0.73GB.
If I had to guess this may be the latent overhead of CUDA streams and events, but even then 360 MB seems ludicrous. CUDA maintains a persistent pool of streams that is not freed until cudaDeviceReset() is called. Maybe they initialize this pool immediately on start-up of the context? AFAIK there is no way to disable or modify this behavior.
Best regards,
(Jacob Fai - booss - oh - vitch)
On Jan 7, 2022, at 13:23, Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>> wrote:
Apart from the 1.2GB caused by importing torch, it seems that PETSc consumes 0.73GB CUDA memory and this overhead persists across the entire running time of an application. cupm_initialize contributes 0.36GB out of 0.73GB. It is still unclear what takes the remaining 0.37GB.
The torch issue is really a mystery. If I import torch only and do some tensor operations on GPU, it consumes only 0.004GB CUDA memory.
On Jan 7, 2022, at 11:54 AM, Zhang, Hong via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
1. Commenting out  ierr = __initialize(dctx->device->deviceId,dci);CHKERRQ(ierr); in device/impls/cupm/cupmcontext.hpp:L199
CUDA memory: 1.575GB
CUDA memory without importing torch:  0.370GB
This has the same effect as commenting out L437-L440 in interface/device.cxx
2. Comment out these two:
. src/sys/objects/device/impls/cupm/cupmdevice.cxx:327 [ierr = _devices[_defaultDevice]->configure();CHKERRQ(ierr);]
. src/sys/objects/device/impls/cupm/cupmdevice.cxx:326 [ierr = _devices[_defaultDevice]->initialize();CHKERRQ(ierr);]
CUDA memory: 1.936GB
CUDA memory without importing torch:   0.730GB
On Jan 7, 2022, at 11:21 AM, Jacob Faibussowitsch <jacob.fai at gmail.com<mailto:jacob.fai at gmail.com>> wrote:
They had no influence to the memory usage.
Comment out the ierr = _devices[id]->initialize();CHKERRQ(ierr); on line 360 in cupmdevice.cxx as well.
Best regards,
On Jan 7, 2022, at 12:18, Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>> wrote:
I have tried all of these. They had no influence to the memory usage.
On Jan 7, 2022, at 11:15 AM, Jacob Faibussowitsch <jacob.fai at gmail.com<mailto:jacob.fai at gmail.com>> wrote:
Initializing cutlass and cusolver does not affect the memory usage. I did the following to turn them off:
Ok next things to try out in order:
1. src/sys/objects/device/impls/cupm/cupmcontext.hpp:178 [PetscFunctionBegin;]
Put a PetscFunctionReturn(0); right after this
2. src/sys/objects/device/impls/cupm/cupmdevice.cxx:327 [ierr = _devices[_defaultDevice]->configure();CHKERRQ(ierr);]
Comment this out
3. src/sys/objects/device/impls/cupm/cupmdevice.cxx:326 [ierr = _devices[_defaultDevice]->initialize();CHKERRQ(ierr);]
Comment this out
Best regards,
On Jan 7, 2022, at 12:02, Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>> wrote:
diff --git a/src/sys/objects/device/impls/cupm/cupmcontext.hpp b/src/sys/objects/device/impls/cupm/cupmcontext.hpp
index 51fed809e4d..9a5f068323a 100644
--- a/src/sys/objects/device/impls/cupm/cupmcontext.hpp
+++ b/src/sys/objects/device/impls/cupm/cupmcontext.hpp
@@ -199,7 +199,7 @@ inline PetscErrorCode CUPMContext<T>::setUp(PetscDeviceContext dctx) noexcept
 #if PetscDefined(USE_DEBUG)
   dci->timerInUse = PETSC_FALSE;
 #endif
-  ierr = __initialize(dctx->device->deviceId,dci);CHKERRQ(ierr);
+  //ierr = __initialize(dctx->device->deviceId,dci);CHKERRQ(ierr);
On Jan 7, 2022, at 10:53 AM, Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
  I don't think this is right. We want the device initialized by PETSc , we just don't want the cublas and cusolve stuff initialized. In order to see how much memory initializing the blas and solvers takes.
  So I think you need to comment things in cupminterface.hpp like cublasCreate and cusolverDnCreate.
  Urgh, I hate C++ where huge chunks of real code are in header files.
On Jan 7, 2022, at 11:34 AM, Jacob Faibussowitsch <jacob.fai at gmail.com<mailto:jacob.fai at gmail.com>> wrote:
Hit send too early…
If you don’t want to comment out, you can also run with "-device_enable lazy" option. Normally this is the default behavior but if -log_view or -log_summary is provided this defaults to “-device_enable eager”. See src/sys/objects/device/interface/device.cxx:398
Best regards,
On Jan 7, 2022, at 11:29, Jacob Faibussowitsch <jacob.fai at gmail.com<mailto:jacob.fai at gmail.com>> wrote:
You need to go into the PetscInitialize() routine find where it loads the cublas and cusolve and comment out those lines then run with -log_view
Comment out
#if (PetscDefined(HAVE_CUDA) || PetscDefined(HAVE_HIP) || PetscDefined(HAVE_SYCL))
  ierr = PetscDeviceInitializeFromOptions_Internal(PETSC_COMM_WORLD);CHKERRQ(ierr);
#endif
At src/sys/objects/pinit.c:956
Best regards,
On Jan 7, 2022, at 11:24, Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
Without log_view it does not load any cuBLAS/cuSolve immediately with -log_view it loads all that stuff at startup. You need to go into the PetscInitialize() routine find where it loads the cublas and cusolve and comment out those lines then run with -log_view
On Jan 7, 2022, at 11:14 AM, Zhang, Hong via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
When PETSc is initialized, it takes about 2GB CUDA memory. This is way too much for doing nothing. A test script is attached to reproduce the issue. If I remove the first line "import torch", PETSc consumes about 0.73GB, which is still significant. Does anyone have any idea about this behavior?
Hong
hongzhang at gpu02:/gpfs/jlse-fs0/users/hongzhang/Projects/pnode/examples (caidao22/update-examples)$ python3 test.py
CUDA memory before PETSc 0.000GB
CUDA memory after PETSc 0.004GB
hongzhang at gpu02:/gpfs/jlse-fs0/users/hongzhang/Projects/pnode/examples (caidao22/update-examples)$ python3 test.py -log_view :0.txt
CUDA memory after PETSc 1.936GB
import torch
import sys
import os
import nvidia_smi
nvidia_smi.nvmlInit()
handle = nvidia_smi.nvmlDeviceGetHandleByIndex(0)
info = nvidia_smi.nvmlDeviceGetMemoryInfo(handle)
print('CUDA memory before PETSc %.3fGB' % (info.used/1e9))
petsc4py_path = os.path.join(os.environ['PETSC_DIR'],os.environ['PETSC_ARCH'],'lib')
sys.path.append(petsc4py_path)
import petsc4py
petsc4py.init(sys.argv)
print('CUDA memory after PETSc %.3fGB' % (info.used/1e9))
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220108/08090147/attachment-0001.html>
