[petsc-dev] PETSc init eats too much CUDA memory
    Zhang, Hong
    hongzhang at anl.gov
    Fri Jan  7 11:18:13 CST 2022
I have tried all of these. They had no influence to the memory usage.
On Jan 7, 2022, at 11:15 AM, Jacob Faibussowitsch <jacob.fai at gmail.com<mailto:jacob.fai at gmail.com>> wrote:
Initializing cutlass and cusolver does not affect the memory usage. I did the following to turn them off:
Ok next things to try out in order:
1. src/sys/objects/device/impls/cupm/cupmcontext.hpp:178 [PetscFunctionBegin;]
Put a PetscFunctionReturn(0); right after this
2. src/sys/objects/device/impls/cupm/cupmdevice.cxx:327 [ierr = _devices[_defaultDevice]->configure();CHKERRQ(ierr);]
Comment this out
3. src/sys/objects/device/impls/cupm/cupmdevice.cxx:326 [ierr = _devices[_defaultDevice]->initialize();CHKERRQ(ierr);]
Comment this out
Best regards,
(Jacob Fai - booss - oh - vitch)
On Jan 7, 2022, at 12:02, Zhang, Hong <hongzhang at anl.gov<mailto:hongzhang at anl.gov>> wrote:
diff --git a/src/sys/objects/device/impls/cupm/cupmcontext.hpp b/src/sys/objects/device/impls/cupm/cupmcontext.hpp
index 51fed809e4d..9a5f068323a 100644
--- a/src/sys/objects/device/impls/cupm/cupmcontext.hpp
+++ b/src/sys/objects/device/impls/cupm/cupmcontext.hpp
@@ -199,7 +199,7 @@ inline PetscErrorCode CUPMContext<T>::setUp(PetscDeviceContext dctx) noexcept
 #if PetscDefined(USE_DEBUG)
   dci->timerInUse = PETSC_FALSE;
 #endif
-  ierr = __initialize(dctx->device->deviceId,dci);CHKERRQ(ierr);
+  //ierr = __initialize(dctx->device->deviceId,dci);CHKERRQ(ierr);
On Jan 7, 2022, at 10:53 AM, Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
  I don't think this is right. We want the device initialized by PETSc , we just don't want the cublas and cusolve stuff initialized. In order to see how much memory initializing the blas and solvers takes.
  So I think you need to comment things in cupminterface.hpp like cublasCreate and cusolverDnCreate.
  Urgh, I hate C++ where huge chunks of real code are in header files.
On Jan 7, 2022, at 11:34 AM, Jacob Faibussowitsch <jacob.fai at gmail.com<mailto:jacob.fai at gmail.com>> wrote:
Hit send too early…
If you don’t want to comment out, you can also run with "-device_enable lazy" option. Normally this is the default behavior but if -log_view or -log_summary is provided this defaults to “-device_enable eager”. See src/sys/objects/device/interface/device.cxx:398
Best regards,
On Jan 7, 2022, at 11:29, Jacob Faibussowitsch <jacob.fai at gmail.com<mailto:jacob.fai at gmail.com>> wrote:
You need to go into the PetscInitialize() routine find where it loads the cublas and cusolve and comment out those lines then run with -log_view
Comment out
#if (PetscDefined(HAVE_CUDA) || PetscDefined(HAVE_HIP) || PetscDefined(HAVE_SYCL))
  ierr = PetscDeviceInitializeFromOptions_Internal(PETSC_COMM_WORLD);CHKERRQ(ierr);
#endif
At src/sys/objects/pinit.c:956
Best regards,
On Jan 7, 2022, at 11:24, Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
Without log_view it does not load any cuBLAS/cuSolve immediately with -log_view it loads all that stuff at startup. You need to go into the PetscInitialize() routine find where it loads the cublas and cusolve and comment out those lines then run with -log_view
On Jan 7, 2022, at 11:14 AM, Zhang, Hong via petsc-dev <petsc-dev at mcs.anl.gov<mailto:petsc-dev at mcs.anl.gov>> wrote:
When PETSc is initialized, it takes about 2GB CUDA memory. This is way too much for doing nothing. A test script is attached to reproduce the issue. If I remove the first line "import torch", PETSc consumes about 0.73GB, which is still significant. Does anyone have any idea about this behavior?
Hong
hongzhang at gpu02:/gpfs/jlse-fs0/users/hongzhang/Projects/pnode/examples (caidao22/update-examples)$ python3 test.py
CUDA memory before PETSc 0.000GB
CUDA memory after PETSc 0.004GB
hongzhang at gpu02:/gpfs/jlse-fs0/users/hongzhang/Projects/pnode/examples (caidao22/update-examples)$ python3 test.py -log_view :0.txt
CUDA memory after PETSc 1.936GB
import torch
import sys
import os
import nvidia_smi
nvidia_smi.nvmlInit()
handle = nvidia_smi.nvmlDeviceGetHandleByIndex(0)
info = nvidia_smi.nvmlDeviceGetMemoryInfo(handle)
print('CUDA memory before PETSc %.3fGB' % (info.used/1e9))
petsc4py_path = os.path.join(os.environ['PETSC_DIR'],os.environ['PETSC_ARCH'],'lib')
sys.path.append(petsc4py_path)
import petsc4py
petsc4py.init(sys.argv)
print('CUDA memory after PETSc %.3fGB' % (info.used/1e9))
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220107/00c02f46/attachment.html>
