[petsc-dev] PETSc init eats too much CUDA memory
Jacob Faibussowitsch
jacob.fai at gmail.com
Fri Jan 7 10:29:49 CST 2022
> You need to go into the PetscInitialize() routine find where it loads the cublas and cusolve and comment out those lines then run with -log_view
Comment out
#if (PetscDefined(HAVE_CUDA) || PetscDefined(HAVE_HIP) || PetscDefined(HAVE_SYCL))
ierr = PetscDeviceInitializeFromOptions_Internal(PETSC_COMM_WORLD);CHKERRQ(ierr);
#endif
At src/sys/objects/pinit.c:956
Best regards,
(Jacob Fai - booss - oh - vitch)
> On Jan 7, 2022, at 11:24, Barry Smith <bsmith at petsc.dev> wrote:
> Without log_view it does not load any cuBLAS/cuSolve immediately with -log_view it loads all that stuff at startup. You need to go into the PetscInitialize() routine find where it loads the cublas and cusolve and comment out those lines then run with -log_view
>> On Jan 7, 2022, at 11:14 AM, Zhang, Hong via petsc-dev <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
>> When PETSc is initialized, it takes about 2GB CUDA memory. This is way too much for doing nothing. A test script is attached to reproduce the issue. If I remove the first line "import torch", PETSc consumes about 0.73GB, which is still significant. Does anyone have any idea about this behavior?
>> Thanks,
>> Hong
>> hongzhang at gpu02:/gpfs/jlse-fs0/users/hongzhang/Projects/pnode/examples (caidao22/update-examples)$ python3 test.py
>> CUDA memory before PETSc 0.000GB
>> CUDA memory after PETSc 0.004GB
>> hongzhang at gpu02:/gpfs/jlse-fs0/users/hongzhang/Projects/pnode/examples (caidao22/update-examples)$ python3 test.py -log_view :0.txt
>> CUDA memory after PETSc 1.936GB
>> import torch
>> import sys
>> import os
>> import nvidia_smi
>> nvidia_smi.nvmlInit()
>> handle = nvidia_smi.nvmlDeviceGetHandleByIndex(0)
>> info = nvidia_smi.nvmlDeviceGetMemoryInfo(handle)
>> print('CUDA memory before PETSc %.3fGB' % (info.used/1e9))
>> petsc4py_path = os.path.join(os.environ['PETSC_DIR'],os.environ['PETSC_ARCH'],'lib')
>> sys.path.append(petsc4py_path)
>> import petsc4py
>> petsc4py.init(sys.argv)
>> print('CUDA memory after PETSc %.3fGB' % (info.used/1e9))
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220107/30421308/attachment.html>
