[petsc-dev] is there a bug in private_DMDALocatePointsIS_3D_Regular?
    Matteo Semplice
    matteo.semplice at uninsubria.it
    Wed Dec 21 12:34:07 CST 2022
Dear Matt,
     I am trying to translate the local nCell numbers returned by swarm
particle location routines into the global (i,j,k) indices in the dmda
and I have run into some oddities in the 3d case. I have dug into the
private_DMDALocatePointsIS_2D_Regular and
private_DMDALocatePointsIS_3D_Regular routines and, using 14 points per
direction and 1 ghost for the DMDA, on 2 cpus:
- the 2d routine thinks to have 13x6 Q1 elements on cpu0 and 13x7 on cpu
1 (which looks correct to me as 6+7 makes 13 elements in the y direction)
- the 2d routine thinks to have 13x13x6 elements on cpu0 and 13x13x8 on
cpu1 (which looks one too many)
Removing lines 155-157 from src/dm/impls/da/dageometry.c (patch
attached) seems to fix some things in my code. I have not studied in
depth the code of private_DMDALocatePointsIS_3D_Regular, but I have seen
that the left shift of xs,ys,zs are already performed at lines 137-139.
Could you have a look, please?
(This looked more appropriate for petsc-dev than petsc-users, but I am
not a subscriber, so could you please reply to me directly as well?)
Thanks
     Matteo
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20221221/3be1f3c9/attachment.bin>
