[petsc-dev] tests coverage
Satish Balay
balay at mcs.anl.gov
Fri Aug 12 10:37:34 CDT 2022
There is some coverage info - there are a couple of gcov tests - but
that doesn't show coverage from all tests.
For ex: https://gitlab.com/petsc/petsc/-/merge_requests/5509
click on the last stage/job of the pipeline 'analyze-pipeline' i.e
https://gitlab.com/petsc/petsc/-/jobs/2841119765
Here - browse 'artifacts' i.e
https://gitlab.com/petsc/petsc/-/jobs/2841119765/artifacts/browse
Here go to 'arch-ci-analyze-pipeline' and click 'index_gcov.html' i.e:
https://petsc.gitlab.io/-/petsc/-/jobs/2841119765/artifacts/arch-ci-analyze-pipeline/index_gcov.html
Satish
On Fri, 12 Aug 2022, Blaise Bourdin wrote:
> Hi,
> Is the source coverage analysis by the tests easily available? When submitting a MR, I want to know if adding a test is necessary.
> Regards,
> Blaise
> Tier 1 Canada Research Chair in Mathematical and Computational Aspects of Solid Mechanics
> Professor, Department of Mathematics & Statistics
> Hamilton Hall room 409A, McMaster University
> 1280 Main Street West, Hamilton, Ontario L8S 4K1, Canada
> https://www.math.mcmaster.ca/bourdin | +1 (905) 525 9140 ext. 27243
