[petsc-dev] Not a single person has approved the MR for allowing the use of clang-format on the repository
    Barry Smith
    bsmith at petsc.dev
    Sat Aug  6 09:31:05 CDT 2022
  Note that this MR does not clang-format the repository nor require that future MR satisfy the clang-format (yet). It merely fixes up everything needed so that we can clang-format the repository. https://gitlab.com/petsc/petsc/-/merge_requests/5455 <https://gitlab.com/petsc/petsc/-/merge_requests/5455> in the future.
  Not a single person has approved the MR; so it appears that everyone, including Jed, does not like the idea of having a way of automatically formatting the repository to eliminate much of the white-space chasing that drives Satish nuts.
  This is frustrating; why would anyone go through the effort of contributing to PETSc based on long-term requests for improvements if everything just hangs ?
  If you object to the MR, please note it in the MR otherwise, at least a few people, please approve the MR.
   Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220806/9763f5a3/attachment.html>
