[petsc-dev] odd log behavior
Barry Smith
bsmith at petsc.dev
Tue Apr 26 19:00:56 CDT 2022
The current nan output has to be replaced to get the column alignment correct, I just didn't feel like making that change also in the same MR.
Something like Unknown or anything that fits in the column space would be fine. It just means for the given run the timing numbers are not meaningful/correct for those events. This is to obtain the best meaningful results for the outer events per Jed since timing the inner events accurately introduces extra time in the outer events. That is it is not possible to have the best accurate times for both inner events and outer events in the same run. So if you want to compare KSPSolve timings, for example, you run as-is, it you want to examine, low-level vector operations run also with -log_view_gpu_time but know that the KSP times are higher than need be.
Sorry for the confusion.
> On Apr 26, 2022, at 3:49 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Apr 26, 2022 at 12:03 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> Well, Nans are a clear sign that something is very wrong.
> Barry chose them so that it could not be mistaken for an actual number.
> Matt
> On Tue, Apr 26, 2022 at 11:52 AM Jacob Faibussowitsch <jacob.fai at gmail.com <mailto:jacob.fai at gmail.com>> wrote:
> There is an automatic warning that shows when you do run with `-log_view_gpu_time`, but perhaps there should also be an automatic warning when *not* running with it. It is unfortunate that NaN is the value printed as this implies a bug but AFAIK it is unavoidable (Barry can say more on this though).
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> > On Apr 26, 2022, at 09:48, Jose E. Roman <jroman at dsic.upv.es <mailto:jroman at dsic.upv.es>> wrote:
> > You have to add -log_view_gpu_time
> > See https://gitlab.com/petsc/petsc/-/merge_requests/5056 <https://gitlab.com/petsc/petsc/-/merge_requests/5056>
> > Jose
> >> El 26 abr 2022, a las 16:39, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> escribió:
> >> I'm seeing this on Perlmutter with Kokkos-CUDA. Nans in most log timing data except the two 'Solve' lines.
> >> Just cg/jacobi on snes/ex56.
> >> Any ideas?
> >> VecTDot 2 1.0 nan nan 1.20e+01 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 100
> >> VecNorm 2 1.0 nan nan 1.00e+01 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 100
> >> VecCopy 2 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 0
> >> VecSet 5 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 0
> >> VecAXPY 4 1.0 nan nan 2.40e+01 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 100
> >> VecPointwiseMult 1 1.0 nan nan 3.00e+00 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 100
> >> KSPSetUp 1 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 0
> >> KSPSolve 1 1.0 4.0514e-04 1.0 5.50e+01 1.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 2 0 0 0 0 0 -nan 0 0.00e+00 0 0.00e+00 100
> >> SNESSolve 1 1.0 2.2128e-02 1.0 5.55e+05 1.0 0.0e+00 0.0e+00 0.0e+00 72 56 0 0 0 100100 0 0 0 25 -nan 0 0.00e+00 0 0.00e+00 0
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220426/4c9909b2/attachment.html>
