[petsc-dev] odd log behavior
Jacob Faibussowitsch
jacob.fai at gmail.com
Tue Apr 26 10:52:38 CDT 2022
There is an automatic warning that shows when you do run with `-log_view_gpu_time`, but perhaps there should also be an automatic warning when *not* running with it. It is unfortunate that NaN is the value printed as this implies a bug but AFAIK it is unavoidable (Barry can say more on this though).
Best regards,
(Jacob Fai - booss - oh - vitch)
> On Apr 26, 2022, at 09:48, Jose E. Roman <jroman at dsic.upv.es> wrote:
> You have to add -log_view_gpu_time
> See https://gitlab.com/petsc/petsc/-/merge_requests/5056
> Jose
>> El 26 abr 2022, a las 16:39, Mark Adams <mfadams at lbl.gov> escribió:
>> I'm seeing this on Perlmutter with Kokkos-CUDA. Nans in most log timing data except the two 'Solve' lines.
>> Just cg/jacobi on snes/ex56.
>> Any ideas?
>> VecTDot 2 1.0 nan nan 1.20e+01 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 100
>> VecNorm 2 1.0 nan nan 1.00e+01 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 100
>> VecCopy 2 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 0
>> VecSet 5 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 0
>> VecAXPY 4 1.0 nan nan 2.40e+01 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 100
>> VecPointwiseMult 1 1.0 nan nan 3.00e+00 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 100
>> KSPSetUp 1 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan -nan 0 0.00e+00 0 0.00e+00 0
>> KSPSolve 1 1.0 4.0514e-04 1.0 5.50e+01 1.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 2 0 0 0 0 0 -nan 0 0.00e+00 0 0.00e+00 100
>> SNESSolve 1 1.0 2.2128e-02 1.0 5.55e+05 1.0 0.0e+00 0.0e+00 0.0e+00 72 56 0 0 0 100100 0 0 0 25 -nan 0 0.00e+00 0 0.00e+00 0
