[petsc-dev] How does PETSc define the overlap in an algebraic ASM preconditioner ?
Matthew Knepley
knepley at gmail.com
Tue Apr 12 07:26:59 CDT 2022
On Tue, Apr 12, 2022 at 4:14 AM markwinpe <markwinpe at 163.com> wrote:
> Dear PETSc’s developers,
> Currently, I don’t have a geometric mesh for a PDE problem, I just
> got a matrix from others and I want to use the ASM preconditioner to solve
> the linear system. I would be appreciated if you could describe how PETSc
> defines the overlap in the context of using the algebraic ASM
> preconditioner.
The overlap is defined in terms of the matrix graph.
Matt
> Best,
> Wenpeng
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220412/fece2aa6/attachment.html>
