[petsc-dev] Error using --download-strumpack
Jean Marques jeanmarques.eng at gmail.com
Wed Apr 6 17:04:41 CDT 2022
Thanks, Pierre! That solved the problem.
Best,
Jean
On Wed, Apr 6, 2022 at 3:41 AM Pierre Jolivet <pierre at joliv.et> wrote:
> Hello Jean,
> From configure.log, you can see:
> «  CMake 3.2 or higher is required.  You are running version 2.8.12.2 »
> So you’ll either need to: update your system CMake or configure PETSc with
> --download-cmake
> Thanks,
> Pierre
> On 6 Apr 2022, at 12:33 PM, Jean Marques <jeanmarques.eng at gmail.com>
> wrote:
> Hi all,
> I am trying to install a PETSc version with STRUMPACK, although I am
> facing an error during configure (configure.log attached).
> I've tried with 3.17 and previous 3.16 versions and the error is always
> the same.
> My configure is as follows:
> ./configure PETSC_ARCH=arch-complex --with-cc=mpiicc --with-cxx=mpiicpc
> --with-fc=mpiifort 'COPTFLAGS=-g -O' 'FOPTFLAGS=-g -O' 'CXXOPTFLAGS=-g -O'
> --with-debugging=no --prefix=$PWD/complex --with-scalar-type=complex
> --download-make --with-blas-lapack-dir=$MKLROOT --download-strumpack
> --download-metis --download-parmetis --download-scalapack
> My cmake version is: cmake version 2.8.12.2
> I appreciate any help you can give me.
> Best,
> Jean
> *Jean Helder Marques Ribeiro*
> Ph.D. Candidate
> University of California, Los Angeles
> 420 Westwood Plaza, Los Angeles, CA 90095
> phone: (310) 689-6593
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220406/0c28f5c2/attachment.html>
