[petsc-dev] petsc4py build
    Matthew Knepley
    knepley at gmail.com
    Thu Sep 30 07:09:37 CDT 2021
On Thu, Sep 30, 2021 at 8:08 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> ./configure --with-petsc4py=1
> and then run a test with export PYTHONPATH=$PETSC_DIR/$PETSC_ARCH/lib
Thanks!
   Matt
> Jose
> > El 30 sept 2021, a las 14:05, Matthew Knepley <knepley at gmail.com>
> escribió:
> > If I add binding code as part of my MR, how do I check the build on my
> machine? I have gotten confused since we merged the source tree.
> >   Thanks,
> >      Matt
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210930/51413b49/attachment.html>
