[petsc-dev] I am getting something strange on osx-dbg:
Mon Sep 27 18:35:31 CDT 2021
If this is the only failure - I can delete package-cache - and rerun the job
Satish
On Mon, 27 Sep 2021, Matthew Knepley wrote:
> On Mon, Sep 27, 2021 at 7:28 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > The fix is at https://gitlab.com/petsc/petsc/-/merge_requests/4368
> > Perhaps that 'test harness' commit should have been in a different MR so
> > that this part could be merged in.
> Should I just merge this branch into mine?
>   Thanks,
>      Matt
> > Satish
> > > lds/qaG_QyAe/1/petsc/petsc/arch-ci-osx-dbg/ex
> > > # dyld: Library not loaded:
> > /Users/glci/builds/qaG_QyAe/1/petsc/petsc/arch-ci-osx-dbg/externalpackages/git.h2opus/lib/libh2opus.dylib
> > > #  Referenced from:
> > /Users/glci/builds/qaG_QyAe/0/petsc/petsc/arch-ci-osx-dbg/tests/snes/tutorials/runex16_3/../ex16
> > > #  Reason: image not found
> > > #  Referenced from:
> > /Users/glci/builds/qaG_QyAe/0/petsc/petsc/arch-ci-osx-dbg/tests/snes/tutorials/runex16_2/../ex16
> > > #  Referenced from:
> > /Users/glci/builds/qaG_QyAe/0/petsc/petsc/arch-ci-osx-dbg/tests/snes/tutorials/runex16_1/../ex16
> > > #  Referenced from:
> > > Not sure why h2opus is giving problems here.
> > >   Thanks,
> > >      Matt
