[petsc-dev] Cannot locate file: share/petsc/datafiles/matrices/small
Junchao Zhang
junchao.zhang at gmail.com
Tue Sep 14 11:01:05 CDT 2021
Yes, we can turn it off. The code without real use is just a
maintenance burden.
--Junchao Zhang
On Tue, Sep 14, 2021 at 10:45 AM Barry Smith <bsmith at petsc.dev> wrote:
> Ok, so it could be a bug in PETSc, but if it appears with particular MPI
> implementations shouldn't we turn off the support in those cases we know it
> will fail?
> Barry
> On Sep 14, 2021, at 11:10 AM, Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> MPI one-sided is tricky and needs careful synchronization (like OpenMP).
> An incorrect code could work in one interface but fail in another.
> --Junchao Zhang
> On Tue, Sep 14, 2021 at 10:01 AM Barry Smith <bsmith at petsc.dev> wrote:
>> It sounds reproducible and related to using a particular versions of
>> OpenMPI and even particular interfaces.
>> Barry
>> On Tue, Sep 14, 2021 at 2:35 AM Stefano Zampini <
>> stefano.zampini at gmail.com> wrote:
>>> I can reproduce it even with OpenMPI 4.1.1 on a different machine
>>> (Ubuntu 18 + AMD milan + clang from AOCC) and it is definitely an OpenMPI
>>> bug in the vader BTL If I use tcp, everything runs smooth
>> On Sep 14, 2021, at 10:54 AM, Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>> Without a standalone & valid mpi example to reproduce the error, we are
>> not assured to say it is an OpenMPI bug.
>> --Junchao Zhang
>> On Tue, Sep 14, 2021 at 6:17 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> Okay, we have to send this to OpenMPI. Volunteers?
>>> Maybe we should note this in the FAQ, or installation, so we remember
>>> how to fix it if someone else asks?
>>> Thanks,
>>> Matt
>>>> zampins at kanary:~/Devel/petsc$ cat
>>>> /home/zampins/local/etc/openmpi-mca-params.conf | grep btl
>>>> btl = tcp,self
>>>> zampins at kanary:~/Devel/petsc$ make -f gmakefile.test
>>>> vec_is_sf_tutorials-ex1_4
>>>> Using MAKEFLAGS:
>>>> TEST arch-debug/tests/counts/vec_is_sf_tutorials-ex1_4.counts
>>>> ok
>>>> vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-create
>>>> ok
>>>> diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-create
>>>> ok
>>>> vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-dynamic
>>>> ok
>>>> diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-dynamic
>>>> ok
>>>> vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-allocate
>>>> ok
>>>> diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-allocate
>>>> ok
>>>> vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-create
>>>> ok
>>>> diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-create
>>>> ok
>>>> vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-dynamic
>>>> ok
>>>> diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-dynamic
>>>> ok
>>>> vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-allocate
>>>> ok
>>>> diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-allocate
>>>> ok
>>>> vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-create
>>>> ok
>>>> diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-create
>>>> ok
>>>> vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-dynamic
>>>> ok
>>>> diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-dynamic
>>>> ok
>>>> vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-allocate
>>>> ok
>>>> diff-vec_is_sf_tutorials-ex1_4+sf_window_sync-lock_sf_window_flavor-allocate
>>>> btl = vader,tcp,self
>>>> Using MAKEFLAGS:
>>>> ok
>>>> not ok
>>>> # Error code: 1
>>>> # 43,46c43,46
>>>> # < [0] 0: 4001 2000 2002 3002 4002
>>>> # < [1] 0: 1001 3000
>>>> # < [2] 0: 2001 4000
>>>> # < [3] 0: 3001 1000
>>>> # > [0] 0: 2002 2146435072 2 2146435072 38736240
>>>> # > [1] 0: 3000 2146435072
>>>> # > [2] 0: 2001 2146435072
>>>> # > [3] 0: 3001 2146435072
>>>> ok
>>>> not ok
>>>> # Error code: 1
>>>> # 43,46c43,46
>>>> # > [0] 0: 2002 2146435072 2 2146435072 0
>>>> ok
>>>> ok
>>>> # retrying
>>>> not ok
>>>> vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-create #
>>>> Error code: 98
>>>> # [1]PETSC ERROR: --------------------- Error Message
>>>> # [1]PETSC ERROR: General MPI error
>>>> # [1]PETSC ERROR: MPI error 6 MPI_ERR_RANK: invalid rank
>>>> # [1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>> shooting.
>>>> # [1]PETSC ERROR: Petsc Development GIT revision:
>>>> v3.15.4-783-g168bb9f76b GIT Date: 2021-09-13 14:01:22 +0000
>>>> # [1]PETSC ERROR: ../ex1 on a arch-debug named kanary.kaust.edu.sa by
>>>> zampins Tue Sep 14 09:31:42 2021
>>>> # [1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message
>>>> # [2]PETSC ERROR: General MPI error
>>>> # [2]PETSC ERROR: MPI error 6 MPI_ERR_RANK: invalid rank
>>>> # [2]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>> shooting.
>>>> # [2]PETSC ERROR: Petsc Development GIT revision:
>>>> # [2]PETSC ERROR: ../ex1 on a arch-debug named kanary.kaust.edu.sa by
>>>> # [2]PETSC ERROR: Configure options
>>>> --with-cc=/home/zampins/local/bin/mpicc --with-cxx-dialect=c++14
>>>> --with-cxx=/home/zampins/local/bin/mpicxx --with-debugging=1
>>>> --with-fc=/home/zampins/local/bin/mpifort --with-fortran-bindings=0
>>>> --with-hip-dir=/opt/rocm --with-hip=1
>>>> --with-hypre-dir=/home/zampins/local-petsc
>>>> --with-kokkos-dir=/home/zampins/local-petsc
>>>> --with-kokkos-kernels-dir=/home/zampins/local-petsc
>>>> --with-blaslapack-include=/home/zampins/local-aocl/aocc/3.0-6/include
>>>> --with-blaslapack-lib="[/home/zampins/local-aocl/aocc/3.0-6/lib/liblapacke.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libflame.a,/home/zampins/local-aocl/aocc/3.0-6/lib/libblis-mt.a]"
>>>> HIPFLAGS=--amdgpu-target=gfx908
>>>> HIPPPFLAGS=-I/home/zampins/local-petsc/include PETSC_ARCH=arch-debug
>>>> # [2]PETSC ERROR: #1 PetscSFGetGroups() at
>>>> /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:1166
>>>> # [2]PETSC ERROR: #2 PetscSFSetUp_Window() at
>>>> /home/zampins/Devel/petsc/src/vec/is/sf/impls/window/sfwindow.c:708
>>>> # [2]PETSC ERROR: #3 PetscSFSetUp() at
>>>> /home/zampins/Devel/petsc/src/vec/is/sf/interface/sf.c:318
>>>> # [2]PETSC ERROR: #4 main() at
>>>> /home/zampins/Devel/petsc/src/vec/is/sf/tutorials/ex1.c:172
>>>> # [2]PETSC ERROR: PETSc Option Table entries:
>>>> # [2]PETSC ERROR: -sf_type window
>>>> # [2]PETSC ERROR: -sf_window_flavor create
>>>> # [2]PETSC ERROR: -sf_window_sync active
>>>> # [2]PETSC ERROR: -test_gather
>>>> # [2]PETSC ERROR: ----------------End of Error Message -------send
>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>> # [3]PETSC ERROR: --------------------- Error Message
>>>> # [3]PETSC ERROR: General MPI error
>>>> # [3]PETSC ERROR: MPI error 6 MPI_ERR_RANK: invalid rank
>>>> # [3]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>> shooting.
>>>> # [3]PETSC ERROR: Petsc Development GIT revision:
>>>> # [3]PETSC ERROR: ../ex1 on a arch-debug named kanary.kaust.edu.sa by
>>>> # [3]PETSC ERROR: Configure options
>>>> # [3]PETSC ERROR: #1 PetscSFGetGroups() at
>>>> # [3]PETSC ERROR: #2 PetscSFSetUp_Window() at
>>>> # [3]PETSC ERROR: #3 PetscSFSetUp() at
>>>> # [3]PETSC ERROR: #4 main() at
>>>> # [3]PETSC ERROR: PETSc Option Table entries:
>>>> # [3]PETSC ERROR: -sf_type window
>>>> # [3]PETSC ERROR: -sf_window_flavor create
>>>> # [1]PETSC ERROR: #1 PetscSFGetGroups() at
>>>> # [1]PETSC ERROR: #2 PetscSFSetUp_Window() at
>>>> # [1]PETSC ERROR: #3 PetscSFSetUp() at
>>>> # [1]PETSC ERROR: #4 main() at
>>>> # [1]PETSC ERROR: PETSc Option Table entries:
>>>> # [1]PETSC ERROR: -sf_type window
>>>> # [1]PETSC ERROR: -sf_window_flavor create
>>>> # [1]PETSC ERROR: -sf_window_sync active
>>>> # [1]PETSC ERROR: -test_gather
>>>> # [1]PETSC ERROR: ----------------End of Error Message -------send
>>>> # -sf_window_sync active
>>>> # [3]PETSC ERROR: -test_gather
>>>> # [3]PETSC ERROR: ----------------End of Error Message -------send
>>>> # MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD
>>>> # with errorcode 98.
>>>> # NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>>> # You may or may not see output from other processes, depending on
>>>> # exactly when Open MPI kills them.
>>>> # [kanary.kaust.edu.sa:115527] 2 more processes have sent help message
>>>> help-mpi-api.txt / mpi-abort
>>>> # [kanary.kaust.edu.sa:115527] Set MCA parameter
>>>> "orte_base_help_aggregate" to 0 to see all help / error messages
>>>> ok vec_is_sf_tutorials-ex1_4 # SKIP Command failed so no diff
>>>> # retrying
>>>> not ok
>>>> vec_is_sf_tutorials-ex1_4+sf_window_sync-active_sf_window_flavor-dynamic #
>>>> Error code: 98
>>>> shooting.
>>>> zampins Tue Sep 14 09:31:45 2021
>>>> # [1]PETSC ERROR: Configure options
>>>> shooting.
>>>> # [2]PETSC ERROR: -sf_window_flavor dynamic
>>>> shooting.
>>>> # [3]PETSC ERROR: -sf_window_flavor dynamic
>>>> # [3]PETSC ERROR: -sf_window_sync active
>>>> # -sf_window_flavor dynamic
>>>> # MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD
>>>> # [kanary.kaust.edu.sa:115572] 2 more processes have sent help message
>>>> # [kanary.kaust.edu.sa:115572] Set MCA parameter
>>>> ok
>>>> ok
>>>> ok
>>>> not ok
>>>> # Error code: 1
>>>> # 43,46c43,46
>>>> # > [0] 0: 4002 2146435072 2 2146435072 34619728
>>>> # > [2] 0: 4000 2146435072
>>>> ok
>>>> not ok
>>>> # Error code: 1
>>>> # 43,46c43,46
>>>> # > [0] 0: 4002 2146435072 2 2146435072 0
>>>> ok
>>>> ok
>>>> Il giorno mar 14 set 2021 alle ore 07:44 Stefano Zampini <
>>>> stefano.zampini at gmail.com> ha scritto:
>>>>> I'll see if I can reproduce
>>>>> Il Mar 14 Set 2021, 06:58 Junchao Zhang <junchao.zhang at gmail.com> ha
>>>>> scritto:
>>>>>> Hi, Stefano,
>>>>>> Ping you again to see if you want to resolve this problem before
>>>>>> petsc-3.16
>>>>>> --Junchao Zhang
>>>>>> On Sun, Sep 12, 2021 at 3:06 PM Antonio T. sagitter <
>>>>>> sagitter at fedoraproject.org> wrote:
>>>>>>> Unfortunately, it's not possible. I must use the OpenMPI provided by
>>>>>>> Fedora build-system (these rpm builds of PETSc are for Fedora's
>>>>>>> repositories), downloading external software is not permitted.
>>>>>>> On 9/12/21 21:10, Pierre Jolivet wrote:
>>>>>>> >> On 12 Sep 2021, at 8:56 PM, Matthew Knepley <knepley at gmail.com
>>>>>>> >> <mailto:knepley at gmail.com>> wrote:
>>>>>>> >> On Sun, Sep 12, 2021 at 2:49 PM Antonio T. sagitter
>>>>>>> >> <sagitter at fedoraproject.org <mailto:sagitter at fedoraproject.org>>
>>>>>>> wrote:
>>>>>>> >> Those attached are configure.log/make.log from a MPI build in
>>>>>>> >> Fedora 34
>>>>>>> >> x86_64 where the error below occurred.
>>>>>>> >> This is OpenMPI 4.1.0. Is that the only MPI you build? My first
>>>>>>> >> inclination is that this is an MPI implementation bug.
>>>>>>> >> Junchao, do we have an OpenMPI build in the CI?
>>>>>>> > config/examples/arch-ci-linux-cuda-double-64idx.py:
>>>>>>> > '--download-openmpi=1',
>>>>>>> > config/examples/arch-ci-linux-pkgs-dbg-ftn-interfaces.py:
>>>>>>> > config/examples/arch-ci-linux-pkgs-opt.py: '--download-openmpi=1',
>>>>>>> > config/BuildSystem/config/packages/OpenMPI.py uses version 4.1.0
>>>>>>> as well.
>>>>>>> > I’m not sure PETSc is to blame here Antonio. You may want to try
>>>>>>> to
>>>>>>> > ditch the OpenMPI shipped by your packet manager and try
>>>>>>> > --download-openmpi as well, just for a quick sanity check.
>>>>>>> > Thanks,
>>>>>>> > Pierre
>>>>>>> Antonio Trande
>>>>>>> Fedora Project
>>>>>>> mailto: sagitter at fedoraproject.org
>>>>>>> GPG key: 0x29FBC85D7A51CC2F
>>>>>>> GPG key server: https://keyserver1.pgp.com/
>>>> Stefano
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210914/cf46e69c/attachment-0001.html>
