[petsc-dev] Cannot locate file: share/petsc/datafiles/matrices/small
Junchao Zhang
junchao.zhang at gmail.com
Sun Sep 12 14:20:18 CDT 2021
We met SF + Windows errors before. Stefano wrote the code, which I don't
think was worth doing. SF with MPI one-sided is hard to be correct (due to
shared memory programming), bad in performance, and no users use that.
I would suggest we just disable the test and feature? Stefano, what do
you think?
--Junchao Zhang
On Sun, Sep 12, 2021 at 2:10 PM Pierre Jolivet <pierre at joliv.et> wrote:
> On 12 Sep 2021, at 8:56 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Sep 12, 2021 at 2:49 PM Antonio T. sagitter <
> sagitter at fedoraproject.org> wrote:
>> Those attached are configure.log/make.log from a MPI build in Fedora 34
>> x86_64 where the error below occurred.
> This is OpenMPI 4.1.0. Is that the only MPI you build? My first
> inclination is that this is an MPI implementation bug.
> Junchao, do we have an OpenMPI build in the CI?
> config/examples/arch-ci-linux-cuda-double-64idx.py:
> '--download-openmpi=1',
> config/examples/arch-ci-linux-pkgs-dbg-ftn-interfaces.py:
> config/examples/arch-ci-linux-pkgs-opt.py: '--download-openmpi=1',
> config/BuildSystem/config/packages/OpenMPI.py uses version 4.1.0 as well.
> I’m not sure PETSc is to blame here Antonio. You may want to try to ditch
> the OpenMPI shipped by your packet manager and try --download-openmpi as
> well, just for a quick sanity check.
> Thanks,
> Pierre
> Thanks,
> Matt
>> On 9/12/21 19:18, Antonio T. sagitter wrote:
>> > Okay. I will try to set correctly the DATAFILESPATH options.
>> > I see even this error:
>> > not ok
>> > vec_is_sf_tutorials-ex1_4+sf_window_sync-fence_sf_window_flavor-create
>> > Error code: 68
>> > # PetscSF Object: 4 MPI processes
>> > # type: window
>> > # [0] Number of roots=3, leaves=2, remote ranks=2
>> > # [0] 0 <- (3,1)
>> > # [0] 1 <- (1,0)
>> > # [1] Number of roots=2, leaves=3, remote ranks=2
>> > # [1] 0 <- (0,1)
>> > # [1] 1 <- (2,0)
>> > # [1] 2 <- (0,2)
>> > # [2] Number of roots=2, leaves=3, remote ranks=3
>> > # [2] 0 <- (1,1)
>> > # [2] 1 <- (3,0)
>> > # [2] 2 <- (0,2)
>> > # [3] Number of roots=2, leaves=3, remote ranks=2
>> > # [3] 0 <- (2,1)
>> > # [3] 1 <- (0,0)
>> > # [3] 2 <- (0,2)
>> > # [0] Roots referenced by my leaves, by rank
>> > # [0] 1: 1 edges
>> > # [0] 1 <- 0
>> > # [0] 3: 1 edges
>> > # [0] 0 <- 1
>> > # [1] Roots referenced by my leaves, by rank
>> > # [1] 0: 2 edges
>> > # [1] 0 <- 1
>> > # [1] 2 <- 2
>> > # [1] 2: 1 edges
>> > # [1] 1 <- 0
>> > # [2] Roots referenced by my leaves, by rank
>> > # [2] 0: 1 edges
>> > # [2] 2 <- 2
>> > # [2] 1: 1 edges
>> > # [2] 0 <- 1
>> > # [2] 3: 1 edges
>> > # [2] 1 <- 0
>> > # [3] Roots referenced by my leaves, by rank
>> > # [3] 0: 2 edges
>> > # [3] 1 <- 0
>> > # [3] 2 <- 2
>> > # [3] 2: 1 edges
>> > # [3] 0 <- 1
>> > # current flavor=CREATE synchronization=FENCE MultiSF
>> sort=rank-order
>> > # current info=MPI_INFO_NULL
>> > # [buildhw-x86-09:1135574] *** An error occurred in MPI_Accumulate
>> > # [buildhw-x86-09:1135574] *** reported by process [3562602497,3]
>> > # [buildhw-x86-09:1135574] *** on win rdma window 4
>> > # [buildhw-x86-09:1135574] *** MPI_ERR_RMA_RANGE: invalid RMA
>> address
>> > range
>> > # [buildhw-x86-09:1135574] *** MPI_ERRORS_ARE_FATAL (processes in
>> > this win will now abort,
>> > # [buildhw-x86-09:1135574] *** and potentially your MPI job)
>> > # [buildhw-x86-09.iad2.fedoraproject.org:1135567] 3 more processes
>> > have sent help message help-mpi-errors.txt / mpi_errors_are_fatal
>> > # [buildhw-x86-09.iad2.fedoraproject.org:1135567] Set MCA parameter
>> > "orte_base_help_aggregate" to 0 to see all help / error messages
>> > Looks like an error related to OpenMPI-4*:
>> > https://github.com/open-mpi/ompi/issues/6374
>> Antonio Trande
>> Fedora Project
>> mailto: sagitter at fedoraproject.org
>> GPG key: 0x29FBC85D7A51CC2F
>> GPG key server: https://keyserver1.pgp.com/
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210912/0d6de562/attachment-0001.html>
