[petsc-dev] Test parsing
Jacob Faibussowitsch
jacob.fai at gmail.com
Thu Oct 28 08:25:03 CDT 2021
Alternatively, we could run dos2unix over all the tests during configure stage and error if this makes a diff.
https://linux.die.net/man/1/dos2unix
Best regards,
(Jacob Fai - booss - oh - vitch)
> On Oct 28, 2021, at 08:22, Jacob Faibussowitsch <jacob.fai at gmail.com> wrote:
> Fix is trivial, we just need to replace ‘\n’ with os.linesep everywhere.
> https://docs.python.org/3/library/os.html#os.linesep <https://docs.python.org/3/library/os.html#os.linesep>
> Best regards,
>> On Oct 28, 2021, at 08:12, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> I just found a loophole in the test parsing happening here:
>> https://gitlab.com/petsc/petsc/-/blob/main/config/testparse.py#L530 <https://gitlab.com/petsc/petsc/-/blob/main/config/testparse.py#L530>
>> If your file was produced on Windows (CRLF), then the parsing fails and tests
>> are silently ignored. This took me some time to find and could be confusing
>> for others. I think we should either:
>> a) Fix the parser to work with CRLF as well
>> or
>> b) Fail immediately for CRLF files
>> What do you think?
>> Thanks,
>> Matt
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211028/6389c63b/attachment.html>
