[petsc-dev] Test parsing
Matthew Knepley
knepley at gmail.com
Thu Oct 28 08:12:52 CDT 2021
I just found a loophole in the test parsing happening here:
https://gitlab.com/petsc/petsc/-/blob/main/config/testparse.py#L530
If your file was produced on Windows (CRLF), then the parsing fails and
tests
are silently ignored. This took me some time to find and could be confusing
for others. I think we should either:
a) Fix the parser to work with CRLF as well
or
b) Fail immediately for CRLF files
What do you think?
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211028/ae165e95/attachment.html>
