[petsc-dev] PETSc () -- MPI -- Versions Conflict on Mac 1
Ahmed Galal
ahmed.galal8591 at gmail.com
Mon Oct 25 09:00:53 CDT 2021
Hello,
I tried to run Step-17 in Dealii, a PETSc Dependenant software, but I got
the following error. Given I have two versions of PETSc. I use the other
one for another software.
I googled and found that the issue is solved by commenting out the line
"ADD_FLAGS(DEAL_II_LINKER_FLAGS "-fuse-ld=gold")" in
"cmake/checks/check_01_compiler_features.cmake", make test, worked.
https://groups.google.com/u/1/g/dealii/c/JxUOyd_4eFM?pli=1https://groups.google.com/u/1/g/dealii/c/JxUOyd_4eFM?pli=1
Any suggestions for how to get around that error "PETSc Error ---
Application was linked against both OpenMPI and MPICH based MPI libraries
and will not run correctly" in the new version of DealII.9.3 as I could not
find a .cmake similar file to edit?
Thanks in advance!
Ahmed
Error:
PETSc Error --- Application was linked against both OpenMPI and MPICH based
MPI libraries and will not run correctly
[----] *** Process received signal ***
[----] Signal: Segmentation fault: 11 (11)
[----] Signal code: Address not mapped (1)
[----] Failing at address: 0x68
[----] [ 0] 0 libsystem_platform.dylib 0x00007fff2041cd7d
_sigtramp + 29
[----] [ 1] 0 ??? 0x0000000060b9d791 0x0
+ 1622792081
[----] [ 2] 0 libsystem_c.dylib 0x00007fff202edfcc
vfprintf_l + 28
[----] [ 3] 0 libsystem_c.dylib 0x00007fff202e69a2
fprintf + 160
[----] [ 4] 0 libpetsc.3.15.dylib 0x000000014c224f0d
PetscVFPrintfDefault + 685
[ 5] 0 libpetsc.3.15.dylib 0x000000014c2280d6
PetscFPrintf + 726
[ 6] 0 libpetsc.3.15.dylib 0x000000014c21d537
PetscErrorPrintfDefault + 375
[ 7] 0 libpetsc.3.15.dylib 0x000000014c21d66a
PetscTraceBackErrorHandler + 154
[ 8] 0 libpetsc.3.15.dylib 0x000000014c21713c PetscError
+ 716
[ 9] 0 libslepc.3.15.dylib 0x000000014bc9cc8c
SlepcInitialize + 428
[10] 0 libdeal_II.g.9.3.0.dylib 0x00000001151ae627
_ZN6dealii9Utilities3MPI16MPI_InitFinalizeC2ERiRPPcj + 135
[11] 0 libdeal_II.g.9.3.0.dylib 0x00000001151aece9
_ZN6dealii9Utilities3MPI16MPI_InitFinalizeC1ERiRPPcj + 9
[12] 0 step-17 0x000000010f244892 main + 82
[13] 0 libdyld.dylib 0x00007fff203f2f3d start + 1
[14] 0 ??? 0x0000000000000001 0x0 + 1
*** End of error message ***
make[3]: *** [CMakeFiles/run] Segmentation fault: 11
make[2]: *** [CMakeFiles/run.dir/all] Error 2
make[1]: *** [CMakeFiles/run.dir/rule] Error 2
make: *** [run] Error 2
bash-3.2$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211025/c970692f/attachment-0001.html>
