[petsc-dev] AMGx integration
Mark Adams
mfadams at lbl.gov
Tue Oct 19 11:03:18 CDT 2021
Matt, (cc'ing Matt M.).
Thanks, that looks pretty straight forward.
Matt M: I'm not very familiar with the configuration system. It might be
best for you to ask questions directly instead of me hacking this up.
mmg.py (appended) and AMReX.py are
in petsc/config/BuildSystem/config/packages. I'm guessing it will be
easiest to prune and clone AMReX.py (150 LOC)
I have rebased the branch over main and am testing it now.
import config.package
import os
class Configure(config.package.CMakePackage):
def __init__(self, framework):
config.package.CMakePackage.__init__(self, framework)
self.gitcommit = '5fc1b2c76fe1d6787387f5c9600759d4cbf26a88' #
jolivet/feature-mmg-install-3.16.0 sep-29-2021
self.download = ['git://https://github.com/prj-/mmg.git','
https://github.com/prj-/mmg/archive/'+self.gitcommit+'.tar.gz']
self.versionname = 'MMG_VERSION_RELEASE'
self.includes = ['mmg/libmmg.h']
self.liblist = [['libmmg.a','libmmg3d.a']]
self.functions = ['MMG5_paramUsage1']
self.precisions = ['double']
return
def setupDependencies(self, framework):
config.package.CMakePackage.setupDependencies(self, framework)
self.externalpackagesdir =
framework.require('PETSc.options.externalpackagesdir',self)
self.compilerFlags = framework.require('config.compilerFlags',self)
self.mathlib = framework.require('config.packages.mathlib',self)
self.ptscotch = framework.require('config.packages.PTScotch',self)
self.deps = [self.mathlib,self.ptscotch]
return
def formCMakeConfigureArgs(self):
args = config.package.CMakePackage.formCMakeConfigureArgs(self)
args.append('-DUSE_ELAS=OFF')
args.append('-DUSE_VTK=OFF')
args.append('-DUSE_POINTMAP=ON')
args.append('-DSCOTCH_DIR:STRING="'+self.ptscotch.directory+'"')
return args
def configureLibrary(self):
config.package.CMakePackage.configureLibrary(self)
On Tue, Oct 19, 2021 at 9:34 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Oct 19, 2021 at 9:32 AM Mark Adams <mfadams at lbl.gov> wrote:
>> cmake
> barf. Clone one of those, like mmg.py or AMReX.py
> Thanks,
> Matt
>> On Tue, Oct 19, 2021 at 9:26 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Oct 19, 2021 at 8:17 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> We (Matt Martineau and I) are ready to work on the AMGx integration and
>>>> I want to start by getting the AMGx download working.
>>>> I'm looking for advice on how to proceed.
>>>> Should I look at a simple example and clone it?
>>> What build system does it use?
>>> Thanks,
>>> Matt
>>>> Thanks,
>>>> Mark
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211019/e421c094/attachment.html>
