[petsc-dev] Anyone run STREAMS on an Apple M1 system?
Barry Smith
bsmith at petsc.dev
Mon Oct 18 17:04:28 CDT 2021
BTW: In the table
Oct 18th, 2021 ASUS System Product Name <https://browser.geekbench.com/v3/cpu/8966621>
Intel Core i9-11900K 3504 MHz (8 cores)
Windows 32-bit
32 bit WTF?
> On Oct 18, 2021, at 6:02 PM, Barry Smith <bsmith at petsc.dev> wrote:
> Thanks, presumably we'll see the new Mac's there in a few days. BTW: the old streams benchmark page should point to this site; google is worthless.
> I get 24 on my Intel MacBook Pro and it also saturates with 1 core.
> Barry
>> On Oct 18, 2021, at 4:48 PM, Jed Brown <jed at jedbrown.org> wrote:
>> I don't have one, but this suggests it gets about 40 GB/s and can be saturated by a single core. I believe it uses two channels of LPDDR4X-4266, which has a theoretical peak of 68 GB/s.
>> https://browser.geekbench.com/v3/cpu/8931693
>> The press release claims up to 400 GB/s on the Max using DDR5. I assume that's calculated based on 8 channels of LPDDR5-6400, which seems like a surprisingly big step and I'm skeptical of what will actually be realized.
>> Barry Smith <bsmith at petsc.dev> writes:
>>> Can anyone who owns an Apple M1 system run the MPI streams benchmark? Make sure the -O3 (or something) optimization flags are turned on.
>>> Thanks
>>> Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211018/8d0c1a93/attachment.html>
