[petsc-dev] snes/tests/ex13 hangs
Mark Adams
mfadams at lbl.gov
Sun Oct 17 16:44:49 CDT 2021
Just an update. This is not deterministic. I am thinking that Permutters
MPI might be an issue.
On Sat, Oct 16, 2021 at 4:47 PM Mark Adams <mfadams at lbl.gov> wrote:
> I am running snes/ex13 on Perlmutter and doing a scaling study in a
> script. The first case runs fine:
> + srun -G 32 -n 256 --cpu-bind=cores --ntasks-per-core=1
> /global/homes/m/madams/mps-wrapper.sh ../ex13 -dm_plex_box_faces 4,8,8
> -petscpartitioner_simple_node_grid 2,2,2 *-dm_refine 3 *-dm_mat_type
> aijcusparse -dm_vec_type cuda -dm_view -ksp_max_it 15 -log_view
> but the next case *with another levels of refinement*:
> -petscpartitioner_simple_node_grid 2,2,2 *-dm_refine 4 *-dm_mat_type
> hangs in BuildTwoSided. With log_trace I see this (grepping on 177). Args
> appended.
> Any ideas?
> Thanks
> [177] 21.4441 Event begin: MatGetBrAoCol
> [177] 21.4441 Event begin: SFSetUp
> [177] 21.4441 Event begin: BuildTwoSided
> [177] 21.5443 Event end: BuildTwoSided
> [177] 21.5443 Event end: SFSetUp
> [177] 21.5443 Event begin: MatAssemblyBegin
> [177] 21.5444 Event end: MatAssemblyBegin
> [177] 21.5444 Event begin: MatAssemblyEnd
> [177] 21.5444 Event end: MatAssemblyEnd
> [177] 21.5444 Event end: MatGetBrAoCol
> [177] 21.5444 Event begin: MatGetLocalMat
> [177] 21.5569 Event begin: MatCUSPARSCopyTo
> [177] 21.557 Event end: MatCUSPARSCopyTo
> [177] 21.557 Event begin: MatCUSPARSCopyTo
> [177] 21.5571 Event end: MatCUSPARSCopyTo
> [177] 21.5571 Event end: MatGetLocalMat
> [177] 21.5571 Event begin: MatCUSPARSCopyTo
> [177] 21.5698 Event begin: MatCUSPARSCopyTo
> [177] 21.5698 Event end: MatCUSPARSCopyTo
> [177] 21.5827 Event begin: MatConvert
> [177] 21.5954 Event end: MatConvert
> [177] 21.5954 Event begin: MatCUSPARSCopyTo
> [177] 21.5954 Event end: MatCUSPARSCopyTo
> [177] 21.5955 Event end: MatCUSPARSCopyTo
> [177] 21.6208 Event begin: SFSetGraph
> [177] 21.6208 Event end: SFSetGraph
> [177] 21.6208 Event begin: SFSetUp
> [177] 21.6208 Event begin: BuildTwoSided
> #PETSc Option Table entries:
> -benchmark_it 10
> -dm_distribute
> -dm_mat_type aijcusparse
> -dm_plex_box_lower 0,0,0
> -dm_plex_box_upper 2,4,4
> -dm_plex_dim 3
> -dm_plex_simplex 0
> -dm_refine 3
> -dm_vec_type cuda
> -dm_view
> -ksp_max_it 15
> -ksp_monitor_short
> -ksp_norm_type unpreconditioned
> -ksp_rtol 1.e-12
> -ksp_type cg
> -log_view
> -matptap_via scalable
> -mg_levels_esteig_ksp_max_it 5
> -mg_levels_esteig_ksp_type cg
> -mg_levels_ksp_max_it 2
> -mg_levels_ksp_type richardson
> -mg_levels_pc_type jacobi
> -options_left
> -pc_gamg_coarse_eq_limit 100
> -pc_gamg_coarse_grid_layout_type spread
> -pc_gamg_esteig_ksp_max_it 5
> -pc_gamg_esteig_ksp_type cg
> -pc_gamg_process_eq_limit 100
> -pc_gamg_repartition false
> -pc_gamg_reuse_interpolation true
> -pc_gamg_square_graph 1
> -pc_gamg_threshold 0.01
> -pc_gamg_threshold_scale .5
> -pc_type gamg
> -petscpartitioner_simple_process_grid 2,4,4
> -petscpartitioner_type simple
> -potential_petscspace_degree 2
> -snes_max_it 1
> -snes_rtol 1.e-8
> -snes_type ksponly
> -use_gpu_aware_mpi 0
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> Configure options: --CFLAGS=" -g -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10
> -DLANDAU_MAX_Q=4" --CXXFLAGS=" -g -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10
> -DLANDAU_MAX_Q=4" --CUDAFLAGS="-g -Xcompiler -rdynamic -DLANDAU_DIM=2
> -DLANDAU_MAX_SPECIES=10 -DLANDAU_MAX_
> Q=4" --with-cc=cc --with-cxx=CC --with-fc=ftn
> --with-cudac=/global/common/software/nersc/cos1.3/cuda/11.3.0/bin/nvcc
> --FFLAGS=" -g " --COPTFLAGS=" -O" --CXXOPTFLAGS=" -O" --FOPTFLAGS="
> -O" --with-debugging=0 --with-cuda=1 --with-cuda-arch=80 --with
> -mpiexec=srun --with-batch=0 --download-p4est=1 --with-zlib=1
> PETSC_ARCH=arch-perlmutter-opt-nvidia-cuda
> Libraries compiled on 2021-10-16 18:33:45 on login02
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211017/637afc3b/attachment.html>
