[petsc-dev] libpetsc.so: undefined references
Satish Balay
balay at mcs.anl.gov
Sat Oct 2 10:48:15 CDT 2021
--with-clib-autodetect=0 --with-fortranlib-autodetect=0 --with-cxxlib-autodetect=0
--CC_LINKER_FLAGS="-Wl,-z,relro -Wl,--as-needed -Wl,-z,now -specs=/usr/lib/rpm/redhat/redhat-hardened-ld -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 "
--FC_LINKER_FLAGS="-Wl,-z,relro -Wl,--as-needed -Wl,-z,now -specs=/usr/lib/rpm/redhat/redhat-hardened-ld -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -lgfortran"
Since autodetect is disabled - its expected the required compiler libraries are passed in via LIBS or in this case CC_LINKER_FLAGS, FC_LINKER_FLAGS
i.e add -lstdc++ to both.
I'm surprised that you didn't need -lgfortran with CC_LINKER_FLAGS in there as well - but get [as libpetsc.so is built with CLINKER]
> libgfortran.so.5 => /lib64/libgfortran.so.5 (0x00007f00d9dde000)
Satish
On Sat, 2 Oct 2021, Antonio T. sagitter wrote:
> Hi all.
> In PETSc-3.16.0, the linker is not working because of these undefined
> references (see https://pastebin.com/izGTfmMp):
> /usr/bin/ld: x86_64/lib/libpetsc.so: undefined reference to `operator
> delete(void*, unsigned long)'
> /usr/bin/ld: x86_64/lib/libpetsc.so: undefined reference to `__cxa_rethrow'
> `__gxx_personality_v0'
> new(unsigned long)'
> `std::__throw_bad_alloc()'
> /usr/bin/ld: x86_64/lib/libpetsc.so: undefined reference to `std::terminate()'
> `std::__throw_bad_array_new_length()'
> /usr/bin/ld: x86_64/lib/libpetsc.so: undefined reference to `typeinfo for
> std::exception'
> `__cxa_begin_catch'
> /usr/bin/ld: x86_64/lib/libpetsc.so: undefined reference to `__cxa_end_catch'
> `std::__throw_length_error(char const*)'
> collect2: error: ld returned 1 exit status
> There are also
> $ ldd -r build/BUILD/petsc-3.16.0/petsc-3.16.0/x86_64/lib/libpetsc.so'
> Start: shell
> linux-vdso.so.1 (0x00007fffbf347000)
> libsuperlu.so.5.2 => /lib64/libsuperlu.so.5.2 (0x00007f00dad0c000)
> libflexiblas.so.3 => /lib64/libflexiblas.so.3 (0x00007f00da95a000)
> libcgns.so.4.2 => /lib64/libcgns.so.4.2 (0x00007f00da873000)
> libhdf5.so.103 => /lib64/libhdf5.so.103 (0x00007f00da4d8000)
> libm.so.6 => /lib64/libm.so.6 (0x00007f00da3f8000)
> libX11.so.6 => /lib64/libX11.so.6 (0x00007f00da2ae000)
> libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f00da294000)
> libc.so.6 => /lib64/libc.so.6 (0x00007f00da08b000)
> libquadmath.so.0 => /lib64/libquadmath.so.0 (0x00007f00d9d94000)
> /lib64/ld-linux-x86-64.so.2 (0x00007f00dc18b000)
> libsz.so.2 => /lib64/libsz.so.2 (0x00007f00d9d8a000)
> libz.so.1 => /lib64/libz.so.1 (0x00007f00d9d6e000)
> libxcb.so.1 => /lib64/libxcb.so.1 (0x00007f00d9d43000)
> libXau.so.6 => /lib64/libXau.so.6 (0x00007f00d9d3d000)
> undefined symbol: _ZTISt9exception
> (build/BUILD/petsc-3.16.0/petsc-3.16.0/x86_64/lib/libpetsc.so)
> undefined symbol: __gxx_personality_v0
> undefined symbol: _ZdlPvm
> undefined symbol: __cxa_rethrow
> undefined symbol: _Znwm
> undefined symbol: _ZSt17__throw_bad_allocv
> undefined symbol: _ZSt9terminatev
> undefined symbol: _ZSt28__throw_bad_array_new_lengthv
> undefined symbol: __cxa_begin_catch
> undefined symbol: __cxa_end_catch
> undefined symbol: _ZSt20__throw_length_errorPKc
> I'm attaching configure.log and make.log
> Antonio Trande
> Fedora Project
> mailto: sagitter at fedoraproject.org
> GPG key: 0x29FBC85D7A51CC2F
> GPG key server: https://keyserver1.pgp.com/
