[petsc-dev] PTScotch problem on Mac
Lawrence Mitchell wence at gmx.li
Tue Nov 23 15:36:41 CST 2021
> On 23 Nov 2021, at 21:29, Satish Balay via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> perhaps "dtruss -f" ?
> https://stackoverflow.com/questions/1925978/equivalent-of-strace-feopen-command-on-mac-os-x
> balay at ypro petsc % dtruss -f ./configure
> dtrace: system integrity protection is on, some features will not be available
> dtrace: failed to initialize dtrace: DTrace requires additional privileges
Yeah, you need boot into recovery mode (holding Command-R on startup) and turn off the SIP:
csrutil enable --without dtrace
Remind me why we use apple hardware again?
Lawrence
