[petsc-dev] PTScotch problem on Mac
Matthew Knepley
knepley at gmail.com
Tue Nov 23 10:33:26 CST 2021
On Tue, Nov 23, 2021 at 11:28 AM Satish Balay <balay at mcs.anl.gov> wrote:
> Well we don't have this issue on our (macos) CI boxes where both c2html
> and scotch build and run daily [in CI]
> what 'flex' are you using? And why does it behave differently on your box?
main *$:/PETSc3/petsc/petsc-dev$ which flex
/usr/bin/flex
main *$:/PETSc3/petsc/petsc-dev$ flex --version
flex 2.5.35 Apple(flex-32)
> And what errors do you get?
Without the extra input define in PTScotch.py, I get the yylval symbol
undefined and the lexer symbol. When I give
that define as input, only the lexer symbol is undefined.
> Perhaps CI is using older xcode (command line tools) - and you are using
> newer? Or something else?
Probably the other way around. I am on Catalina 10.15.6
Matt
> Barry - do you have this issue on your machine?
> balay at ypro ~ % which flex
> /usr/bin/flex
> balay at ypro ~ % /usr/bin/flex --version
> balay at ypro petsc % clang -v
> Apple clang version 12.0.0 (clang-1200.0.32.2)
> Target: x86_64-apple-darwin19.6.0
> Thread model: posix
> InstalledDir: /Library/Developer/CommandLineTools/usr/bin
> balay at ypro ~ % balay at ypro petsc % ./configure
> --with-mpi-dir=$HOME/mpich-3.4.2 --download-c2html --download-ptscotch
> <log attached>
> Satish
> On Tue, 23 Nov 2021, Matthew Knepley wrote:
> > This is the same flex problem as I had for c2html, but I was more
> > determined tracking it down this time. The first problem is that we were
> > not renaming in the parser,
> > main *$:/PETSc3/petsc/petsc-dev$ git diff
> > diff --git a/config/BuildSystem/config/packages/PTScotch.py
> > b/config/BuildSystem/config/packages/PTScotch.py
> > index d1c277b6e9f..e046804c17f 100644
> > --- a/config/BuildSystem/config/packages/PTScotch.py
> > +++ b/config/BuildSystem/config/packages/PTScotch.py
> > @@ -70,7 +70,7 @@ class Configure(config.package.Package):
> > if self.libraries.add('-lrt','timer_create'): ldflags += ' -lrt'
> > self.cflags = self.cflags + ' -DCOMMON_RANDOM_FIXED_SEED'
> > # do not use -DSCOTCH_PTHREAD because requires MPI built for
> threads.
> > - self.cflags = self.cflags + ' -DSCOTCH_RENAME
> > -Drestrict="'+self.compilers.cRestrict+'"'
> > + self.cflags = self.cflags + ' -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER
> > # this is needed on the Mac, because common2.c includes common.h
> which
> > DOES NOT include mpi.h because
> > # SCOTCH_PTSCOTCH is NOT defined above Mac does not know what
> > clock_gettime() is!
> > if self.setCompilers.isDarwin(self.log):
> > Second, they were not treating this case completely correctly:
> (93454e8...):/PETSc3/petsc/petsc-dev/arch-master-debug/externalpackages/git.ptscotch/src/libscotch$
> > git diff HEAD~1
> > diff --git a/src/libscotch/parser_yy.h b/src/libscotch/parser_yy.h
> > index 931315d..95b8160 100644
> > --- a/src/libscotch/parser_yy.h
> > +++ b/src/libscotch/parser_yy.h
> > @@ -62,6 +62,9 @@
> > #if ((defined SCOTCH_RENAME_PARSER) || (defined yylex)) /* If prefix
> > renaming */
> > #define scotchyyparse stratParserParse2 /* Parser function
> > name */
> > +#if !defined(yylex)
> > +#define yylex scotchyylex
> > +#endif
> > #ifndef yylval
> > #define yylval SCOTCH_NAME_MACRO3 (scotchyy,
> > SCOTCH_NAME_SUFFIXC, lval) /* It should be Yacc/Bison's job to redefine
> it!
> > #endif /* yylval */
> > How should we go about getting this fix in? Do you need to have our own
> > branch of PTScotch?
> > Thanks,
> > Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211123/98dc2e0a/attachment.html>
