[petsc-dev] PTScotch problem on Mac
Barry Smith
bsmith at petsc.dev
Tue Nov 23 10:24:33 CST 2021
Mail a patch.
> On Nov 23, 2021, at 11:19 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Nov 23, 2021 at 11:17 AM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
> I would normally say make a pull request but they have their own git server that requires you ask them for an account so I suggest posting an issue with your patch.
> Also need an account to create an issue :)
> Matt
> Barry
>> On Nov 23, 2021, at 10:55 AM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> This is the same flex problem as I had for c2html, but I was more determined tracking it down this time. The first problem is that we were not renaming in the parser,
>> main *$:/PETSc3/petsc/petsc-dev$ git diff
>> diff --git a/config/BuildSystem/config/packages/PTScotch.py b/config/BuildSystem/config/packages/PTScotch.py
>> index d1c277b6e9f..e046804c17f 100644
>> --- a/config/BuildSystem/config/packages/PTScotch.py
>> +++ b/config/BuildSystem/config/packages/PTScotch.py
>> @@ -70,7 +70,7 @@ class Configure(config.package.Package):
>> if self.libraries.add('-lrt','timer_create'): ldflags += ' -lrt'
>> self.cflags = self.cflags + ' -DCOMMON_RANDOM_FIXED_SEED'
>> # do not use -DSCOTCH_PTHREAD because requires MPI built for threads.
>> - self.cflags = self.cflags + ' -DSCOTCH_RENAME -Drestrict="'+self.compilers.cRestrict+'"'
>> + self.cflags = self.cflags + ' -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER -Drestrict="'+self.compilers.cRestrict+'"'
>> # this is needed on the Mac, because common2.c includes common.h which DOES NOT include mpi.h because
>> # SCOTCH_PTSCOTCH is NOT defined above Mac does not know what clock_gettime() is!
>> if self.setCompilers.isDarwin(self.log):
>> Second, they were not treating this case completely correctly:
>> (93454e8...):/PETSc3/petsc/petsc-dev/arch-master-debug/externalpackages/git.ptscotch/src/libscotch$ git diff HEAD~1
>> diff --git a/src/libscotch/parser_yy.h b/src/libscotch/parser_yy.h
>> index 931315d..95b8160 100644
>> --- a/src/libscotch/parser_yy.h
>> +++ b/src/libscotch/parser_yy.h
>> @@ -62,6 +62,9 @@
>> #if ((defined SCOTCH_RENAME_PARSER) || (defined yylex)) /* If prefix renaming */
>> #define scotchyyparse stratParserParse2 /* Parser function name */
>> +#if !defined(yylex)
>> +#define yylex scotchyylex
>> +#endif
>> #ifndef yylval
>> #define yylval SCOTCH_NAME_MACRO3 (scotchyy, SCOTCH_NAME_SUFFIXC, lval) /* It should be Yacc/Bison's job to redefine it!
>> #endif /* yylval */
>> How should we go about getting this fix in? Do you need to have our own branch of PTScotch?
>> Thanks,
>> Matt
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211123/77cac1b1/attachment-0001.html>
