[petsc-dev] HIP / hypre
Mark Adams mfadams at lbl.gov
Wed Nov 10 13:43:13 CST 2021
This sounds great, let me know if can test anything. I also have a friendly
user, ECP funded, that is interested to try out ECP solvers. This will be a
good thing for us to deliver
On Wed, Nov 10, 2021 at 2:14 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> Justin,
>   We like to have a wrapper over CUDA/HIP since with that we only need to
> maintain one code base.  Scott (Cc'ed) may introduce his work/thoughts
> along this line and coordinate with Jacob and your team.
> --Junchao Zhang
> On Wed, Nov 10, 2021 at 12:50 PM Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
>> What’s the plan going forward with this unified cuda/hip branch?
>> The end goal is to integrate PetscDevice and PetscDeviceContext — new
>> objects which encapsulates physical devices and device-side sets of
>> operations respectively — into PETSc. PetscDeviceContext provides a
>> framework for enqueueing work on device streams, but is far more
>> extensible. For example, I extend it to a very basic graph-based
>> “PetscCallGraph" implementation in
>> https://gitlab.com/petsc/petsc/-/merge_requests/4217. I believe Junchao
>> is also currently working on integrating SYCL into the PetscDevice
>> framework.
>> Is this related to what some of us have been hearing about PETSc
>> eventually going with a unified wrapper over both the CUDA and HIP API?
>> The unified CUDA-HIP wrapper exists mainly because both APIs similar
>> enough that it made sense to wrap them, and is the man in the middle
>> between direct cuda/hip calls and higher-level
>> PetscDevice/PetscDeviceContext API.
>> Best regards,
>> (Jacob Fai - booss - oh - vitch)
>> On Nov 10, 2021, at 12:28, Justin Chang <jychang48 at gmail.com> wrote:
>> Jacob,
>> What’s the plan going forward with this unified cuda/hip branch? Is this
>> related to what some of us have been hearing about PETSc eventually going
>> We’re interested in making the HIP port more mature, including having
>> support for the HIP part of HYPRE, but we’re unsure what direction you guys
>> want to go with the GPU route.
>> Thanks,
>> Justin
>> On Wed, Nov 10, 2021 at 12:19 PM Justin Chang <jychang48 at gmail.com>
>> wrote:
>>> Cc’ing Paul since I misspelled his email address initially
>>> On Wed, Nov 10, 2021 at 12:17 PM Jacob Faibussowitsch <
>>> jacob.fai at gmail.com> wrote:
>>>> I’m in the process of implementing asynchronous GPU support for petsc.
>>>> A side effect of this is that I unify the cuda/hip interface such that
>>>> anywhere we have cuda-like code we will automatically also get the hip
>>>> variant.
>>>> The scaffolding is in include/petsc/private/cupminterface.hpp, but for
>>>> concrete examples see the jacobf/2021-10-21/veccupm-async branch for
>>>> the WIP port of VecSeq in src/vec/vec/impls/seq/seqcupm/veccupm.hpp.
>>>> Best regards,
>>>> On Nov 10, 2021, at 11:50, Justin Chang <jychang48 at gmail.com> wrote:
>>>> Paul Bauman was also involved with the HIP port of HYPRE. Several of us
>>>> at AMD are interested in getting HIP support for PETSc in general, and
>>>> having HYPRE support would greatly help
>>>> On Wed, Nov 10, 2021 at 11:47 AM Stefano Zampini <
>>>> stefano.zampini at gmail.com> wrote:
>>>>> I did the work last summer. It's already available in 3.16
>>>>> Il Mer 10 Nov 2021, 20:44 Mark Adams <mfadams at lbl.gov> ha scritto:
>>>>>> Hypre has released HIP support and Ulrike says:
>>>>>> I just want to let you know that hypre can now be used through PETSc
>>>>>> with GPUs (both Nvidia and AMD).
>>>>>> I am guessing we have some work to do to make this happen.
>>>>>> What should I do?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211110/a14ae200/attachment.html>
