[petsc-dev] [DocTip!] #3 CI docs build and preview
Scott Kruger
kruger at txcorp.com
Mon Nov 8 11:40:49 CST 2021
On 2021-11-06 15:09, Patrick Sanan did write:
> Unfortunately, I don't know a simple way to reliably preview a single .rst
> file (as you might be used to from working with some Markdown-based tools).
rst2html is the standard python docutils command. The problem is that
Sphinx is really rst+(extensions for book-like documentation) so the
extensions won't be handled, But that will be true for MyST well.
Scott
Scott Kruger
Tech-X Corporation kruger at txcorp.com
5621 Arapahoe Ave, Suite A Phone: (720) 466-3196
Boulder, CO 80303 Fax: (303) 448-7756
