[petsc-dev] Running with CUDA and CUDA_VISIBLE_DEVICES=-1
Stefano Zampini
stefano.zampini at gmail.com
Mon Nov 1 10:09:14 CDT 2021
Just found out that if we configure with cuda and then want to run on CPU
only using CUDA_VISIBLE_DEVICES=-1 PETSc errors out. Is this intended
behavior? I supposed it should work
This is with main
(ecrcml-cuda) zampins at qaysar:~/miniforge/Devel/petsc$ make check
Running check examples to verify correct installation
Using PETSC_DIR=/home/zampins/miniforge/Devel/petsc and
PETSC_ARCH=arch-ecrcml-cuda-double
C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes
C/C++ example src/snes/tutorials/ex19 run successfully with cuda
Completed test examples
CUDA_VISIBLE_DEVICES=1
Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
See http://www.mcs.anl.gov/petsc/documentation/faq.html
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: GPU error
[0]PETSC ERROR: cuda error 100 (cudaErrorNoDevice) : no CUDA-capable device
is detected
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.16.0-368-g72b201b202
GIT Date: 2021-10-29 14:48:19 +0300
[0]PETSC ERROR: ./ex19 on a arch-ecrcml-cuda-double named
qaysar.kaust.edu.sa by zampins Mon Nov 1 18:06:12 2021
[0]PETSC ERROR: Configure options
--with-blaslapack-include=/home/zampins/miniforge/envs/ecrcml-cuda/include
--with-blaslapack-lib=/home/zampins/miniforge/envs/ecrcml-cuda/lib/libmkl_rt.so
--download-h2opus --with-cuda
--with-kblas-dir=/home/zampins/miniforge/envs/ecrcml-cuda
--with-magma-dir=/home/zampins/miniforge/envs/ecrcml-cuda
--LDFLAGS=/usr/lib/x86_64-linux-gnu/libcuda.so --with-debugging=1
--with-openmp --with-precision=double --with-fc=0
[0]PETSC ERROR: #1 initialize() at
/home/zampins/miniforge/Devel/petsc/src/sys/objects/device/impls/cupm/cupmdevice.cxx:302
[0]PETSC ERROR: #2 PetscDeviceInitializeTypeFromOptions_Private() at
/home/zampins/miniforge/Devel/petsc/src/sys/objects/device/interface/device.cxx:292
[0]PETSC ERROR: #3 PetscDeviceInitializeFromOptions_Internal() at
/home/zampins/miniforge/Devel/petsc/src/sys/objects/device/interface/device.cxx:417
[0]PETSC ERROR: #4 PetscInitialize_Common() at
/home/zampins/miniforge/Devel/petsc/src/sys/objects/pinit.c:956
[0]PETSC ERROR: #5 PetscInitialize() at
/home/zampins/miniforge/Devel/petsc/src/sys/objects/pinit.c:1231
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211101/b1ca68c0/attachment.html>
