[petsc-dev] Compiling issue with main branch
Jacob Faibussowitsch jacob.fai at gmail.com
Thu May 6 11:48:52 CDT 2021
Guess who’s back:
ld: warning: object file (/Users/kongf/projects/petsc1/arch-darwin-c-opt/lib/libfblas.a(ddot.o)) was built for newer OSX version (10.14) than being linked (10.9)
Best regards,
(Jacob Fai - booss - oh - vitch)
> On May 6, 2021, at 12:43, Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi All,
> I could compile 3.15.0, but could not compile the main branch using the same environment.
> If you need me to do git bisect, please let me know.
> The log was attached.
> Fande
> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210506/223db644/attachment.html>
