[petsc-dev] Tag name v3.15
Satish Balay
balay at mcs.anl.gov
Wed Mar 31 10:06:57 CDT 2021
And we just use 2 level workflow, and have branches for each of the 'releases' [as we move from one to the other]
$ git branch -r |egrep 'origin/(maint|release)-'
origin/maint-3.10
origin/maint-3.11
origin/maint-3.12
origin/maint-3.2
origin/maint-3.3
origin/maint-3.4
origin/maint-3.5
origin/maint-3.6
origin/maint-3.7
origin/maint-3.8
origin/maint-3.9
origin/maint-tao-2.2
origin/release-3.13
origin/release-3.14
Satish
On Wed, 31 Mar 2021, Satish Balay via petsc-dev wrote:
> https://semver.org/
> Given a version number MAJOR.MINOR.PATCH, increment the:
> MAJOR version when you make incompatible API changes,
> MINOR version when you add functionality in a backwards compatible manner, and
> PATCH version when you make backwards compatible bug fixes.
> For one - we don't strictly use semantic versions.
> - Our PATCH versions have (some) new functionality [from above that should be MINOR]
> - Our MINOR versions have lot more new functionality, with some incompatible API changes [this should be MAJOR - but we haven't changed that in a while]
> Wrt v3.15.0 vs v3.15 I don't remember the exact reason. I suspect we
> just stuck with this notation for a long time [and didn't want to
> change it]
> Also Barry still wants to use 'release' term only with v3.15 - and 3.15.1 etc as updates [but not releases]
> Satish
> On Wed, 31 Mar 2021, Lisandro Dalcin wrote:
> > Satish, if we use semantic versioning for the PETSc version itself and the
> > tarball, why don't we use the same format for tags? In short, why aren't we
> > using v3.15.0 instead of v3.15 ?
