[petsc-dev] Tag name v3.15
Satish Balay
balay at mcs.anl.gov
Wed Mar 31 09:54:21 CDT 2021
https://semver.org/
Given a version number MAJOR.MINOR.PATCH, increment the:
MAJOR version when you make incompatible API changes,
MINOR version when you add functionality in a backwards compatible manner, and
PATCH version when you make backwards compatible bug fixes.
For one - we don't strictly use semantic versions.
- Our PATCH versions have (some) new functionality [from above that should be MINOR]
- Our MINOR versions have lot more new functionality, with some incompatible API changes [this should be MAJOR - but we haven't changed that in a while]
Wrt v3.15.0 vs v3.15 I don't remember the exact reason. I suspect we
just stuck with this notation for a long time [and didn't want to
change it]
Also Barry still wants to use 'release' term only with v3.15 - and 3.15.1 etc as updates [but not releases]
Satish
On Wed, 31 Mar 2021, Lisandro Dalcin wrote:
> Satish, if we use semantic versioning for the PETSc version itself and the
> tarball, why don't we use the same format for tags? In short, why aren't we
> using v3.15.0 instead of v3.15 ?
