[petsc-dev] mpi.mod --with-fortran-interfaces=0
Satish Balay
balay at mcs.anl.gov
Wed Mar 24 09:30:57 CDT 2021
On Wed, 24 Mar 2021, Satish Balay via petsc-dev wrote:
> If MS-MPI is missing mpi.mod - I guess we'll have to revert this requirement. For some reason the tests in CI don't error out. I'll have to check.
> I can add back mpif.h usage [without the extra complex code we had for handling some corner cases - in this mode]
I have this [yet untested] change in balay/revert-mpi.mod-check
Satish
