[petsc-dev] configureLibrary fails for c++11 projects
Tue Mar 23 12:25:44 CDT 2021
I'm not sure if we can eliminate preprocessing. [mpi.h detection is
one place where its used - don't remember others - perhaps detection
of most includes? - some externalpacakges need them listed
separately?]
And as long as we need preprocessing as a separate step [and some
compile flags give errors when used with processor] - we'll need
separate PPFLAGS.
Satish
On Tue, 23 Mar 2021, Junchao Zhang wrote:
> Can we combine CXXPPFLAGS and CXXFLAGS into one CXXFLAGS?
> --Junchao Zhang
> On Tue, Mar 23, 2021 at 11:38 AM Patrick Sanan <patrick.sanan at gmail.com>
> wrote:
> > I had a related (I think) issue trying to build with Kokkos. Those headers
> > throw an #error if they're expecting OpenMP and the compiler doesn't have
> > the OpenMP flag. I have an open MR here (number 60^2!) which thus adds the
> > OpenMP flag to the CXXPPFLAGS:
> > https://gitlab.com/petsc/petsc/-/merge_requests/3600
> > My collaborator at CSCS was testing with the latest Kokkos and ran into an
> > even hairier version of this problem trying to use CUDA - the Kokkos
> > headers now apparently check that you're using nvcc. He has some workaround
> > which I'll review and hopefully be able to submit.
> > Am 23.03.2021 um 17:04 schrieb Stefano Zampini <stefano.zampini at gmail.com
> > The check fails within buildsystem when running mpicc -E (which uses
> > CXXPPFLAGS)  The package header needs c++11  to be included properly.
> > C++11 is also needed at preprocessing time
> > Il Mar 23 Mar 2021, 18:59 Satish Balay <balay at mcs.anl.gov> ha scritto:
> >> -std=cxx11 for sure is a compile flag. But don't really know if its
> >> also needed at pre-process stage and/or at link stage.
> >> And for compile stage both CXXFLAGS and CXXPPFLAGS should get
> >> used. [PETSc makefiles make sure this is the case]
> >> And for link stage CXXFLAGS and LDFLAGS get used [but then sometimes
> >> we have CLINKER, and FLINKER - and they certainly don't use CXXFLAGS -
> >> so -std=cxx11 isn't really needed at link time?
> >> So the previous default of CXXPPFLAGS=-std=cxx11 looks reasonable to me.
> >> However if this project is not using PETSc makefiles - it should make
> >> sure all compile flags are grabbed.
> >> # lib/petsc/conf/variables
> >> PETSC_CXXCPPFLAGS       = ${PETSC_CC_INCLUDES} ${PETSCFLAGS}
> >> ${CXXPP_FLAGS} ${CXXPPFLAGS}
> >> CXXCPPFLAGS             = ${PETSC_CXXCPPFLAGS}
> >> PETSC_CXXCOMPILE_SINGLE = ${CXX} -o $*.o -c ${CXX_FLAGS} ${CXXFLAGS}
> >> ${CXXCPPFLAGS}
> >> # lib/petsc/conf/rules
> >> .cpp.o .cxx.o .cc.o .C.o:
> >>         ${PETSC_CXXCOMPILE_SINGLE} `pwd`/$<
> >> # gmakefile.test
> >> PETSC_COMPILE.cxx = $(call quiet,CXX) -c $(CXX_FLAGS) $(CXXFLAGS)
> >> $(CXXCPPFLAGS) $(CXX_DEPFLAGS)
> >> # lib/petsc/conf/test
> >> LINK.cc = $(CXXLINKER) $(CXX_FLAGS) $(CXXFLAGS) $(CXXCPPFLAGS) $(LDFLAGS)
> >> Satish
> >> > I would rather directly change the project to use CXXFLAGS instead of
> >> > CXXPPFLAGS.
> >> > --Junchao Zhang
> >> > On Tue, Mar 23, 2021 at 10:01 AM Satish Balay via petsc-dev <
> >> > petsc-dev at mcs.anl.gov> wrote:
> >> > > On Tue, 23 Mar 2021, Stefano Zampini wrote:
> >> > > > Just tried out of main, and and the include tests of a c++11
> >> project fail
> >> > > > Below my fix, if we agree on, I'll make a MR
> >> > > > diff --git a/config/BuildSystem/config/compilers.py
> >> > > > b/config/BuildSystem/config/compilers.py
> >> > > > index c96967e..44e4657 100644
> >> > > > --- a/config/BuildSystem/config/compilers.py
> >> > > > +++ b/config/BuildSystem/config/compilers.py
> >> > > > @@ -527,6 +527,8 @@ class Configure(config.base.Configure):
> >> > > >          if self.setCompilers.checkCompilerFlag(flag, includes,
> >> > > > body+body14):
> >> > > >            newflag = getattr(self.setCompilers,LANG+'FLAGS') + ' ' +
> >> > > flag #
> >> > > > append flag to the old
> >> > > >            setattr(self.setCompilers,LANG+'FLAGS',newflag)
> >> > > > +          newflag = getattr(self.setCompilers,LANG+'PPFLAGS') + '
> >> > > flag
> >> > > > # append flag to the old
> >> > > > +          setattr(self.setCompilers,LANG+'PPFLAGS',newflag)
> >> https://gitlab.com/petsc/petsc/commit/ead1aa4045d7bca177e78933b9ca25145fc3c574
> >> > >           self.setCompilers.CXXPPFLAGS += ' ' + flag
> >> flag #
> >> > > So the old code was setting 'PPFLAGS' - but this commit changed to
> >> > > 'FLAGS'. Maybe this flag is needed at both compile time and link time?
> >> > > So this project is somehow using CXXPPFLAGS - but not CXXFLAGS?
> >> > > I'm fine with adding it to PPFLAGS - duplicate listing hopefully
> >> shouldn't
> >> > > cause grief.
> >> > > Satish
> >> > > >            cxxdialect = 'C++14'
> >> > > >            self.addDefine('HAVE_'+LANG+'_DIALECT_CXX14',1)
> >> > > >            self.addDefine('HAVE_'+LANG+'_DIALECT_CXX11',1)
> >> > > > @@ -546,6 +548,8 @@ class Configure(config.base.Configure):
> >> body):
> >> > > flag #
> >> > > flag
> >> > > >            cxxdialect = 'C++11'
> >> > > >            break
